OEM Tonneau Cover Toyota
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Areyna2313, Nov 10, 2021.
  1. Nov 10, 2021 at 1:21 PM
    Areyna2313
    Areyna2313 [OP] Active Member
    Ashley
    2022 Army Green Toyota Tacoma TRD OR DBL CAB
    I have a guy willing to install the OEM Toyota Tacoma tonneau cover for $200. It’s coming off his 2017 short bed Tacoma. I have a 2022 TRD Off Road Tacoma short bed double cab. I shouldn’t have a problem with fit for this should I? Any reason not to purchase it? Seller indicates all the hardware is including and he would install it. I called the dealer and they said it would be $1,025 to install and I’ve been going back and forth on the Bakflip MX4 and Leer covers. Attaching a picture for reference!
  2. Nov 10, 2021 at 1:27 PM
    Lgeekdws
    Lgeekdws Well-Known Member
    2015 Magnetic Grey V6 4x4 SR5
    Should fit, looks in good shape and it's is cheaper than the options you list. But it's your $$$
    Areyna2313[OP] likes this.
  3. Nov 10, 2021 at 2:47 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Yes cheaper than Mx4, but not the quality. I have one on my 18, leaks bad. Fades/caulking out, need to constantly put protectant on it. Tried all different adjustments, can't stop leaks, and it leaks bad.
  4. Nov 10, 2021 at 2:54 PM
    Mr.Gea
    Mr.Gea Well-Known Member
    Gea
    Lancaster, PA
    2020 TRD Sport Cement
    Those OEM tonneau covers are junk. They're too heavy and doesn't seal right, always leaks in the rain.
    On mine the back by the tailgate lifts up about 1/2", no matter how I adjust it.
    Go aftermarket, you will be much happier.
    bigsmirt, Aqualoon and na8rboy like this.
  5. Nov 10, 2021 at 2:56 PM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    You have a brand new truck, get a new cover, and install it yourself. It really isn't hard, tons of youtube videos to help.
    I have a cover i got for 150, and its great, and my bed is dry.
  6. Nov 10, 2021 at 3:16 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    IMG_20210727_154026476.jpg My OEM cover is very nice, fit and finish to me is the best. The aftermarket ones just don't fit perfect enough for me. They are too square and don't conform to the lines of the bed. Mine leaks water in the tailgate when I wash it but that's the only place but I stopped that with some foam strips. I covered mine with a pro grade coating product I was given by a friend. Only wash it and nothing else.
    Simon's Mom and Areyna2313[OP] like this.
  7. Nov 10, 2021 at 4:35 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    No leaks whatsoever currently on my 2020 6' bed toyota tonneau cover. When it was brand new it had a couple spots on the driver side that let in a small amount of droplets when we had severe thunderstorms, or a hurricane. The second year all has settled in well to seal those spots leaving the insides perfectly dry. I just wish the rubber smell from the bed mat would go away.
  8. Nov 10, 2021 at 4:46 PM
    Areyna2313
    Ashley
    I realize it won’t be 100% waterproof but rather water resistant but so many people who say yes then others who say no! It’s hard to decide. But $200 is worth a shot. I did get tonneau cover cleaner and also weather strips. I’m going to see if that’ll help.
  9. Nov 10, 2021 at 4:50 PM
    DamGuide
    DamGuide Well-Known Member
    Nooga, TN
    2020 TRD Offroad
    He would have to swap bed caps with you, but install is super simple. So is the dealer wanting $1000 just to install his cover or a new aftermarket cover? Dealer will absolutely not sell you this cover unless you are in Canada.
  10. Nov 10, 2021 at 4:52 PM
    Belgian Taco
    Belgian Taco Well-Known Member
    2019 MGM SR SX
    I would make sure you’re dedicated to having this cover before going through with it. I had the factory cover and transitioned away from it. Personally, I’d rather have a shell than a tonneau. The issue is that the bed rail protectors (the plastic trim on the top rails of your bed) have to be notched to accommodate the cover. They come like this from the factory but I’ve seen some people make their own (looks terrible). This seller is likely going to switch your brand new rail protectors for their used, notched protectors.
