Off-road newbie -- what armor do I need?
Discussion in 'Armor' started by galactoid, Nov 22, 2019.
  1. Nov 22, 2019 at 5:56 PM
    galactoid
    galactoid [OP] New Member
    Hi all, new Tacoma ('19 TRD Off-road) owner here.
    I don't plan on doing rock crawling exactly but I do drive on rough, rocky dirt roads a fair amount to get to trailheads, and I'd prefer not to damage anything if what looks like a shallow puddle turns out to be a deep pothole, etc, so some armor seems like a good idea.
    - What is a reasonable amount of armor for my purposes? Oil pan, transmission, transfer case, diff, ...? All of the above? Some?
    - What about aluminum vs steel? Are they of equivalent strength but the aluminum is lighter weight, or what?
    - What about rock slider bars? Overkill for what I'm doing?
    - Any other advice?
    I'm in Montana, so a vendor in the western US would be good to minimize shipping cost. Any suggestions? I don't really know what to look for, and I'm sure there are lots of good vendors, but a little searching found RCI in Colorado: https://rcimetalworks.com/product-category/toyota/tacoma/16-19-tacoma/
    Thanks for any advice!
  2. Nov 22, 2019 at 6:14 PM
    Deathdealer
    Deathdealer Well-Known Member
    Ricky Spanish
    Texas
  3. Nov 22, 2019 at 8:55 PM
    6AYoteHunter
    6AYoteHunter Well-Known Member
    Stewart
    Northern AZ
    2014 TRD 4x4 2019 TRD 4x4
    On my 2014 with 43k miles (about 10% of that offroad) the factory skids are barely adequate. I have one cracked and another dented just from rock flip ups. Have new skids on the way. Also have rock sliders ordered with fill plates after having more than once broken limbs kick up. Luckily no damage to anything so far.
    Asked a friend who owns the tire shops around here and he said every truck has some sort of damage underneath by the time they hit 50k in northern or central AZ if taken off road at all.
  4. Nov 22, 2019 at 8:58 PM
    6AYoteHunter
    Stewart
    Northern AZ
    Factory skids are thinner than most steel cookie sheets. Not a lot of protection.
  5. Nov 22, 2019 at 9:02 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    I was going to type this same reply pretty much. If you’re not sure if the puddle has a bottom get out and poke it with a stick.
    whatstcp[QUOTED] likes this.
  6. Dec 12, 2019 at 12:16 PM
    Brewnasty
    Brewnasty Active Member
    Sandford NC
    2007 Tacoma TRD Off-Road
    265/75/16 coopers, high clearance exhaust, more to come..
    You probably be fine with a set of aluminum skids plates form front to rear on the belly of your taco, and some rock sliders with kick-outs. If your are really worried about it.
    That's what I ran on my Fj cruiser. But i took rock crawling and overland alot.
    But if you have a good spotter and don't do anything to crazy you should be fine with stock skids.
    Hamer95USA likes this.
  7. Dec 19, 2019 at 10:59 AM
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    Stay stock. Save weight. Drive smartly.
  8. Jan 8, 2020 at 9:06 PM
    tacopearl
    tacopearl Well-Known Member
    WA
    2012 TRD-OR 6-Spd
    you can barely call the factory plates "skid plates"
