OEM Oil plug gasket stuck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cornwall325, Jan 16, 2010.
  1. Jan 16, 2010 at 8:39 AM
    cornwall325
    cornwall325 [OP] Toyota newbie...
    Jonathan
    Virginia
    09' D.C. TRD Sport 4x4
    Seatbelt chime turned off, Toyota bedmat, Wet Okoles, stock other than that.
    Ok guys so I'm in the process of changing my oil in my new truck and forgot to get some new gaskets for the drain plug. When I took the bolt out the plug came out but the gasket is still stuck to the oil pan. Since I don't have any and it's a Saturday what do you guys recommend I do now? I thought about picking it off there but I didn't know if it would rip or not. Maybe Fire will see this thread and have a couple spare gaskets since he's nearby. :eek:
    thanks everyone
  2. Jan 16, 2010 at 8:51 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    I wouldn't worry bout re-using it for just this one time. Just check for leaks periodically, and put a new gasket on at your next oil change.
    Mine didn't even have a gasket from the factory!
  3. Jan 16, 2010 at 8:53 AM
    cornwall325
    Jonathan
    Virginia
    Should I attempt to remove it from the oil pan itself though since I don't have any extras? I'm going to a dinner today for my sister's b-day and the drive is an hour away. I just don't want to run into any problems with that kind of a drive and my 3 month old in the backseat.
  4. Jan 16, 2010 at 8:54 AM
    TexasTacoma37
    If it's stuck on there pretty good, I wouldn't mess with it. It will hold the seal on the pan side, so then all you have to worry about is on the drain plug side. If you remove it an re-use it, then you need to worry about sealing on both sides of the washer.
    Have you gotten the factory filter off yet? That's a whole other adventure.
  5. Jan 16, 2010 at 8:56 AM
    cornwall325
    Jonathan
    Virginia
    It's definitely stuck on there good. I tried to get it to come off with my thumbnail and it wouldn't budge. I'm assuming since this is the first oil change on the truck (new truck) that the paint is what has sealed it up to the pan itself.
  6. Jan 16, 2010 at 8:57 AM
    MGRS
    MGRS Well-Known Member
    '20 Tundra OR
    I think you will be fine. I have something like 6 changes on my current gasket with no leaks (not recommended). As long as you don't have a quick lube place service your truck and mangle the thing, it does not deform that much.
  7. Jan 16, 2010 at 8:57 AM
    jcayce
    jcayce Well-Known Member
    Texas
    17 DCSBTRDOR4X4
    I had to take a razor blade to mine and carefully work it off. I don't see why leaving it on there would be a problem. My situation was different though, I replaced the plug with a Fumoto valve and a new gasket so I did not care about destroying the old gasket.
  8. Jan 16, 2010 at 8:59 AM
    TexasTacoma37
    Then I'd just put the plug back in and not worry about it. Worst case scenario you will have a tiny leak, nothing that would make any difference for weeks.
    I'm sure there are folks here that would say you don't ever need to replace the crush washer :rolleyes:. There used to be debates about that all over the subaru forums I was on.
  9. Jan 16, 2010 at 9:00 AM
    cornwall325
    Jonathan
    Virginia
    I'm glad I'm not the first one to have this problem. I was starting to feel like a moron there at first when it happened. I'm going to just leave it on there and get some from the Toyota dealership and replace it when I do my next oil change. Like previously stated I shouldn't have to worry about the pan side leaking I'll just have to check the plug side really good when I crank er' up.
  10. Jan 16, 2010 at 9:06 AM
    JKD
    JKD Well-Known Member
    Mine did that...I knocked it off, and part of the rubber coating tore a bit.
    I had to reuse it...no leak, thankfully, so I will just have to remember to pick up a few for the next oil change.
  11. Jan 16, 2010 at 9:14 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    I have used the same gasket through ten oil changes and not one drop has leaked. No seepage either.
  12. Jan 16, 2010 at 9:24 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    I change mine every other change. You should be fine.
  13. Jan 16, 2010 at 9:45 AM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Silverado Crew Cab Z71, 5.3 made from real Tornado's!
    A few additions to make me feel cool.
    I have to take a screwdriver to knock mine off. You could knock it off and clean it up but either way you will be fine using is again.
  14. Jan 16, 2010 at 9:51 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    It's ok to reuse this time but next time change it.
    To get it off just get a big flat head screw driver and chip/pry it off. should take 2 seconds
  15. Jan 16, 2010 at 10:35 AM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    I've never changed mine dont worry about it. When I buy a filter from toyota I tell the guy I don't need the gasket.
  16. Jan 18, 2010 at 9:07 AM
    roy826
    roy826 Well-Known Member
    Mississippi
    2010 Prerunner TRD Sport DC
    When I purchase my filters from the dealer the parts guy always throws a new washer in each filter box. No extra charge for that. Filters cost only (2) for $10 bucks.
  17. Jan 18, 2010 at 9:19 AM
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    haha...no kidding...i spent the better part of the afternoon getting mine
    off the first time...it's probably put on by robot at the factory.
    I should post a pix or two of the tool i had to invent.
    yea, i didnt notice a gasket either on my drain plug?...
    but i've not noted any leaks without one.
    just need to check it every now and then.
    PC
  18. Jan 18, 2010 at 9:36 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I've never changed mine, probably never will. Honestly, you don't even need a crush washer there it's just Toyota being paranoid. I've never, ever changed one of those out on any car I've had, and never had a leak.
  19. Jan 18, 2010 at 9:59 AM
    roy826
    Mississippi
    An S2000 and a Miata take a new aluminum washer every time and if you don't it will leak. I know 1st hand on both of those cars since my wife has had both. I can flip the used washer on the S2000 and get two oil changes out of it. My '02 Tacoma only had a new washer once in 125,000 miles and it never leaked. My '10 Tacoma washer was stuck on the 1st oil change. I whacked it with a flat head screwdriver and it popped right off.
