OEM TRD sema wheels clarification?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sbmon, Jul 30, 2017.
  1. Jul 30, 2017 at 7:41 PM
    sbmon
    sbmon [OP] Well-Known Member
    I have been looking at wheels recently and was hoping folks here could clear something up. I am looking at a commonly used 3rd gen wheel which is the OEM TRD SEMA wheel. Unfortunately I keep coming across conflicting measurements on fleabay ( I have seen OEM listed wheels with both 17x7 and 17x7.5 widths and have seen two other figures for offset/backspacing) for these wheels. Now maybe there is more than one size or offset version but can someone provide the specs for this wheel including the offset.
    Thank you
  2. Jul 30, 2017 at 8:17 PM
    Nightscape
    Nightscape Well-Known Member
    SoCal
    2017 TRD Sport DCLB
    4Runner Pro TRD wheels are 17x7 (4) offset. Anything else is a knockoff
    JS760, RIDERED67 and doorsidedown like this.
  3. Jul 30, 2017 at 8:51 PM
    sbmon
    That's the first time I have seen the offset listed as negative value. Where did you find the specifications?
  4. Jul 30, 2017 at 9:26 PM
    Nightscape
    SoCal
    2017 TRD Sport DCLB
    Sorry...Meant 4mm
    (Fixed)
  5. Jul 31, 2017 at 3:03 AM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    Offset is 4mm.
    Part number gray: PTR20-35110-GR
    Part number black: PTR20-35110-BK
    Edit: more info
    For vehicles with OE 20 inch wheels, you must order & install the TRD 17 inch Tire Pressure Label (MDC# 00602-35155) when installing these TRD 17" wheels & 17" OE tires.
    TRD Owner's Manual Label (MDC # 00602-35061) also required and available thru the MDC.
    Matte GRAY Paint Color with Red TRD Logo on Center Cap.
    17 inch x 7.0 inch x 4 mm offset, Cast Aluminum TRD Wheel with TRD snap-in center cap (PTR20-35111-GR).
    This wheel is designed for use with OE Flat-Seat lugnuts (90942-01058), sold separately.
    Optional 4Runner DIO Wheel Lock Kit is 00276-00901
    Optional FJ Cruiser DIO Wheel Lock Kit is 00276-42960 (includes 5th lock for spare tire)
    This wheel is designed to re-use the OE 17" Tires P265/70R17 113S
    jamesfishn09 likes this.
  6. Jul 31, 2017 at 6:40 AM
    Sedyn
    Sedyn Well-Known Member
    Justin
    Vancouver, BC / Sumas, WA
    17' TRD Pro, Cement.
    Great info, thanks!
