OEM front coil spring musings…
Discussion in '1st Gen. Tacomas (1995-2004)' started by abauer10.beachside, Feb 7, 2024.
  1. Feb 7, 2024 at 11:45 AM
    abauer10.beachside
    abauer10.beachside [OP] Well-Known Member
    2004 Tacoma prerunner TRD off-road double cab
    N/A
    I was wondering if anyone knows if it would be reasonable to use a set of front coil springs from a newer gen Tacoma on a first gen prerunner. I have an 04 prerunner 3.4l v6 automatic 2wd w/ the trd off road package and both of my OEM coil springs have the paint flaking off on the bottom couple coils and a good bit of rust eating its way into the coils…. From what I can find, both Toyota and moog no longer have the stock coils for sale. I was wondering if anyone had tried using a set of coils of a newer gen Tacoma?? In SoCal I see a metric butfuckton of brand new stock suspension components being sold by crazy people who probably rarely go off road but felt it necessary to pull their stock suspension at 30k miles and dump $3k worth of aftermarket suspension into their truck. I think I can score a nice set of newer coils for very reasonable costs, I’m just wondering if anyone has tried this or has any opinions on if it would work ok… At worst I will just roll the dice and give it a go, but any advice would be appreciated!
  2. Feb 7, 2024 at 11:58 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    If you are talking about coils from a 3rd gen Tacoma, they would be too long for a 1st gen.
  3. Feb 7, 2024 at 12:28 PM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    I have some oem coils from my previous 03 tacoma TRD laying around in good condition. If you are in California you can have them.
  4. Feb 7, 2024 at 12:52 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    rocknbil likes this.
  5. Feb 7, 2024 at 1:59 PM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    Not sure where you got that info, but SuspensionLifts sells moog 81104's which are about as close to stock as you'll get. After it settled in I gained 1" compared to my OEM originals.
    Well he did say stock . . . the 4600's are closer to stock. For the OP the difference is the 5100's are adjustable. Well that and the price LOL
    If you're considering those might as well get the whole set.
    Edit: you got me curious, based on info from the Moog page it says the correct coilover number is 81102, not 81104. It may have changed, did mine last summer. SuspensionLifts assembles them and are pretty responsive, you can email them.
  6. Feb 7, 2024 at 2:06 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    It's more likely that you gained 1" over the sagged state of the springs, than 1" of lift from "factory height". IE, your oem springs had sagged 1" in 20 years.
    mechanicjon and rocknbil[QUOTED] like this.
  7. Feb 14, 2024 at 9:24 AM
    abauer10.beachside
    N/A
    I am in CA! I’m in the SoCal area, north OC.
  8. Feb 14, 2024 at 9:25 AM
    abauer10.beachside
    N/A
  9. Feb 14, 2024 at 9:29 AM
    abauer10.beachside
    N/A
    I’m also not afraid of spring compressors… I have used them to change the shocks/struts in a handful of different vehicles. Frankly It is a bit confusing why people are so scared of using the spring compressors….. you just have to be careful and pay attention to what you are doing. Personally I think it is imperative to use an impact wrench even though the spring compressor instructions say not to. Because trying to tighten the screw with a ratchet will try and pull the compressor to the side and that is no good. Just little short burst on alternating sides with the impact until the top hat is free has worked just fine for me!
  10. Feb 14, 2024 at 9:36 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Have you seen people do things? People are bad at stuff. Especially random people on the internet. It's impossible to determine an individuals ability or general mechanical knowledge in a forum. :notsure:
    The "just rolled in" or "customer states" video series are great examples of people doing stuff badly.
    Kevins60 likes this.
