odometer reprogramming
Discussion in '2nd Gen. Tacomas (2005-2015)' started by oh6_taco, Apr 19, 2020.
  1. Apr 19, 2020 at 12:57 AM
    oh6_taco
    oh6_taco [OP] Member
    Southern California
    2013 Regular Cab, 2.7L, 5-spd
    none
    Hey guys,
    I recently did the LED swap/mod on my gauge cluster. It came out fantastic. However, I used a gauge cluster from a wrecked Tacoma. To my chagrin, the odometer displays the mileage on the wrecked truck, not mine.
    After a little digging, I learned that the odometer data is stored on an EEPROM w/in the cluster gauge circuit board. I assumed (incorrectly) that is was stored on the truck's ECU but it is not.
    Does anyone know of any resources on where I can get my digital odometer reprogrammed?
  2. Apr 19, 2020 at 3:44 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    If it’s in the eeprom then it can be changed by the dealership but....
    you need to install your old gauge and take them the new gauge. The old one needs to be installed so they can read it. They need to certify the true mileage before Installing and resetting the replacement gauge to your trucks true mileage. It is a crime for anyone else Other than a certified business to reset an odometer.
    SR-71A likes this.
  3. Apr 19, 2020 at 8:01 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    @Crosis would techstream work?
  4. Apr 19, 2020 at 8:35 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Here is some reading for you. I don't know if it is applicable or not, but it should be the same. There is a reason they make it a pain in the ass. The old style dial odometers were simple and easy to change. Don't ask me how I know this.
    https://www.toyotanation.com/threads/diy-odometer-reprogramming.782562/
    https://www.clublexus.com/forums/es-1st-to-4th-gen-1990-2006/740730-diy-odometer-reprogramming.html
    https://www.instructables.com/id/DIY-Odometer-Reprogramming/
  5. Apr 20, 2020 at 10:03 PM
    oh6_taco
    Southern California
    none
    Thank you guys for your replies, especially Jimmyh. I have reviewed those link before but I appreciate you taking the time to post them for me.
    I believe that I've located the EEPROM on the odometer circuit board. I'm going to attempt to de-solder it and swap it with the EEPROM from the original board. If anyone is interested, I'll post a picture and let you know if I was successful or not. Please let me know if you are interested.
  6. Apr 21, 2020 at 4:02 AM
    Crosis
    Dunedin Fl
    Interested to see if it’s possible even though illegal.
    jbaker1976 likes this.
  7. Apr 21, 2020 at 5:00 AM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Interested here also . . . keep us posted. Thanks.
  8. Apr 21, 2020 at 7:27 AM
    Muddinfun
    Muddinfun Well-Known Member
  9. Apr 21, 2020 at 7:36 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    The odometer actually has to be sent out to a company that verifies and certifies the correct mileage and it makes the changes, the dealer can not do it. In most states it’s illegal for you to tamper with the odometer in any way.
  10. Apr 21, 2020 at 10:01 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Please document with pictures! I would love to see it and a successful outcome.
    TireFire likes this.
  11. Apr 21, 2020 at 10:05 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    From the Odometer service link:
    Legal:
    Programming the odometer on a part to match the true mileage of the vehicle is legal, as long you are not misrepresenting the true mileage of the vehicle. Here are the U.S. Codes that you should search and read that will help you understand U.S. odometer laws regarding service and sale of vehicles:
    U.S. Code 49 U.S. Code § 32704. Service, repair, and replacement
    U.S. Code 49 U.S. Code § 32705. Disclosure requirements on transfer of motor vehicles
    Please read carefully and understand U.S. Code 49 U.S. Code § 32705. "Disclosure requirements on transfer of motor vehicles" to know your responsibilities when transferring a vehicle.
    Torspd likes this.
  12. Apr 21, 2020 at 10:05 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    interested
  13. Apr 21, 2020 at 10:53 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Wanna bet the fun police (aka mods) will nuke this thread?
