OEM battery replacement help...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by doublethebass, May 2, 2020.
Which battery to replace OEM TrueStart?
  1. AGM X2 - upgraded performance @ $320
    16 vote(s)
    30.2%
  2. Lead Acid Interstate - more of the same @ $115
    37 vote(s)
    69.8%
  1. May 2, 2020 at 3:15 PM
    doublethebass
    doublethebass [OP] aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I’m on the fence about whether or not to pull the trigger on the AGM X2 / Northstar 24F for ~$320 at Batteries Plus vs a Lead-Acid Interstate for ~$115 at Costco…
    I don’t mind spending the extra $200 for quality and peace of mind, but I can’t tell if it’d be wasted in this case.
    I've dug through TW quite a bit and narrowed it down to those two options. Not interested in Optima red or yellow tops (quality issues since moving to MX) and for the other big store brands are a couple bucks more than Costco for pretty much the same quality.
    Some background….
    I don't have any fo the big electric items on the truck (yet)....no winch, light bar, fridge, etc. I’ve never had the OEM TrueStart battery in my truck last a full 12mo. Every Jan since I’ve had the truck I’ve brought it back to the dealer and they have replaced it for free under warranty. The truck is weekend vehicle (drive a work vehicle during the week) and it gets well below 0F here in Minnesota in the winter. I’ve had the truck for 4 winters now I’m on my 3rd replacement. It’s a joke really. The only thing that’s ever saved me in a pinch is the $100 jump pack I keep in the glove box (and there have been several pinches).
    This thread by @crashnburn80 has a ton of great info on the AGM upgrade option but sent me down the rabbit hole...
    https://www.tacomaworld.com/threads/the-northstar-agm-battery-voltage-booster-upgrade.604478/
    If I’m reading this thread right, the 3rd Gen alternators don’t have a sufficiently high voltage output to maintain an AGM battery (14.0v-14.4v vs 14.4v-14.8v) and there’s no easy way to boost the 3rd Gen alternator voltage….if that’s the case, is the extra up front money for the AGM X2 wasted because the insufficient voltage will decrease it’s life prematurely?
    The OEM TrueStarts are rebranded Interstates, so I know going Costco means more of the same….but if I get lucky and get more than 2yrs out of one battery, I’m ahead….plus I’ve got the jump pack in a pinch?
    What do you guys think? Costco until there's a voltage boost trick for 3rd Gens? Or will the AGM last as long as it should in these trucks?
  2. May 2, 2020 at 3:18 PM
    tacomaccountant
    tacomaccountant Well-Known Member
    Florida
    2019 Metallic Grey SR5 4WD
    Following as I’ll be replacing my oem battery to accommodate a winch, compressor, and some other things eventually.
    doublethebass[OP] likes this.
  3. May 2, 2020 at 3:21 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Look into dual batteries.
  4. May 2, 2020 at 3:21 PM
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    So FWIW my battery on my 2017 crapped out already... and I replaced mine with a Northstar 27F. To keep with the factory look and basic system I purchased the battery tray from a 2nd Gen Tacoma with tow package (they came with a 27F). In my opinion if you’re gonna upgrade to a more substantial battery why not get a larger capacity one as well for a small amount of addition cost...
  5. May 2, 2020 at 3:22 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    If you don’t have any electronics to power just get a lead acid. Our alternators aren’t designed to charge AGM so you would need to install a Redarc or similar to manage battery power and charging. Again since you don’t have anything that requires battery power it would be wasted.
    I have all of that on the OEM battery and almost 4 years later it’s still fine.
  6. May 2, 2020 at 3:23 PM
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    If the truck sits during the week I would put a battery tender on it
  7. May 2, 2020 at 3:24 PM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Yeah the 27F is on the table too...
    edit: looks like for $5 it's got an extra half hour reserve capacity...
    YOTA 4X4[QUOTED] likes this.
  8. May 2, 2020 at 3:25 PM
    tacomaccountant
    Florida
    I have a dual battery setup planned down the road. I don’t currently have a ton of lights to run off the start battery. Only the compressor and winch from time to time while the vehicle is running. I have money to spend on lockers/armor/suspension now. I keep a lithium battery pack charged as a backup.
    I’m planning an upgrade to a camper shell down the road where I will dedicate a box to house an auxiliary battery or two. Just not needed or in the cards right now.
  9. May 2, 2020 at 3:26 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    EVERSTART
    PapaRee likes this.
  10. May 2, 2020 at 3:33 PM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    This sounds like a great plan. Cap is on my short list too.
  11. May 2, 2020 at 3:34 PM
    Foster Imposter
    Foster Imposter Well-Known Member
    Art
    Out in the woods, GA
    2018 PRO MT
    This is very good advice regardless of which type battery you decide on.
    I put the tender on mine every 2-3 weeks and let it stay overnight...my oem battery is still going strong!
  12. May 2, 2020 at 4:07 PM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I should also mention....the Batteries+ warranty is 5yrs on the X2 while Costco is 3yrs on the Interstate...
  13. May 2, 2020 at 5:50 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    If you jumpy to the end of that NorthStar thread, it sounds like OVTune will soon release an AGM charging update for 3rd Gen, which will programmatically adjust the charge voltage up vs the 2nd Gen solution of using a diode to boost charge voltage. If you do not adjust the charge voltage, you'll want to use a wall charger periodically for optimum battery health to avoid sulfation. Not doing either of these will decrease battery life, though that doesn't mean it wouldn't outlast your short lived lead acid batteries. AGMs should outlast lead acid (when maintained correctly) they have better resistance to vibration for off road, have greater power density and in the case of NorthStar can also deep cycle. But if you don't need one and don't want to deal with the charging headaches in 3rd Gen, there is nothing wrong with buying a quality lead acid battery.
  14. May 2, 2020 at 6:31 PM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I did see the bit about OVTune working on a 3rd Gen solution. That’ll be helpful for a lot of us
  15. May 2, 2020 at 6:35 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Go big or go home.
  16. May 2, 2020 at 6:41 PM
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Haha I usually live by those words but truck money is allowance money and it has to be rationed
  17. May 2, 2020 at 6:45 PM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Just get the lead acid battery. A well manufactured lead acid battery works fine if it's going back in the stock location.
    Also, bigger size batteries weigh more. More than one person has bent the radiator support by putting a giant battery in the stock location.
    JKU3000 and doublethebass[OP] like this.
  18. May 2, 2020 at 6:54 PM
    Woodrow F Call
    Colorful Colorado
    I need a new battery too. I'm on my 2nd stock battery. The Toyota batteries suck.
    That being said, most places are only offering AGM options. It must not be a big deal to under voltage charge an AGM as many posts on this site indicate.
    I still think my previous post is still valid though.
  19. May 2, 2020 at 7:40 PM
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    My 10/2015 stock battery just died and since I am am OVTune customer I just picked up an AGM. I am optimistic to have a a good run on this battery upgrade with the right software solution. Here's to improving stick crap! :thumbsup:
  20. May 2, 2020 at 7:42 PM
    hfjeff
    hfjeff Well-Known Member
    Frozen Tundra
    2021 Army Green Off Road
