OEM roof rack removal
Discussion in '3rd Gen. Tacomas (2016-2023)' started by vanislandtacoma, Jan 20, 2020.
  1. Jan 20, 2020 at 11:02 AM
    vanislandtacoma
    vanislandtacoma [OP] New Member
    Has anyone taken off the OEM roof rack from the dealership and replaced it back with the weather stripping? Mine is leaking inside the cab and dealership has the parts on order. Just seeing if anyone has replaced it back to stock and what process they used to cover up the bolt holes.
  2. Jan 20, 2020 at 11:04 AM
    Shellshock
    Iowa
    You could do it, but it’s a lot of holes to try and seal off. I’d use an excessive mount of silicone or rtv to try and seal them off.
  3. Jan 20, 2020 at 11:05 AM
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    There’s ways to stop the leaking if you want to keep the roof rack. Not sure on the best process for returning to stock but I’m sure it can be done.
  4. Jan 20, 2020 at 11:19 AM
    photoguy190
    photoguy190 Well-Known Member
    James Goff
    Middle TN
    your best bet would be to use the original hardware in the holes and apply a liberal amount of slicon over them. Unless the dealer can get the original sticker covers.
    Shellshock likes this.
  5. Jan 20, 2020 at 11:31 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    holes dont go through to the interior, you have a leak somewhere else. the oem holes with rivnuts are there, with weatherproof tape, then the moulding slips into the channel. the moulding is held on in front and rear by retainer clips. and the rear has double sided tape where it wraps from the roof to cab back panel at the back glass. the worst part about swapping back to the mouldings is, the rubbing the roof rack did to the roof finish... and you have to glue the front and rear retainers down, with something that wont come off. fill the holes with silicone, and weatherproof tape over them, for peace of mind. for the record, i switched mine from the rack back to the mouldings, not a fan of the look. cost about 150 bucks for the mouldings and retainers. Ski
  6. Jan 20, 2020 at 12:10 PM
    vanislandtacoma
    the new mouldings wont cost me anything its being covered by warranty because the dealer is the one who installed the roof rack. personally i dont like the roof rack it came with the truck when i bought it.
    Big tall dave likes this.
  7. Jan 25, 2020 at 7:50 AM
    ID.AZ
    ID.AZ Well-Known Member
    2019 TRD Off Road
    My truck came with the roof bars too...not a fan and would love to remove them but not sure how big of a nightmare it would be...Sub’d for info. Good luck bro...
  8. Jan 25, 2020 at 10:29 AM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    I had one, then removed my roof rack for a while. I just cleaned the channels and put a couple of layers of duct tape over the holes. It rained a lot, no leaks. If I was taking the rack off permanently, I would have filled the bolt holes with silicone before the tape. A few beads of HomeDepot window caulking held the weather stripping on too.
  9. Jan 25, 2020 at 10:36 AM
    Big tall dave
    FYI- I’m pretty sure I remember checking and the rivnuts on my truck weren’t the blind type and the holes went right through to the interior....
  10. Jan 25, 2020 at 10:43 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    Make sure to collect your rack when you pick it up. I'd sell it and recoup the money.
    I think the rack looks sexy. but opt for a slick roof. I worry about wind noise
    ID.AZ, Big tall dave and Nito like this.
