OEM Parts Sticky (autoparts.toyota.com)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bigoldbeef, Sep 2, 2023.
  1. Sep 2, 2023 at 4:09 PM
    bigoldbeef
    bigoldbeef [OP] Well-Known Member
    18 DCSB OR MT, 22 DCSB OR AUTO
    As these trucks age and parts begin to fail, you can purchase OEM replacements at steep discounts through the autoparts.toyota.com website.
    Only negative is Toyotas website is not user friendly at all. The diagrams are trash and so are the descriptions.
    I thought I would create an OEM parts list for 3rd gens that I can keep updated so people can save the headache of trying to locate the OEM part numbers on their own & avoid risking it with junk from the local auto parts store.
    Everything I have listed is for an 18 3.5L Offroad 4x4 with a manual transmission.
    Engine/Exhaust
    - 04152YZZA1 Engine Oil Filter Element
    - 87139YZZ09 Cabin Air Filter
    - 178010P100 Engine Air Filter
    - 270600P350 Alternator
    - 9091901263 Spark Plug
    - 122040P020 PCV Valve
    - 90919A2008 Direct Ignition Coil
    - 2810031160 Starter
    - 1610009720 Water Pump
    - 90126A0019 BOLT - exhaust manifold stud
    - 171730P040 Exhaust Manifold Gasket
    - 171500P320 Catalytic Converter with Integrated Exhaust Manifold (Left)
    - 171400P320 Catalytic Converter with Integrated Exhaust Manifold (Right)
    - 90917A6005 Exhaust GASKET
    - 174510D060 GASKET, EXHAUST PIPE
    - 90917A6001 GASKET, Exhaust Pipe
    - 9008043036 GASKET, EXHAUST PIPE
    Transmission/Driveline
    - 3723009080 Drive Shaft Center Support Bearing
    - 423450K290 CLAMP, REAR PROPELLER SHAFT BOOT
    Brakes
    - 43512-04052 Front Rotor
    - 04947-0C010 Fitting Kit, Disc Brake, FR
    - 04465-04090 Pad Kit, Disc Brake L/Fitting Parts, FR
    - 04945-0C030 Shim Kit, Anti Squeal, FR Disc Brake
    - 90240-06158 Pin, W/Hole
    - 47743-04093 Clip, Pin Hold
    - 04495-04010 Shoe Assy
    - 04942-04010 Spring Kit, RR Drum Brake
    - 42431-04061 Drum, Brake
    Body
    - 641890C011 Bed Mounting Bolt
    - PT58035050SB Bed Mat, 5' Bed
    - PT39235100 BedStep
    - PT0766020002 Black Lug Nuts (6)
    If anyone's bought stuff before they can post below and I will periodically update the list. Also specify what engine/driveline your truck has.
  2. Sep 2, 2023 at 5:15 PM
    Plaintaco
    Plaintaco Well-Known Member
    Houston, TX
    2023 Access Cab TRD Off Road
    This is a great resource. Thanks!
  3. Sep 4, 2023 at 7:44 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    @bigoldbeef
    Thanks for the list. If I find anything not on here I’ll pass it on.
    How many miles are you at currently?
  4. Sep 4, 2023 at 7:58 PM
    bcmbcmbcm
    bcmbcmbcm Well-Known Member
    Brett
    22 Barcelona Red TRDOR 6MT worth the wait !! Hang in there !!
    Good resource. Yes the exploded diagrams and search is not friendly. I keep an excel list-here is what I have saved:
    Tacoma 90010-23059 Knob/RAV4
    Tacoma 90430-12031 Drain Plug washer
    Tacoma PTR60-35160-HW Hardware for TRD Skid plate
    Tacoma 75872-04900 Flare LF Flare
    Tacoma 12180-0H012 Oil cap marked 5W30
    Tacoma 4321104060 Steering Knuckle, Right
    Tacoma 4321204050 Steering Knuckle, Left
    Tacoma 75873-04900 RR Flare
    Tacoma 75874-04900 LR Flare
    Tacoma 75427-04030 Tacoma fender emblem passenger
    Tacoma 75427-04010 Tacoma fender emblem driver
    Tacoma 89785-00179 Dumb Key
    Tacoma 55441-26090 Japanese Coin holder
    Tacoma 7544421220 2000 4Runner Emblem
    TRD Pro center cap (mid style-forgot year range) 94390639
    TRD Pro wheel (mid style-forgot year range) 94390656
    Tacoma 6920604030C0 Black door handle Left/Driver front and rear
    Tacoma6920504030C0 Black door handle Right/Passenger front and rear
    Tacoma PT58035050SB Bed Mat-Short Bed
    Chew likes this.
  5. Sep 4, 2023 at 8:12 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    I keep a list in my notes app on my phone. I’ll share what I’ve collected. The only ones I’m not sure about are the fender flares. I got the part numbers from someone else on here but once I searched them on the sites, some of it didn’t seem right. For example, the offroad ones that are supposed to be finished in the box and ready to bolt on, didn’t seem that way once I searched their numbers.
