OEM fog light wiring to aftermarket light assembly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by appstate, Apr 11, 2011.
  1. Apr 11, 2011 at 11:04 PM
    appstate
    appstate [OP] New Member
    North Carolina
    2010 TRD Off-Road Double-Cab
    ARB Bull Bar, Warn Winch
    Hello! I have a 2010 Toyota Tacoma and it had stock fog lights. I recently added an ARB bull bar and I want to be sure I'm doing the wiring correctly.
    This is the OEM fog light wiring. It has two wires going into that connector. One is green and the other is white/black. Green is negative/ground, right?
    This is the connections on the ARB fog light assembly. I know that white is positive and black is negative. I'm not sure why only the black wire has the clear seal on the end...
    My question is: what is the best way to connect my OEM fog light wiring to my ARB fog lights?
    Thank you! :)
  2. Aug 19, 2011 at 7:12 PM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    I'm dealing with the same situation right now. trying to wire my new fog lights on my Demello bumper to the OEM wiring.
    confused :confused:
  3. Aug 19, 2011 at 7:18 PM
    appstate
    North Carolina
    I just ended up sniping off the Toyota factory connectors and the fog light connectors and used heat shrink butt connectors. I haven't had any problems at all and it was easy.
  4. Aug 19, 2011 at 7:33 PM
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/70-17 KO2
    This worked for me as well...
  5. Apr 9, 2013 at 6:20 PM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    I am doing this right now for my All-Pro Apex bumper and a set of PIAAs. Is the green the ground? I cant find my voltmeter to check it.
  6. Apr 9, 2013 at 7:18 PM
    appstate
    North Carolina
    I believe the black/white was technically ground. As I recall, I tried both ways and it worked either way. Good luck!
  7. Apr 9, 2013 at 8:22 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    White/black is ground.
    Look at the connectors... one is male and the one with the cover is female. The other end of the harness will have the opposite set... the hot will have the clear cover so it does not short to the body when the light is unplugged.
  8. Apr 10, 2013 at 6:50 AM
    YOTA LOVER
    NH
    Thank you very much gentlemen! Normally I wouldn't care about polarity when installing a bulb, but the PIAA 530s are LED and I don't want to fry something.
    Spliced right into the stock wiring, soldered and heat shrunk for protection.
  9. Jun 26, 2015 at 6:24 PM
    Just Chill
    Just Chill #1 H8r
    Jon
    Colorado Springs
    '10 Sport
    Expedition One bumper, OME 2.5", Pelfreybilt rear bumper, Prinsu roof racks
    So this plug here will snap right into the OEM plug?
  10. Mar 4, 2016 at 1:31 PM
    Tako9
    Tako9 Well-Known Member
    Gatineau, Québec
    07 Trd offroad access cab SWB
    I confirm that the green wire of fogs is the positive and black/white wire is negative... I just finished installing my led lights withe fogs switch and wires.
    Jsevert2023 likes this.
  11. Dec 4, 2016 at 7:30 PM
    SpeedwayTaco160
    SpeedwayTaco160 Well-Known Member
    Killeen TX
    10 Sport SWB DCSB
    Subbed.
    what about the led blinkers on the bumper
  12. Dec 4, 2016 at 7:34 PM
    Tako9
    Gatineau, Québec
    Are you talking to me?
  13. Dec 4, 2016 at 7:36 PM
    SpeedwayTaco160
    Killeen TX
    10 Sport SWB DCSB
    Sure, if you have any advice for the led turn signals
  14. Dec 4, 2016 at 8:01 PM
    Tako9
    Gatineau, Québec
    Ok you mean the main lights or the fogs?
  15. Dec 4, 2016 at 8:03 PM
    SpeedwayTaco160
    Killeen TX
    10 Sport SWB DCSB
    I dont have my fog light or blinkers hooked up on my ARB. I have a deluxe bumper
  16. Dec 4, 2016 at 8:05 PM
    Tako9
    Gatineau, Québec
    Ok just tell me what you want to know...
  17. Dec 5, 2016 at 1:34 PM
    Dekay
    Dekay New Member
    David
    2013 DCSB TRD Sport
    Does anybody have radio interference when using the stock fog light wiring to hook up LED pods? I have radio interference when using my fogs but do not when using my light bar with it's own wiring harness.
  18. Dec 7, 2016 at 6:21 PM
    SpeedwayTaco160
    Killeen TX
    10 Sport SWB DCSB
