Oem rebuild kit for 5vzfe 3.4L
Discussion in '1st Gen. Tacomas (1995-2004)' started by bodhi armor, Nov 20, 2023.
  1. Nov 20, 2023 at 2:42 PM
    bodhi armor
    bodhi armor [OP] 02’ Dbl Cab- "The Luck Dragon"
    Joshua
    East TX
    2002 4x4 Dbl Cab Jade Green
    Hey TW!
    My beloved bulletproof 2002 Tacoma hit 340,000 miles this week!! Well done TOYOTA!!
    It’s creeping into the mileage range where the engine will need to be rebuilt soon. I ONLY replace engine components with oem so i need a complete oem rebuild kit. where is the cheapest yet guaranteed oem kit be purchased on those world wide webs?
    thanks in advance everyone!
  2. Nov 20, 2023 at 2:51 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Fantastic11 and 1997tacomav6 like this.
  3. Nov 20, 2023 at 2:57 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    toyota sells a full gasket kit. everything else is individual. if youre not having issues i dont really see a need to preemptively rebuild it. my 95 is at 486k on the original 3.4. runs and sounds just fine
  4. Nov 20, 2023 at 5:52 PM
    O'Silver_Taco
    MD
    I suppose if you've owned it all its life....and changed the oil religiously every 5K.....uses no oil...
    then you might roll the dice and just replace/rebuild the heads....
    still a gamble tho...
    Its the bottom two oil rings that wear out.....so a compression test may not tell the whole story....
    would need to endoscope it and check the cylinder walls....
    https://www.bing.com/images/search?q=Cylinder+Scoring&form=IRBPRS&first=1
