OEM Gear Ratio Chart
Discussion in '1st Gen. Tacomas (1995-2004)' started by chris4x4, Mar 1, 2015.
  1. Mar 1, 2015 at 9:28 AM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The axle code for your rig can be found on the manufacture's sticker located on the driver's side door jamb as follows:
    First digit:
    • A = 7.5" ring gear
    • B = 8" ring gear
    Next two digits:
    • 01 = 3:42
    • 02 = 3:58
    • 03 = 4:10
    • 04 = 4:56
    • 05 = 3:15
    • 06 = 3:91
    • 07 = 4.30
    Last digit:
    • A = 2 Pinion, Open
    • B = 4 Pinion, Open
    • C = 2 Pinion OEM Limited Slip
    some '98-00 models have shown a BO code of "???" on the door plate; so far this turns out to be a 3.91 gear ratio, at least for the 5sp. RZN171L-CRPDKAB with factory 31s/265s should be 4.56 with the AT.
    Edit by Ed Quinones on 10-7-05: I used to own a 99 Prerunner ext cab 2.7L with auto tranny and gear code of B07A. It came from the factory with a 4.56 gear ratio.
  2. Mar 1, 2015 at 11:10 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Good info there! :thumbsup:
    HondaGM likes this.
  3. Mar 1, 2015 at 11:28 PM
    neegdogdig
    neegdogdig Untrained with bad experiences go go go!
    3rd Gen DC V6
    My 2002 2.7L taco xcab was packed with 4:20 gear ratio from the factory but i swapped mine with 5:29. Sweet mall crawl. Good info.
  4. Mar 26, 2015 at 1:56 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I noticed that this was posted on the 1st gen tacomas wall.
    Would this also apply to second gens?
    What about 4runners, FJ cruisers and what not?
    Looking to start a 4runner build soon.
  5. Mar 26, 2015 at 3:00 PM
    roehoe72
    roehoe72 Well-Known Member
    Dan
    Vacaville, CA
    04 dc prerunner v6 trd
    sketch-1427407054212.jpgI take it it is these numbers circled in red?
  6. Mar 26, 2015 at 3:02 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Yup
    motolife313 and straightawaykid like this.
  7. Mar 26, 2015 at 3:06 PM
    roehoe72
    Dan
    Vacaville, CA
  8. Mar 27, 2015 at 11:57 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Only applies to first gens.
  9. Mar 30, 2015 at 2:27 PM
    rphass17
    rphass17 Well-Known Member
    Ryne
    NE Wisconsin
    03 Tacoma DC TRD
    Deckplate NGK plugs & wires Grey Wire mod Anti door dinger mod
    why would my 03 dcsb have a 4:10 compared to a buddys 96 AT ext cab with 4:56s ?
  10. Mar 30, 2015 at 2:28 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Does his truck has the 4 cylinder?
  11. Apr 7, 2015 at 11:22 AM
    rphass17
    Ryne
    NE Wisconsin
    03 Tacoma DC TRD
    yes
  12. Apr 7, 2015 at 12:16 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    Because an engineer determined a 4.56 gear ratio would work better with a 2.7 automatic and that 4.10 would be better suited to a V6 automatic?
  13. Apr 28, 2015 at 12:00 PM
    beardawg
    beardawg Member
    My 95 has 3.58's my step dads has 4.10's. both are 2.7 4wd reg cab 5spds.
  14. May 25, 2015 at 11:13 PM
    95babybluetaco
    95babybluetaco Active Member
    Joe
    Beavercreek, Oregon
    1995 Toyota Tacoma 4x4 3.4
    18 inch Magnaflow muffler 31" BFG KO2's
    Whats the difference between a two and four pinion setup?
  15. May 26, 2015 at 6:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The amount of pinions in the planetary set. one has 2, the other has 4. Most all rear diffs us a 2 pinion set up.
  16. May 26, 2015 at 10:14 PM
    95babybluetaco
    Joe
    Beavercreek, Oregon
    Where is the planetary set located within the differential? I know there is a planetary gear set in the transfer case but am not aware of one in the diffs. Are you referring to the number of spider gears?
  17. May 26, 2015 at 10:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  18. Jul 16, 2015 at 7:30 AM
    beardawg
    beardawg Member
    If I wanted to put 4:10's in my truck would anything have to be done to the speedometer (show correct speed)? I assume not, but I wasn't sure. I hate these 3.58's truck just feels gutless.
  19. Jul 17, 2015 at 2:15 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    You will have to change the speedometer drive gear in the transfer case if you change your differential ratios and keep the same tire size.
  20. Jul 21, 2015 at 11:04 AM
    MotoMoose68
    MotoMoose68 Well-Known Member
    Ed
    Southwestern Colorado
    2014 Tacoma TRD Sport
    Strut Spacer and block lift, w/33" tires on custom wheels.
    The chart seems to correlate with the code on my door jamb label. Mine reads A/TM: A04C / A750F. If I use the part in bold, it reads 7.5" diff., with 4.56 gears and Limited Slip. I looked elsewhere on the internet and couldn't find anything different, or specific to 2nd Gen trucks.
    LamzTaco likes this.