    If you really want a tonneau, I’d do it right the first time and get a Diamondback: https://diamondbackcovers.com/produ...MIua667YuP9AIVAz6tBh35kApoEAAYASAAEgJ_ZvD_BwE
    Kev250R likes this.
  11. Nov 10, 2021 at 4:56 PM
    Areyna2313
    Ashley
    He agreed to swapping bed caps with me. The dealer wanted to charge $1000 for both the install and the tonneau OEM Toyota cover.
  12. Nov 10, 2021 at 5:04 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    For 200 it’s a great deal, will fit no problem
    Bleep100 likes this.
  13. Nov 10, 2021 at 6:49 PM
    DamGuide
    Nooga, TN
    2020 TRD Offroad
    Are you in Canada? That’s the only place I know of that it is sold by a dealer. The OEM tonneau cover isn’t available in the USA as a kit like it is in Canada. To buy it in parts is something like $2k in parts alone. It’s pretty ridiculous. They were probably just gonna put an aftermarket one on your truck for $1k.
    Only way to get it new for cheap in the USA is to get it with it on the truck when you buy the truck from Toyota. Used is the other option.
  14. Nov 10, 2021 at 9:17 PM
    Areyna2313
    Ashley
    I wouldn’t be surprised if they were trying to pull a quick one on me. I specifically said OEM Tacoma tonneau cover and he said they come out of Portland and they’re the OEM ones. I ended up getting this gently used one and it’s actually in real good shape! I’ll upload a photo in the AM.
  15. Nov 11, 2021 at 4:07 AM
    MR.WaynesWorld
    MR.WaynesWorld Well-Known Member
    Wayne
    North East Pa
    2021 Black Tacoma Limited
    **** 2021 Mods **** Sokietech No Drill Hood Struts (Replaced) Color Matched Mirror Caps Color Match Door Handles SUPAREE LED Side Mirror Turn Signal Lights AVS Dark Smoked Hood Bugflector (Removed) Meso Black Interior Door Handles AVS Window Vents AUTOGINE Super Bright 6000K White LED Vanity Mirror Lights 3D Rear Tacoma Letters Matte Black OEM Blacked Out Emblems OEM Black Trim around Fog Lights Full BedRug AMP Research Bed Extender LoMax Tonneau Cover (Replaced) RBP 77-Spike Wheels 18X9 (Replaced) Nitto Terra Grappler G2 tires 285/60 (Replaced) Blacked out Toyota emblem on steering wheel Night Shade Front Grill (Replaced) Dark Tint Front TSS Emblem (Replaced MBRP Dual Exhaust KTJO Door Pod lighting Window Tint, 5% in the back 30% up front MESO Chrome Delete center console MESO Chrome Delete Vent Rings **** 2022 Mods **** Cali Raised Steel Front Skid Plate (Replaced) Ice Blue Map and Dome LED bulbs Rek-Gen XL Mud Flaps - Black on Black All interior trim painted Matte Black with Flat Clear Coat Aqua Blue Foot Lights - Front and Rear MESO Switch Panel Custom Layout MESO 3 Switch Overhead console panel MESO Chrome Delete Climate Control Rings UpTop Bravo Roof Rack Extreme LED 38 inch LED Light Bar in Roof Rack Diode Dynamics LED Strip Grill Lights Meso Ultimate Tail Lights (Replaced) Rock Lights - 8 Cyclone V2's (Replaced) UpTop Roof Rack Grab Handles UpTop Scene Pods with Baja Design Rock Lights Diode Dynamics Elite Series Fog Lights CaliRaised Stealth Bumper 30 inch Infinite Offroad LED Light Bar X2 Zeak 10,000 Winch KTJO Driver's Side Grab Handle LambTek Winch Switch Boomers "faux" TRD Pro Shift Knob Tacoma Lifestyle Smoke Third Brake Light Blacked out Instrument Panel Lens Diff Drop Dobinson's Suspension, Front Coil Overs, UCA's, Rear Shocks and Leaf Packs DB Customz Grill, Color Match with RGBW LED Letter Lighting **** 2023 Mods **** PowerTrays Tray with Busemann Fuse Relay Pioneer DMH-WC6600NEX Maestro RR2 SiriusXM SXV300 Tuner BoxWare Anti Glare HU Screen Protector Varity