  11. Feb 14, 2024 at 10:43 AM
    abauer10.beachside
    N/A
    Fair enough…. To be honest I probably qualified as one of those people 5-6 years ago…. But after a few bad experiences having repairs made to my vehicle and having both a place and a basic set of tool I took to the interwebs and pretty quickly found out that I can tackle pretty much any job. Only things I don’t do myself is tires and I don’t have the equipment to recover refrigerant for AC work, but I found a local shop who will recover the refrigerant for $50 and then they will recharge the system for $150 - the $50 paid for recovery. He used to put back what ever he took out for free and just charge for the missing amount but times have changed and I can’t say I blame him. I learned everything from awesome forums like this one, YouTube, and FSM if I can find one for cheap or DL it. I have also collected a considerable amount of tools because I am a firm believer in buying tools if it is not outrageously expensive and I think I may use it again. I’m sure I have saved a few thousand dollars just with my $140 harbor freight shop press and $100 worth of press accessories….
  12. Feb 15, 2024 at 11:44 AM
    mattyosh
    mattyosh Well-Known Member
    Oahu, HI
    02 TRD Prerunner; 96 SR5
    I’ve used 2nd gen Tacoma Sport springs on a first gen xtra cab (3.4 w/ 4x4) and got about a 2in lift over factory height. They were well used and had over 100k miles on them, but rode surprisingly well. A great option for the $20 spent.
  13. Feb 15, 2024 at 12:08 PM
    abauer10.beachside
    N/A
    interesting!! This is the type of info I was looking for! I have a double cab prerunner trd, it’s a RWD truck. I wonder what the weight difference is between an extended cab 4x4 and a double cab rwd…. :rolleyes: I recently replaced my shot out leaf springs with a set of the Dayton/husky/general springs HD springs and even with my camper shell it did lift the rear of the truck a little bit. I’m honestly not sure how much lift it is compared to the factory ride but it was a good 2.5in over the sagging OEM springs…. It made a huge improvement in the ride of the truck. It looks a little stink bug now so an inch or so might be just fine as it would level the truck out I think.
  14. Feb 15, 2024 at 12:17 PM
    abauer10.beachside
    N/A
    If you are somewhere in the southern half of CA I would be stoked to take those off your hands. I don’t mind paying you something for them either!
  15. Feb 15, 2024 at 1:29 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    This is extremely ill advised. Get the right parts for your truck. Cobbling suspension together makes you a danger to everyone on the road.
  16. Feb 16, 2024 at 4:01 PM
    abauer10.beachside
    N/A
    I fail to see how swapping out the coil springs with Toyota springs that are going to be very similar is going to cause any sort of hazardous conditions? It can’t be much different than all the folks running aftermarket lift springs…
  17. Feb 16, 2024 at 5:12 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Those aftermarket lift springs are actually spec'd for the correct weight of the truck. Even throwing the wrong weight springs on a Kings, say, 800# springs vs the normal 600-650#, is going to result in the suspension being VERY stiff, and cause traction and handling issues.
  18. Feb 19, 2024 at 4:46 PM
    abauer10.beachside
    N/A
    except the fact that many aftermarket parts are designed to fit a range of different vehicles…. For instance most of the aftermarket springs/shocks I have looked at just say 01-04 Tacoma…. But there is going to be a good bit of weight difference between a standard cab 2.7l RWD and say a double cab v6 4x4…. This would lead me to believe that the springs will work for a given range of weight applications, I am sure it’s not a huge weight range, but if I can find a set of springs off a comparable Tacoma as mine, or take it a step further and find out which model of later gen Tacoma is closest to mine in curb weight…. I don’t think it would be a problem. As long as the spring is not drastically taller…. I don’t want a bunch of lift, in fact I would be most pleased with <1”.
  19. Feb 19, 2024 at 6:09 PM
    Cricket-0
    Cricket-0 Well-Known Member
    https://www.mevotech.com/part//SMS81078
    Take a peak at these, I was in the same boat, after a lot of research it is what I went with. They are pretty popular in the 4 runner forums.
  20. Feb 19, 2024 at 7:11 PM
    abauer10.beachside
    N/A
    Cool! I will definitely check those out! The really frustrating part is that I can get the correct spring left side, the progressive rate spring for the off road package. It’s the RIght hand side spring that appears to be made out of unobtanium…
