Oedro or Tyger Nerf bars
Discussion in '3rd Gen. Tacomas (2016-2023)' started by buca, Aug 4, 2019.
Which steps would you buy?
  1. Oedro steps
  2. Tyger steps
Results are only viewable after voting.
  1. Aug 4, 2019 at 7:51 PM
    buca
    buca [OP] Member
    Peter
    Portland, OR
    2019 Cement Tacoma TRD Sport
    Feeling like I’m splitting hairs here but any recommendations to go with one over the other? They seem like pretty comparable construction and looks.
    Oedro is $200 on eBay. My concern is the bracket and lack of reviews.
    https://www.amazon.com/Compatible-2007-2018-Multi-layer-Slip-proof-Protection/dp/B07CCKWZMQ
    Tyger steps are slightly more expensive $289. Concern is the lame stars and logo on the step. I’ve seen some people cover it up with strips from Harbor Freight.
    https://www.amazon.com/Tyger-Auto-T...564973306&s=gateway&sprefix=tyger+step&sr=8-1
  2. Aug 4, 2019 at 8:18 PM
    Captain_Slow
    Captain_Slow Well-Known Member
    Are you just looking for the "look" of sliders? If so, sure... both will probably handle the weight of a human on them for a while. They're both likely made out of soviet era recycled chinesium that would rust/explode when they see a pebble, but again, if you're looking for nothing but slider like step.... why not?
    GillyLink, ancient11 and Chew like this.
  3. Aug 4, 2019 at 9:04 PM
    Steemax
    Steemax Well-Known Member
    SoCal
    2019 Cement TRD OR 4x4 DCSB
    I believe they are literally the same thing just branded differently. I've seen a few TW members get the Oedro without any complaints.
  4. Sep 4, 2019 at 7:05 PM
    z00mer
    z00mer Active Member
    Christopher
    2017 TRD Sport 4X4 DCSB
    A couple going on (virtual work in progress)
    The Tyger product has a better build quality, rave reviews, and great cs. Whereas Oedro seems to be hit/miss with their product (brackets don't always line up, protective coating flakes, terrible welds). Personally I'd apply my "$" towards better offerings.
  5. Sep 4, 2019 at 8:17 PM
    buca
    buca [OP] Member
    Peter
    Portland, OR
    Thanks for the feedback everyone.
    I ended up going with Tyger steps. Purchased through Amazon for $289. Packaging came slightly damaged although no damage to the actual steps. The hardware was missing and I had read a lot of complaints about that happening, so no real surprise there. I reached out to Tyger for new hardware and they shipped it out promptly without much hassle.
    @z00mer you’re right. The quality and build definitely exceeded my expectations. The looks are great too but the functionality just isn’t there. They’re really no help getting into the truck and as my wife keeps telling me they really just get in the way and make it more difficult for her. So after being on my truck for 3 weeks I’ll be taking them off and returning to amazon. Fortunately I saved all the packaging so it should be a fairly painless process.
    z00mer and shane100700 like this.
  6. Sep 5, 2019 at 5:57 AM
    z00mer
    Christopher
    The hardware was missing?
    Tyger is usually on spot with its orders. I had their "Blades" for about a week, but I found their placement to be just a tad annoying. My gf would constantly complain about her pant leg rubbing on them whenever entering or egressing (she's 5"9 btw).
    Honestly, I like the placement of the OEM side steps seem to be spot on, but as for the price...
  7. Sep 5, 2019 at 8:02 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    The Tyger steps are solid. They are clearly NOT rock sliders, but mine have still taken a lot of abuse, including thousands of rocks/pebbles pinging their undersides. No rust, powder coat is holding up spectacularly, they literally look like brand new nearly 3 years after I put them on... They are not cheap material as their price would suggest either, weighing in at 90 lbs for the set these are not chinesium that explode :)
    I don't rock slide (and I suspect many many folks WITH sliders, rarely see true rock crawling scenarios...), but I spend a fair amount of time on gravel, loose rock, and old logging roads and have certainly "tapped" the bottom of these several times with no damage to the steps nor my rocker panels where these attach. I'd never support the full weight of the truck on them given where they mount, but for what they are it was one of the best value mods I've done.
    My primary use for these is to have a wide, flat space to stand on when accessing gear on my Prinsu cabrac, and for my wife to be able to get into the truck easier. Yes, they sit a bit high for a step, but my wife uses them every time she gets into the truck and was thankful when I installed them.