of cables and adapters Focal ACX 690 Front Speakers (Replaced) Focal ACX 165 Rear Speakers (Replaced) Diode Dynamics Stage Series Rock Lights - 3 in each wheel well Diode Dynamics Flush Mount Brackets Revolver X4s Tonneau Cover UpTop Roof Rack Grab Handles V2 Raceline Compass 17X9 wheels Toyo Tires Open Country A/T III 275/70R17 Tacoma Beast Infinity Tail Lights Taco Clout Wide Angle Convex Mirrors - Heated + Turn Signals + BSM KTJO Powered Folding Mirrors **** 2024 Mods **** Lighting Trendz Glow LED lights in Grill Lettering Cali Raised Cat Shields The Sub Box Shop Sub Amp box Rockford Fosgate 10 inch 4 ohm Dual VC Sub Kicker 3.5 inch speakers in dash (Replaced) Auto Harness House harness adapters for speaker wires Alpine PXE-C80-88 8 Channel Amp. Polk Audio DB 6502 Front Doors Polk Audio DB 6502 Tweeters in Dash Polk Audio DB 652 Rear Doors Hidden LED's in Bed Charvonia Design Bed Rail Tie Down Anchors Charvonia Design Bed Tie Down Anchors Charvonia Design Bed Floor Tie Down Anchors Charvonia Design Billet Battery Tie Down Redline Hood Struts TRD Pro Hood KITT Scanner LED in Hood Scoop Cali Raised Aluminum Skid Plate
    My Limited came with the factory tonneau cover. Yes it leaked. Took it off and sold it. Put on a LowMax tonneau and very happy with the look..
  16. Nov 11, 2021 at 4:09 AM
    Jeffaz1
    Jeffaz1 Well-Known Member
    Phoenix, AZ
    2020 Tacoma TRD Pro MGM
    MX4 for me, but people are different and some are ok with things that aren't as nice.
  17. Nov 11, 2021 at 4:11 AM
    Aqualoon
    Aqualoon More stickers!
    Minnesota
    2019 Off-Road DCSB Cavalry Blue
    Way better aftermarket options.
  18. Nov 11, 2021 at 4:39 AM
    Ryeguy
    Ryeguy Well-Known Member
    43* North
    2021 TRD Off Road 4X4 Blackout
    OEM Bed Extension, Bed Mat, Lomax Bed Cover, Auto lock tailgate (OEM)
    Bought my LOMAX tri-fold from a vendor here for $650 and installed it myself in maybe an hour.
    I still have my factory bed rails so if I remove the cover, the truck will be stock.
    If you buy this used cover and decide you don’t like it, good luck getting your factory rails back. You’ll be forced to use only the Toyota cover because your swapped rails will have cut outs that’ll leak with anything other than OEM.
    My advice is to spend the extra $450 and buy a new LOMAX. If you had an older truck, I’d say go for it, but putting an old faded cover on a new truck (and one you can’t easily switch back from) just makes little sense to me.
  19. Nov 11, 2021 at 5:34 AM
    mattwhit08
    mattwhit08 Well-Known Member
    2018 Tacoma TRD Sport Double Cab
    Completely agree with Ryeguy.
    I had the OEM and it’s heavy and doesn’t fold all the way up. I did the same thing, snagging a LoMax for that price, probably from the same vendor. 100x better. Looks so clean, it’s low profile, folds all the way up when I need the full bed, and isn’t a third as heavy as the OEM. Spend the extra $$ for your truck. It’s a well worth-it investment.
  20. Nov 11, 2021 at 5:46 AM
    zoo truck
    None
    I disagree oem covers are junk. Properly installed they seal near water tight.....mine actually got better after a year as far as sealing. You cannot find a drop water anywhere no matter how hard it rains now. Another thing maybe its the trucks build, and not the covers fault if not sealing well.
    The only remaining issue with these oem covers i have is the external quality of material used. So far 0 complaints. Dealer did supply me with a bottle of wolfstein protectant to apply when needed.
    VaToy and Lynx416 like this.