    Once I see my info has been added to the first post, I’ll delete this one so as to remove clutter. These types of threads start to get confusing if too many cooks are in the kitchen.
    Engine
    90430-12031 - Oil drain plug gasket
    04152-YZZA1 - Oil filter
    17801-0P100 - Air filter
    90919-01263 - Spark plug
    90919-A2008 - Coil pack
    12204-0P020 - PCV valve
    28100-31160 - Starter motor
    16100-09720 - Water pump
    17111-0P060 - Intake manifold (lower)
    17177-0P030 - Intake manifold (lower) gaskets
    17190-0P101 - Intake manifold (upper - "tank assembly")
    17176-31130 - Intake manifold (upper - "surge tank") gasket
    Automatic Transmission
    35010-04110-84 - Reman. automatic transmission - AC60E (RWD)
    35010-04120-84 - Reman. automatic transmission - AC60F (4WD)
    35178-30010 - Drain plug gasket
    35330-04010 - Strainer/Filter
    Manual Transmission
    33030-04070 - Manual transmission assembly - RC62F (4WD)
    90430-A0003 - Fill AND drain plug gasket
    90431-18033 - Fill plug
    Transfer Case
    36110-04010 - Transfer case assembly - VF2CM (MT)
    36110-04030 - Transfer case assembly - VF2CM (AT)
    Front Differential (IFS 8" Clamshell)
    12157-10010 - Fill plug gasket
    90341-18032 - Fill plug
    90430-24017 - Drain plug gasket
    90341-24014 - Drain plug
    90341-14013 - Temp sensor block-off plug
    90430-14011 - Temp sensor block-off gasket
    90311-47027 - CV axle shaft seal - left
    90311-47026 - CV axle shaft seal - right
    90311-41015 - Pinion seal
    90366-30067 - Pinion bearing - outer
    90366-35087 - Pinion bearing - inner
    90366-53004 - Side/Carrier bearings
    Rear Differential (BD22A/BD22AN 8.75" - TRD OR/PRO & MT)
    90341-A0002 - Fill plug
    12157-10010 - Drain plug gasket
    90341-18057 - Drain plug
    42181-KK010 - 3rd Member gasket (BD22A/AN)
    90311-T0065 - Pinion seal
    82824-0K060 - Locker connector
    90366-T0062 - Pinion bearing - outer
    90366-T0065 - Pinion bearing - inner
    90366-T0068 - Side/Carrier bearing - left
    90366-T0071 - Side/Carrier bearing - right
    HVAC
    88508-04010 - Cabin air filter
    Body
    Fender Flares
    75871-04060 - Right front fender flare (OR/PRO)
    75872-04060 - Left front fender flare (OR/PRO)
    75873-04090 - Right rear fender flare (OR/PRO)
    75874-04090 - Left rear fender flare (OR/PRO)
    75871-04900 - Right front fender flare (Sport/Painted)
    75872-04900 - Left front fender flare (Sport/Painted)
    75872-04900 - Right rear fender flare (Sport/Painted)
    75874-04900 - Left rear fender flare (Sport/Painted)
    Fender Support Brackets (by Headlights)
    52115-04070 - Right
    52116-04070 - Left
    Misc Body Hardware
    53911-04210 - Front bumper valance
    90189-06227 - Green speaker bolt grommets
    90189-06010 - Tailgate cover screw grommets (Quantity 15)
    Wipers
    85222-04040 - Left blade
    85212-0E050 - Right blade
    85214-04030 - Left refill/insert
    85214-0E140 - Right refill/insert
    Mirrors
    67771-58010 - Mirror trim panel clips (white)
    87915-04070-B1 - (MGM) - Right painted mirror cap
    87945-04070-B1 - (MGM) - Left painted mirror cap
    Wheels & Wheel Hardware
    90942-01033 - 1-Piece chrome lug nuts
    90084 - 94001Stock 2-piece chrome lug nuts
    PT076-60200-02 - Black lug nuts - (quantity of 6)
    PT276-35200-02 - Black wheel lock set
    42607-04020 - TPMS sensors
    04423-0E010 - TPMS sensor service kit
    Tail Lights
    There are 8 types of tail lights from Toyota for the 2016-2020 Tacoma. 81550 (x=5) for RH, 81560 (x=6) for LH.
    815x0-04170 - 2016-2017 SR, SR5
    815x0-04180 - 2016-2017 TRD Sport, TRD Off-Road
    815x0-04181 - 2018-2020 SR, SR5; 2018-2019 TRD Sport, TRD Off-Road
    815x0-04190 - 2016-2019 Limited
    815x0-04200 - 2017-2019 TRD Pro
    815x0-04210 - 2020 TRD Sport, TRD Off-Road
    815x0-04220 - 2020 Limited
    815x0-04230 - 2020 TRD Pro
    Gaper, bigoldbeef[OP] and Chew like this.
  6. Sep 4, 2023 at 8:17 PM
    bigoldbeef
    345k
  7. Sep 4, 2023 at 8:20 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    great lists guys!
    Sticky this please
