OEM Roof Rack Removal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by madisonsfinest, Dec 13, 2009.
  1. Dec 13, 2009 at 9:14 PM
    madisonsfinest
    madisonsfinest [OP] Addicted to my DSLR
    Madison, WI
    2010 DC OffRoad 4x4 Debaged
    Factory Roof Rack Avid Offroad Light Bar 16" XD Hoss Truxedo LoPro QT Window Tint Autobot Emblem w/Autobot Shifter Color Matched Grille
    When I bought my truck the dealer had the oem roof rack installed on it. I'm not a big fan of the way it looks. Can it be taken off, or was it drilled when installed? Thanks for any help
  2. Dec 13, 2009 at 9:22 PM
    TL697
    TL697 Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    I'm not positive, but I think the holes are present on all trucks... I'm interested in the rack if you remove it...
    I've heard that all I have to do to add the rack is to remove the trim pieces and the holes are already there... Maybe some others can shed some light on the subject...
    We might be able to swap your rack for my trim pieces...
  3. Dec 14, 2009 at 6:08 AM
    madisonsfinest
    Madison, WI
    At this point I'm not interested in getting rid of the roof rack. I'm wondering if I were to remove it, would it be the same way it was before it was installed? Thanks
  4. Dec 15, 2009 at 9:04 PM
    Madtown Taco
    Madtown Taco Well-Known Member
    Madison, Wisconsin
    05 TRD Sport SR5 DC LB 4x4
    Gun Metal FJ Cruiser TRD Wheels, Black Head Lights, I-pod Patch Cable for Stock Head Unit, In-Cab 115V outlets, Aries Bull Bar, 12V outlets in Bed, Snug Top Super Sport Topper, Hard-Wired Valentine 1 Radar Detector, Disabled Automatic Air Conditioning for Windshield Vent Setting, Additional D-Rings in Bed, 12-Volt Pop-N-Lock Solenoid in Tailgate Handle, TRD Front Seat Covers, WeatherTech Floor Mats
    I believe wether or not a tacoma came with the roof rack, that they all have the threaded holes already drilled into them for mounting one. Of course we are only talking about the double cab models here. If you remove yours, you would probably want to get the drip channel trim strips and clips that hold them in place. There is probably some sort of rubber plug or similar that goes in the threaded holes where the rack mounting hardware once was. You may be able to find them used or new for sure from the dealership, ebay, etc. I saw a post on here earlier that said the trim pieces and clips that go in the place of you removed roof rack are $140 new from the dealership.
  5. Dec 16, 2009 at 9:46 AM
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    2018 TrD Sport Upgrade
    "Hello Kitty" steering wheel cover.
    The previous posters are all on the right track.....All of the DC's come with the mount holes pre tapped under the drip channels.When you install the rack,you remove the drip channels and the holes are under a layer of tape.You cut the tape to expose the holes,and the front plastic clips that retain the drip channel are snapped off with a screwdriver.My thought is that when you remove your rack,cover the holes with a strip of duct tape so that the holes are not permenently disabled for future use.In the front,you can either buy new clips to re-install the channels or use silicon to secure it down.
  6. Apr 8, 2016 at 9:48 AM
    ColoradoEd
    ColoradoEd Member
    I am going to remove my OEM roof rack this weekend. It sounds pretty straight forward. I plan on using silicone at the front and back to secure the drip channel trim strips. Any pitfalls I may encounter?
  7. Apr 8, 2016 at 1:47 PM
    TOP TACO
    TOP TACO Well-Known Member
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    sounds like you may want to plug the threaded holes where rack was bolted down, not sure if the drip strip is going to keep water out 100%
  8. Apr 8, 2016 at 1:51 PM
    travel_taco
    travel_taco Gentlemans Sausage
    CO
    09 Rust Bucket
    anti-fuel saving mods
    This, to install the oem roof rack you had to remove or poke holes in the waterproof tape that was covering the threaded holes. Either fill those holes up with silicone or use some waterproof foam tape and you'll be set.
  9. Apr 8, 2016 at 1:53 PM
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    that's what I figured. I never removed the factory tape.
  10. Apr 8, 2016 at 5:52 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I actually installed a set on my truck. The rivnuts are there and on mine were covered with the stickers that have the vin number on the doors, tailgate, etc. They were put on before paint if I remember correctly
  11. May 9, 2017 at 6:48 PM
    Crazy Nick
    Crazy Nick Well-Known Member
    Crazy
    03" TRD 4X2, 07" 4Runner 4X4, 2015 TRD Sport 4X4
    I'm looking at a 2015 Tacoma double cab that has the factory roof racks (which I would want to remove). I noticed that a portion of the rack sits on the roof next to the channels - Is there an impression left behind on the paint when you remove them ?
  12. May 9, 2017 at 6:52 PM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    Yes. Follow these instructions in reverse: https://www.tacomaworld.com/threads/oem-roof-rack-install.126753/
  13. May 9, 2017 at 7:20 PM
    Durdy
    Durdy Well-Known Member
    Utah
    2012 Black Sand Pearl Tacoma TRD Off Road
    Relentless Fab Bed Bars Prinsu Roof rack CVT Mt Shasta Extended Summit RTT CVT Pioneer 72"Awning Road Shower 7 Gallons Pelican Case Roof Mount EBC Stage 4 disc brakes EBC Green Stuff Pads Rear Axle Breather Relocation 12v plug in bed for RTT Rigid SR-M Diffused Bed Light Bilstein 6112 SPC Upper Control Arm Rad Rubber Designs Engine Splash Guards 2" Add-a-leaf 265/75/R16 Falken Wildpeak AT3W
    If anyone wants to get rid of their OEM roof rack im interested. Just putting that out there.
  14. May 11, 2017 at 8:46 AM
    Robman
    Robman Well-Known Member
    Rob
    Hawaii
    '14 Tacoma Double Cab
    When I removed the oem roof rack, I filled the holes with silicone and further covered them with mastic electric tape. Been a couple months and some heavy downpours no issues.
    You may find that in addition to the ditch mouldings that you'll want to grab a couple of the clips for the front. They are damaged or removed as part of the installation.
    TOYOTA\LEXUS\SCION 7556102020 GENUINE OEM DRIP MOLDING CLIP
    https://www.ebay.com/itm/162269982371
  15. Jul 5, 2020 at 6:27 PM
    Msuizor
    Msuizor New Member
    2016 TRD spt
    Anyone remove and replace the OEM rack with a different rack?
    If so, are there any direct bolt on's or will there be mods required?
  16. Jul 5, 2020 at 6:36 PM
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    Yes it can be removed. If you aren't installing new rack, then put silicone around the holes then put waterproof tape. Then install weatherstrips in. If you plan to install alternative rack such as Prinsu, you can install in the threaded holes. Make sure to use silicone before you put spacers in for Prinsu rack.
  17. Jul 5, 2020 at 6:38 PM
    Msuizor
    Msuizor New Member
    2016 TRD spt
    Thanks for the reply, I'm looking to replace the rack with something heavier. With the replacement rack like the prisnu, would I need the new weather strips or leave as is?
  18. Jul 5, 2020 at 6:44 PM
    TAZMINATOR
    2017 Tacoma
    Up to you. If you install the rack, you can place the strips between the spacers. Or you can drill holes in the strips for spacers in. Which you can see it in video:
    https://www.youtube.com/watch?v=F7g1rGOQqJU
    You can even leave the strips out in case you plan to sell the truck and take the rack off then install the strips in. Like I said, up to you.
