OEM parts for oil change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DCJeeper, Jan 25, 2019.
  1. Jan 25, 2019 at 10:18 AM
    DCJeeper
    DCJeeper [OP] Well-Known Member
    I’m ready for my first oil change and bought some tools. Wonder where to buy oil filter, oil drain plug gasket, synthetic oil and other related parts? Mobil 1 oil seems reliable. I looked the parts numbers online. Amazon sells almost everything, but some reviews mentioned that they are not genuine OEM parts even the descriptions say so. Is dealership the only place we can trust?
  2. Jan 25, 2019 at 10:33 AM
    DCJeeper
    doublethebass likes this.
  3. Jan 25, 2019 at 10:37 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Usually when I get filters on Amazon they come with drain plug gaskets.
    BSFord, payrow, Bagman and 1 other person like this.
  4. Jan 25, 2019 at 1:02 PM
    greg8765
    greg8765 Grant
    Grant
    Utah
    2023 Tacoma TRD Off-Road DCSB
    Rhino Wheels, 3 Inch Tuff Country Lift, Smart Cap, Tint, Pop & Lock, Door Sill Decals, Rooftop Tent
    I bought all my stuff on Amazon... i never had anything come that wasn't OEM
  5. Jan 25, 2019 at 3:04 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
  6. Jan 25, 2019 at 3:05 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    The ones I bought on Amazon were OEM.
    shakerhood likes this.
  7. Jan 25, 2019 at 3:13 PM
    DCJeeper
  8. Jan 25, 2019 at 6:15 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    i would click on the link and ask question, is the wrench metal ? if it is metal should be good to go.
    the filter is on tight and when unscrewing it is hard to turn for about 3 rotations=normal.
  9. Jan 25, 2019 at 9:40 PM
    Bryanccfshr
    Bryanccfshr Well-Known Member
    2018 Trd OR , 2018 TRD Pro 4Runner
    I have a cast aluminum filter adapter I bought at autozone a few years ago. It works fine.. sometimes I need to tap on it to get it to come off the plastic canister. I normally buy my filters and gaskets off Amazon. I have been getting better proces on engie. Oil off Walmart.com.
  10. Jan 25, 2019 at 10:26 PM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    This forged aluminum filter wrench seems to work well for $13. Https://www.amazon.com/dp/B01M7RWORF/ref=cm_sw_r_cp_apa_i_8R.sCb3CQ06ZG
    Filter and gasket are around $5 from dealer. Pennzoil has $10 rebate for 5qt oil jugs which makes them less than $15.
    All makes for a cheap oil change.
    One thing to keep in mind... The small plastic drain that snaps into the oil filter can make quite a mess. Consider setting it into an old glass bottle (wine, etc) and use the bottle to shove it into the filter housing...oil will drain into the bottle. Haven't tried it yet but the video online looked slick.
  11. Jan 25, 2019 at 11:30 PM
    ECU4422
    ECU4422 Well-Known Member
    Robocon
    Nissan Frontier
    I just bought parts at Amazon to change oil a few days ago. I almost went with this one stop piece, but looking further it seems the filter tool is cheaply made -someone posted pics of it broken and twisted at ratchet being it is not forged. I bought the $24 tool Motivx filter tool itself as it seemed like a quality piece and many good reviews. Will see when delivered. I'm only doing the first one soon being I'm on the 4 year dealer oil change plan so it will be used more after that. Who knows, I may not like the dealer oil change experience and just do them myself
  12. Jan 26, 2019 at 1:33 AM
    jtifm
    jtifm Well-Known Member
    2017 TRDORDCSB
    Good f'n idea! Was a PITA last weekend.
  13. Jan 26, 2019 at 10:57 AM
    DCJeeper
    I’ve seen Mobil 1’s ow-20 5 qt sells for $40 in Advance Auto Parts. How can you find the oil so cheap?
  14. Jan 26, 2019 at 10:58 AM
    DCJeeper
    Looks like Motivx is the best choice based on reviews
  15. Jan 26, 2019 at 11:03 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Walmart has Mobil 1 0w-20 5 qt for $27
    Vbpiper likes this.
  16. Jan 26, 2019 at 11:12 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Just a small point of order on this whole "OEM" thing... Toyota doesn't make oil, oil filters, or a lot of other "OEM" components. They buy large quantities from Manufacturer 'X', likely, People's Filter Manufacturing Works, #3, Beijing. The only thing that is close to "OEM" is the custom packaging which says, "Toyota" vice "Subaru", "Ford", or "Acme Auto-parts". The filters will meet a series of specifications produced by Toyota engineers, but so will a hundred other brands. In all likelihood, if you bought ten filters on Amazon, a good percentage of them would have come from the same factory as the "Genuine Toyota" part. In short, for general consumables such as oil, filters, etc, anything that meets the specifications and comes from a reputable name (Fram, Mobil, etc) will be absolutely fine, and likely cheaper.
  17. Jan 26, 2019 at 11:16 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Vbpiper likes this.
  18. Jan 26, 2019 at 11:19 AM
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    Good find! Just ordered. I have had both of my free oil changes completed already and I’m creeping up on 30k and will be doing it myself. Thanks!
  19. Jan 26, 2019 at 11:20 AM
    shakerhood
    Southern Ohio
    Walmart usually has it for $24 and the Mobil 1 offers $12 rebates a couple times a year, I snag a couple and always have extra on hand.
  20. Jan 26, 2019 at 11:42 AM
    DTaco18
    Pennzoil Platinum is usually around $23/ 5qt at walmart, then you upload receipt to their website for $10 rebate. Mobil 1 will probably have a rebate sometime this year too.
    Edit: Pennzoil rebate link:
    https://www.pennzoil.com/en_us/prom...otion-14.html#iframe=L2RpeS9TcHJpbmdNSVIxOS8=
