OEM muffler is NA
Discussion in '2nd Gen. Tacomas (2005-2015)' started by N919HJ, Jan 21, 2023.
  1. Jan 21, 2023 at 8:07 AM
    N919HJ
    N919HJ [OP] Well-Known Member
    Ohio
    2007 Double Cab TRD OR
    Why did Toyota decided to stop producing mufflers for our trucks? Anybody have any info on this? It blows my mind that I can’t get a OEM muffler for my 2nd Gen. There is still a ton of these trucks on the road.
  2. Jan 21, 2023 at 8:15 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    It doesn’t seem discontinued. Are you sure it’s not just on backorder?
    Jeff
  3. Jan 21, 2023 at 8:26 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    For something like a muffler, does OEM make a big difference? Or can you get some Dorman replacement?
  4. Jan 21, 2023 at 8:44 AM
    Squirrel1969
    Squirrel1969 Well-Known Member
    2006 Tacoma v6 at 4wd
    new 17" tacoma wheels with 265/70/17 meats, stock for now
    as long as the volume is similar it will work great. I learned this from a very trusted exhaust guy around here who was able to make this even better by tucking it for more clearance.
  5. Jan 21, 2023 at 9:09 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    From a sound and exhaust flow standpoint, aftermarket (Wagner, etc.) will probably be just fine. The big difference will be in how they're finished and that directly relates to how long they will last. Up here in the rust belt, it's not at all uncommon to get over 10 years and well over 100,000 miles out of an OEM system. Replace that with an aftermarket (steel) system and you won't get even half that. As for Dorman parts, don't even get me started.
  6. Jan 21, 2023 at 9:19 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The P/N 174300P010 is shown as "no longer available" on Toyota's web site, but you can still order it from many dealer web sites, for example:
    https://parts.lakelandtoyota.com/p/TOYOTA__/Exhaust-Muffler/3915886/174300P010.html
    https://parts.longotoyota.com/oem-parts/toyota-muffler-and-tail-pipe-174300p010
    https://toyotaparts.bochtoyotasouth...unner-fits-2005-2012-toyota-tacoma-174300p010
    (I'm assuming they have it available. Otherwise there's no point in offering a 20% off discount...)
    Is the piping rusted? If not, just buy an aftermarket stainless muffler and have it installed by an exhaust shop. Probably cheaper than paying $440 plus shipping.
    TRDSport10 likes this.
  7. Jan 21, 2023 at 10:14 AM
    N919HJ
    Ohio
  8. Jan 21, 2023 at 11:12 AM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    like others have said, if the muffler blows out, im just going to chop it off and go blow $40-$100 on a decent muffler and take a trip to the local exhaust shop to have them weld on a new muffler and ive been told now by a few friends that a 2.5in muffler slips over the oem piping fairly well
  9. Jan 21, 2023 at 12:20 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Just picked up a trd muffler/ tailpipe at a local dealer
  10. Jan 21, 2023 at 1:01 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Aftermarket does not last long in the rust belt. Walker is by far the worst.
    tacomataco2 likes this.
  11. Jan 21, 2023 at 1:36 PM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    TRD cat back
  12. Jul 26, 2023 at 7:00 AM
    tomrad
    tomrad Well-Known Member
    2008 Tacoma Access cab, automatic 4x4
    I'm also looking for either a 17430-0P010 or the TRD PT910-89061. Lots of places list them, but most say backordered or NLA. If anyone has either, new or like new used, please let me know. Thanks! I'm trying to avoid aftermarket (two or three year mufflers in the rust belt).
  13. Jul 26, 2023 at 8:33 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Curious as to why you don't want to go aftermarket? A quick internet search puts a TRD exhaust at around 350 to 950$ depending on where you get it from and if new or used. Or you could go the route of one of many aftermarket mufflers for example and pay an exhaust shop to bend and weld you up something comparable for the low end of that spectrum. I think I spent about 100$ on top of the muffler (and resonator) on the install at the shop that welded up mine. It was a complete assembly from the Y-pipe back. I didn't spring for an exhaust tip since my exhaust is turned down over the rear axle.
    -J
  14. Jul 26, 2023 at 9:04 AM
    tomrad
    Why? Well, I have had factory exhausts last 15-20 years. Walker, Maremont, AP….rust in just a few years. Never had luck with aftermarket exhausts. Other than the Cherry Bombs I put on my Mustang 30 years ago.
    mattandkelly likes this.
  15. Jul 26, 2023 at 9:22 AM
    JustAddMud
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    I can see your point. I'm at about 11 years on this after market exhaust and the welds are showing signs of rust and pitting while the tubing is showing discoloration due to road debris but zero observed exfoliation in the metal. It must be said that my truck has only spent 1 winter north of the rust belt but I'm sure I'd be having similar results as you had if it spent more time in the salt. When it does come time to replace my exhaust, I'll be sure to size the intake and exhaust of my resonator and muffler so that I don't have additional weld seams due to the step-up and step-downs the shop had to use.
    -J
  16. Jul 26, 2023 at 9:48 AM
    tomrad
    Thanks for the reply. My truck spent its early life in Pennsylvania and now Maryland (Maryland uses salt and magnesium chloride on the roads).
    I had an 84 F250 years ago that got a new Maremont muffler every year. But my 99 F150 original muffler lasted until just a few years ago, about 20 years. Stainless steel oem exhaust.
    Around here, stainless is the way to go, and oem.
    Trust me, I hate the thought of spending almost $500 on a muffler and tailpipe but I hate replacing them every year or two even more.
  17. Jul 26, 2023 at 12:30 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Facts! Also for folks that do not want a weird sounding exhaust, OEM does a great job of muffling out unwanted exhaust note.
    GilbertOz likes this.
  18. Jul 26, 2023 at 12:39 PM
    JustAddMud
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    I scooped up one of these to keep the rasp under control.
    -J
  19. Jul 26, 2023 at 5:13 PM
    TacoTuesday1
    FL
  20. Aug 17, 2023 at 3:51 AM
    N919HJ
    Ohio
    I just got lucky and got one at my local dealer. It is so quiet now, I had no idea that my truck was so loud. super easy install. The dealer said there are over one hundred on back order in the system.
