Oem roof rack problems
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sr.Tacoma, Nov 14, 2019.
  1. Nov 14, 2019 at 7:46 PM
    Sr.Tacoma
    Sr.Tacoma [OP] Bryan
    Bryan
    Olathe/Overland Park Kansas
    2019 Tacoma SR 4X4 V6 DCSB
    Led Light Bulbs (High-Low Beams) Reverse Led Bulbs Body Armor 4x4 Rear Bumper Level8 MK6 Wheels Yokohama Geolander G003 Interior Led Lights OEM Roof Rack AVS Rain Guards AVS Bug Deflector OEM Foglights
    I got a oem roof rack. The bolts idnt align and it was giving me a hard time. It was very upset trying to put the bolts in when they didnt want to go in. The bolts were straight but were very tough to get in. I actually stripped a bolt cuz it was so hard to tighten. The passenger cross bar nut was securely tighten. But the cross bar can swing a 360 degree. But the driver side cross bar doesnt swing that far. Did i do something wrong? Any comments or answers?
  2. Nov 14, 2019 at 7:57 PM
    Dammit Evie
    Dammit Evie Evie the Schnauzer
    IDAHO-.-. .-.. .- ... ... .. ..-. .. . -..
    2018 Tacoma TRD Sport 4x4 DCSB A/T MGM
    Exterior Mods: TRD Pro SS catback exhaust | TRD Pro Grille | Redline Tuning hood QuickLIFT | OEM Tacoma bedmat | Black running boards | Derped chrome badges | Me-So Gashole | TRD Pro 17x8Alloy wheels Interior Mods: Black Clazzio Napa Leather seat covers |Aluminum stereo knobs Engine Mods: TRD Pro Intake Air Box Up Coming Mods: 265/70R17 Falken Wildpeak tires
    We can't tell what you did without pictures.
    The hammer and Chew like this.
  3. Nov 14, 2019 at 8:07 PM
    rkl17
    rkl17 Well-Known Member
    Utah
    2018 TRD Sport
    Did you fully tighten the first bolt you put in? You need to get every bolt started before you tighten any of them. I installed one of these about a year and a half ago and I remember it being more difficult than I thought but I was able to get everything lined up and the cross bars functioned properly.
  4. Nov 14, 2019 at 9:17 PM
    Sr.Tacoma
    Bryan
    Everything is as tight as it will ever be. I stripped acouple of bolts due to much force i was applying. Cross bar bolts are super tight. But feels like they have room. I have been too scared about trying to take out the bolts of the cross bars because it was such a hassle. I remember seeing a small purple o ring. I didnt pay much attention to it. Should i have?
  5. Nov 15, 2019 at 7:40 AM
    choose for me
    choose for me Not Sure
    Northwest Florida
    2017 Toyota Tacoma TRDOR
    Flux Capacitor
    Where did you get the roof rack? I've noticed on Amazon that some of the part numbers are incorrect for applicable generations. Between the 2nd and 3rd gen, I believe the part numbers have changed 2-3 times. Some are interchangeable, some are not. I bought a used 2nd gen roof rack without the mounting hardware, and had to get new hardware from Amazon. The first kit was clearly not for my truck, even though the part numbers were cross-referenced on Amazon and from Toyota. I ordered another kit, and it worked just fine. The only difference between the two were bolt diameter and length. I'm guessing this may be your issue.
  6. Nov 15, 2019 at 7:55 AM
    El Latigo
    El Latigo Well-Known Member
    Anaheim CA
    2017 MGM TRD OR Double Cab Short Bed
    I bought mine straight from the Toyota dealer about a year a go.. But i don't remember having to force the bolts in.. in some cases i had to wiggle the roof rack to a line it with the holes but the bolts went in with out much force. sorry no much help here..
    As indicated above, did you check the part number to make sure is the correct one?
  7. Nov 15, 2019 at 8:03 AM
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote YotaWerx Tuning
    I had to eggout one of the roof holes before I could bolt mine up. There was roof metal in the way of the hole. After a slow process and a dremel bit I opened it up and all was well.
  8. Nov 15, 2019 at 8:08 AM
    Sr.Tacoma
    Bryan
    I got the roof rack from my toyota dealership where i bought my truck. I spent the extra money because i read the forums that you would have a harder time putting it in. But i ended up having a hard time anyways. I ended up stripping the bolts that holds the roof rack to the metal bracket. And the passenger cross bar feels looser than the right side even though the bolt to keep it from coming out is very tight. My luck. Lol
  9. Nov 15, 2019 at 8:19 AM
    choose for me
    Northwest Florida
    Flux Capacitor
    What's the part number on the box? I have been handed wrong components from the parts department from my local dealership, and I actually like and mostly trust them with my vehicle. There's 3 part numbers for the roof rack: PT278-35130, PT278-35140, and PT278-35170
    From Amazon:
    Genuine Toyota (PT278-35170) Tacoma Roof Rack
    • for model years 2017-2019 only
    • Toyota has superseded part number PT278-35130 to PT278-35170
    • Supports a maximum of 75 lb. when weight is evenly distributed across both bars
    • 2015 Tacoma
    TOYOTA Genuine PT278-35140 Roof Rack
    • Genuine OEM
    • Securely haul items
    • Long lasting sturdy construction
    • Easy to install
    • 2014-2016 Tacoma
  10. Nov 15, 2019 at 4:40 PM
    paviLLion
    paviLLion New Member
    2019 SR5
    Do the racks from the dealer come with cross bars ?
  11. Nov 15, 2019 at 4:42 PM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    Lexus LX 470
    The bolts won't go in the roof holes or it won't tighten on the arm?
  12. Nov 15, 2019 at 5:53 PM
    wahoobie
    chris
    Suffolk, VA
    Later we find out the whole unit was installed backwards.
  13. Nov 15, 2019 at 6:02 PM
    El Latigo
    Anaheim CA
    Yes....
  14. Nov 15, 2019 at 6:11 PM
    paviLLion
    2019 SR5
    They told me they didn't so I just wanted to clarify.
  15. Nov 15, 2019 at 6:31 PM
    Sr.Tacoma
    Bryan
    The cross bar bolts is as tight as it can go. But the cross bars seems loose. The cross bar latches fine but it wiggles as if the bolts to hold in the cross bars are too long.
  16. Nov 28, 2019 at 5:48 PM
    Kinggargantuan
    Kinggargantuan Well-Known Member
    Nick
    2014 grey dcsb trd or 4x4
    Stock
    do you have a link or part number for your mounting kit?
  17. Nov 29, 2019 at 6:15 AM
    choose for me
    Northwest Florida
    Flux Capacitor
    Unfortunately no. Amazon processed my return as an exchange, so the replacement order has the same part number, even though it's different. And I didn't keep the box with the new part number.
  18. Nov 29, 2019 at 6:27 AM
    1taco2motos
    1taco2motos Well-Known Member
    Colorado
    19 DCSB mgm TRD OR 6MT
    I had trouble installing my rack as well. Make sure the plastic liner is where it should be and yes you need the purple o- ring. If it fell out that means you lost the nut that the cross bar bolt threads into, which is very easy to lose.
  19. Dec 4, 2021 at 5:08 PM
    CTtoNoVa
    CTtoNoVa Well-Known Member
    2017 DCSB TRD OR Magnetic Gray
    Pop N Lock
    Wouldn’t you know this though? Otherwise the bolt would just spin
