OEM brake pad question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aeroskynyrd, Oct 22, 2020.
  1. Oct 22, 2020 at 7:51 AM
    Aeroskynyrd
    Aeroskynyrd [OP] Active Member
    North Alabama
    2023 TRD OR MGM
    Changing front brakes on my 07 TRD off road. I have 1 A pad, 1 B, and 2 C’s. Does the A go on the drivers side (inside), B on the passenger inside, and the C’s on the outsides?
  2. Oct 22, 2020 at 8:27 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    Good Question.....pictures if you have a chance...
    I believe the wear indicator goes on the inside of the rotor on the front brakes. ....you should be able to match them up at you remove them.
  3. Oct 22, 2020 at 8:38 AM
    Aeroskynyrd
    North Alabama
    2023 TRD OR MGM
    The ones I took off had the wear indicators on outside but I seen/read where they are supposed to go on inside. Just trying to get a definite answer.
  4. Oct 22, 2020 at 8:48 AM
    IL Capo
    Sidney BC Canada
    MrFixit420 likes this.
  5. Oct 22, 2020 at 3:29 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    I believe if you look in the front brake replacement thread the “indicator” goes on the inside leading edge of the rotor ...
  6. Oct 22, 2020 at 3:30 PM
    igno1tus
    So it goes on the inside and down
  7. Oct 22, 2020 at 5:20 PM
    igno1tus
    In my notes I have it as
    Pad A is for the driver side inside (engine side)
    Pad B is for the passenger inside pad
    The C’s go on the outsides
  8. Oct 22, 2020 at 5:21 PM
    Aeroskynyrd
    North Alabama
    2023 TRD OR MGM
    You are correct. I had only taken off the driver side pads at time of post. When I took off the passenger side the indicator was on the inside unlike the driver side. And a Toyota dealership did the last brake job before I bought the truck. Lol. Anyway, I put them on the inside.
    igno1tus[QUOTED] likes this.
  9. Oct 22, 2020 at 5:23 PM
    igno1tus
    Yea but inside and which way ?
  10. Oct 22, 2020 at 5:27 PM
    Aeroskynyrd
    North Alabama
    2023 TRD OR MGM
    They can only go on one way if you put them on the inside. I can’t remember if the indicators were on the top or bottom, I’m thinking top though. Like you said, A on driver inside, B on passenger inside, C’s on the outside.
  11. Oct 22, 2020 at 5:29 PM
    igno1tus
    No I’m pretty sure inside and down
    (The leading edge of the rotor)
  12. Oct 22, 2020 at 5:31 PM
    igno1tus
  13. Oct 22, 2020 at 5:43 PM
    Aeroskynyrd
    North Alabama
    2023 TRD OR MGM
    Ok I misunderstood, they are inside and down.
  14. Oct 23, 2020 at 5:24 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Per the video, I do it a little differently. I lightly grease the hub areas that contact the new rotor. Not much, just enough to hopefully keep it from rusting to the hub. I also wipe the pins off, then lightly hit them with a Scotchbright pad, lightly grease, then reinsert.
  15. Oct 23, 2020 at 8:49 AM
    igno1tus
    You should just use new , they are only a couple bucks and the retaining clips also (they are like .25¢) That’s what I did anyway, used all new everything
    EdgemanVA[QUOTED] likes this.