  8. Sep 5, 2019 at 8:29 AM
    Cementing
    Cementing Well-Known Member
    2019 Tacoma TRDOR Cement
    I personally would avoid Tyger. I ordered those steps on Amazon. The rear mount on the driver side was off by probably a half inch(if you check a few of the other reviews it is the exact same problem that I had). I called them up and customer service said they would have a new pair sent out. Then the following morning they said the tech looked at the pictures and said it was right and I quote, "you can use a soft hammer to make small adjustment." I can obviously do that, but the point is they are designed for the truck and I don't want to spend the time hitting something with a hammer that should just work out of the box. Not to mention telling a customer they have a new set coming out in writing then to turn around and say I need to hit what I have with a hammer or return them to amazon is horrid customer service. I have since returned them to amazon and ordered Avid Off-Road frame bolt on sliders. Just remember you get what you pay for.
    CusterFan, z00mer and SIDELINER4 like this.
  9. Sep 5, 2019 at 8:46 AM
    ancient11
    ancient11 Well-Known Member
    robert
    tallahassee
    2019 4 cyl srsx ac
    I got the Carid (aps) aluminum steps. The box of brackets and bolts weighed more than the steps. So far they are ok..
  10. Sep 5, 2019 at 10:08 AM
    phdog
    phdog Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    I had the Tyger bars. Really nice, seemed solid. My only concern was they hung a bit low and was afraid I'd end up on a rock someday and damage something. Sold and got sliders. I'm not into hard core offroading or anything, but I do take it off road and sliders just make more sense.
    Drove this recently. Only a few light hits on the sliders but pretty sure the Tyger bars would have been a liability.
    ancient11 and slamson00 like this.
  11. Sep 5, 2019 at 10:39 AM
    SIDELINER4
    SIDELINER4 SO MOTE IT BE.
    Sgt. G
    Hanover, NH & Jacksonville, Fl.
    ***UPDATE*** Purchased the 2019 TRD PRO VOODOO. 2016 Tacoma TRD Sport 4x4
    *Moto Fab Lifts* Level Kit (3x2)(Comming soon)! Bed Mat. Hondo AR-15 Radio knobs. Weather Tech Rain guards. Diode Dynamics interior LED's.(Wish List), Center console divider. Keeper Gun Magnet. 2" hose clamp Tailgate mod (along with about half of the "Cheep/Free Mods").Oh, my favorite "mod" is the AJT DESIGN Key fobs! (will need two more Voodoo Blue).
    Tyger sucks!
    Sorry I got here late. So you ordered the tyger, the box was damaged and shipment missing all hardware? My experience with them was not heathy and worst of all they are not vet friendly. Enough said.
    Cementing likes this.
  12. Sep 5, 2019 at 10:57 AM
    TakoLoko12
    TakoLoko12 Well-Known Member
    Hello Sir, can you clarify what "Vet friendly" means? Seen those words a lot lately, just wondering what it means.
  13. Sep 5, 2019 at 11:29 AM
    Cementing
    He probably means not friends to military veterans?
  14. Oct 11, 2019 at 8:29 PM
    TrailRayted
    TrailRayted Well-Known Member
    Ray
    2008 Rugged Trail Tacoma
    What is "vet friendly"? My Tygers Rock!!!
  15. Oct 11, 2019 at 8:40 PM
    black_angus1
    black_angus1 Well-Known Member
    AZ
    2017 Inferno TRD Sport DCSB
    Why does this matter? How is this "worst of all"?
    z00mer and TrailRayted like this.
  16. Oct 11, 2019 at 8:44 PM
    FishnTx
    South East Texas
    ‘17 OR
    Neither
    Chew likes this.
  17. Oct 11, 2019 at 8:48 PM
    TrailRayted
    Ray
    Then beat it
  18. Oct 11, 2019 at 11:04 PM
    Lemmy68
    Lemmy68 Well-Known Member
    Emailed Oedro and they replied that it would not fit a 2019 Tacoma 4 door... They have me confused, below is the reply. Guess I’ll purchase my second choice, Rhino. Thought double cab/crew was the same vs access cab. Maybe lost in translation?
    Hello,
    It not work with 2019 Tacoma Sport 4 door crew cab.
    Only for Double Cab Only
    wi发件人: oEdRo <service@oedro.com>
    发送时间: 2019年10月10日 16:57
    收件人: oEdRo <info@oedro.com>
    主题: Contact Form
  19. Oct 12, 2019 at 1:42 AM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    heading into my 3rd winter in northeast pa. with my tyger steps, very little rust,heavy duty, previous steps were NFAB. they had large pieces of paint and rust falling off after 3 months, luckily i bought them from Amazon, and they refunded my money and told me to keep them.. NFAB was no help..
    i bought my tyger steps from amazon also,, FYI
    tryb101 likes this.
  20. Oct 12, 2019 at 5:06 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I'm ok with my Tygers, but I like the look of the Oedro's better. But neither will be as good as real Sliders.
