OEM Leaf Spring Lifespan
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AmethystTheTacoma, May 20, 2021.
  1. May 20, 2021 at 5:39 PM
    AmethystTheTacoma
    AmethystTheTacoma [OP] Member
    I recently changed out my entire suspension. The original OEM suspension had 80,000 miles on it and had the crappy TRD Sport shocks/struts. Essentially, the truck was riding like a covered wagon. Plus the leaf springs were rusted and a bit saggy.
    I installed basically brand new 2021 TRD Off-Road shocks, struts, and leaf springs that I got off of Facebook Marketplace for a few hundred bucks. I wanted an improved ride without paying $4,000 for the suspension I eventually plan on installing, and I definitely succeeded with that.
    ANYWAY, now that y'all know the context, I am curious how long everyone thinks these new OEM leaf springs might last me. I know the OEMs are notoriously weak-ish.
    They have a 2" add-a-leaf, and will soon be paired with the Archive Garage Hammer Hangers. Oh and I also have about 250 lbs of constant weight in the back because of the bed rack and rooftop tent.
    The truck is pretty exclusively driven on pavement and forest roads. Nothing too rough.
    I know I have bought myself A LITTLE bit of time before I need to upgrade to aftermarket leafs, but probably not that much time.
    My Tacoma is also a Double Cab LONG BED, so I know that changes the spring dynamics.
    So my question is, how long do y'all think I have before these new OEM leaf springs are toast? Given all of those variables.
  2. May 20, 2021 at 5:46 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    I had the OEM 4 leaf-TSB leaf pack last me less than a year after 1 camping trip with a bed full of fire wood effectively turned the leaf pack into a W-shape.
    Then the TSB came out for the OEM leaf pack replacement due to the potential to break a leaf and puncture the gas tank. I was more mindfull with this leaf pack and never loaded the bed with more than 800 lbs of stuff and that lasted me 2 years and 65k miles until I upgraded to an all-pro expo leaf pack.
    I think that pack would have lasted me 120k miles if I didn't upgrade. A good average is that the OEM leaf pack & OEM shocks will last 100k miles if not overloaded (which is really easy to overload) or 3 years on the OEM shocks b/c of loosing pressure over time if you're not a high mileage driver.
    Tacoma’20 likes this.
  3. May 20, 2021 at 5:47 PM
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    "toast" ? probably longer than you'll own the truck.
    but they'll usually start sagging/squeaking/riding kind of "poorly" in about the same amount of time as your old ones. I think 100k is about the usual time frame for that, depending on usage.
  4. May 20, 2021 at 5:49 PM
    AmethystTheTacoma
    That is some AWESOME input! Thanks so much for that information
    My hope is that I can at least wait to replace them until I do the full upgrade to the Dobinsons MRRs and leafs I want to eventually get.
  5. May 20, 2021 at 5:50 PM
    Bishop84
    Bishop84 Well-Known Member
    With constant weight I've seen them break around the 6 year mark. They usually start to sag around the 3 year mark with normal use.
    TnShooter likes this.
  6. May 20, 2021 at 5:52 PM
    AmethystTheTacoma
    That would definitely be ideal. If I can get some good use out of them over the next few years, that will be more than enough
  7. May 20, 2021 at 5:54 PM
    AmethystTheTacoma
    That sounds pretty close to what I was thinking too.
    That should be right about the time where I fully upgrade the suspension, so that would be just fine! Fingers crossed
  8. May 20, 2021 at 6:42 PM
    mikkydee
    mikkydee My Taco 2007 DCLB 4x4 Man Truck
    Doyle
    Florida
    2007 Silver DCLB Tacoma, 4X4, 4.0 Liter, 6" lift, 20" rims, 34" tires
    6" lift, 20 " inch rims, 34" tires, billet grill, aftermarket fender flares, custom rear bumper, DVd player with backup camera, all LED lights
    The OEM Springs are crap. I had mine replaced under the tsb recall 6 months ago. I thought it would help with the rear sag. It did not. That is with my helper spring on also.
  9. May 20, 2021 at 7:01 PM
    AmethystTheTacoma
    LOL sounds about right!
  10. May 22, 2021 at 6:40 AM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    I don’t know what it is about these trucks but to me 95% of the ones I see on the road look low in the rear.
  11. May 22, 2021 at 7:55 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    When I had my frame replaced 3 years ago they replaced my Wheeler's leaf packs with the OEM leafs without my consent.
    I had to dig my leaf packs out of the dealership scrap pile and take them home to replace them the right way.
    Yea, I drove home like that:mad:
    with air filled brake lines and an overfilled brake reservoir.
  12. May 23, 2021 at 12:12 AM
    TacoTuesday1
    FL
    Jesus
  13. May 23, 2021 at 7:29 AM
    TheDude94
    TheDude94 Basement Operator
    Mom's basement
    2008 TRD Sport 4x4
    Workin progress...
    210k on my odometer and I’m still rolling around on the factory leafs (replaced a couple years ago on a recall).