  14. Apr 21, 2020 at 11:11 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    I'm pretty sure it is perfectly legal as long as you comply with the US Code listed below.
    https://www.law.cornell.edu/uscode/text/49/32704
    (a) Adjusting Mileage.—A person may service, repair, or replace an odometer of a motor vehicle if the mileage registered by the odometer remains the same as before the service, repair, or replacement. If the mileage cannot remain the same—
    (1)the person shall adjust the odometer to read zero; and
    (2)the owner of the vehicle or agent of the owner shall attach a written notice to the left door frame of the vehicle specifying the mileage before the service, repair, or replacement and the date of the service, repair, or replacement.
    (b) Removing or Altering Notice.—A person may not, with intent to defraud, remove or alter a notice attached to a motor vehicle as required by this section.
    https://www.law.cornell.edu/uscode/text/49/32705
    (1) Disclosure Requirements.—Under regulations prescribed by the Secretary of Transportation that include the way in which information is disclosed and retained under this section, a person transferring ownership of a motor vehicle shall give the transferee the following written disclosure:
    (A)Disclosure of the cumulative mileage registered on the odometer.
    (B)Disclosure that the actual mileage is unknown, if the transferor knows that the odometer reading is different from the number of miles the vehicle has actually traveled.
    (2) A person transferring ownership of a motor vehicle may not violate a regulation prescribed under this section or give a false statement to the transferee in making the disclosure required by such a regulation.
    (3)A person acquiring a motor vehicle for resale may not accept a written disclosure under this section unless it is complete.
    (4)(A)This subsection shall apply to all transfers of motor vehicles (unless otherwise exempted by the Secretary by regulation), except in the case of transfers of new motor vehicles from a vehicle manufacturer jointly to a dealer and a person engaged in the business of renting or leasing vehicles for a period of 30 days or less.
    (B) For purposes of subparagraph (A), the term “new motor vehicle” means any motor vehicle driven with no more than the limited use necessary in moving, transporting, or road testing such vehicle prior to delivery from the vehicle manufacturer to a dealer, but in no event shall the odometer reading of such vehicle exceed 300 miles.
    (5) The Secretary may exempt such classes or categories of vehicles as the Secretary deems appropriate from these requirements. Until such time as the Secretary amends or modifies the regulations set forth in 49 CFR 580.6, such regulations shall have full force and effect.
    Larzzzz likes this.
  15. Apr 21, 2020 at 11:53 AM
    Larzzzz
    Larry
    MA
    I could be wrong.... Wouldn't be the first time.
    I'm inclined to think @Jimmyh wedged the door open with his reply... :thumbsup:
    Jimmyh likes this.
  16. Apr 30, 2020 at 4:40 PM
    gotzskillz
    gotzskillz New Member
    Any update on this? Curious as I'm doing a cluster swap as well
  17. May 5, 2020 at 11:56 PM
    oh6_taco
    Southern California
    none
    Update: Success!
    Swapping the EEPROM from one board to another is tricky, even if you are experienced in soldering. Having access to a microscope was a big help for me too. In the future, I'm going to get a few tunnel soldering tips like this one* for removal of ICs.
    The EEPROM is an 8-pin IC (integrated circuit) whose pins are coated in some sort of blue colored coating. I'm still not sure what the blue stuff is; it dissolved in isopropyl alcohol and some gentle brushing w/ an acid brush. It's not a conformal coating (otherwise it wouldn't have just dissolved like that). I think that it's to indicate tampering/removal of various board components pertinent to mileage information. The same blue coating is also on the pins of the microcontroller and a relay array IC that are also on the circuit board.
    I swapped out the new EEPROM with the old and viola, my new cluster gauge displays the correct mileage reading! I don't remember the EEPROM part number off the top of my head but I have it written down somewhere. I'll update this post w/ that information when I can find it.
    * keep in mind that tunnel type soldering tips should be purchased based upon the footprint size of the IC (not the number of pins). I do not know the SOIC of the EEPROM in question.
    Torspd, SR-71A, Rocketball and 4 others like this.
  18. May 5, 2020 at 11:58 PM
    oh6_taco
    Southern California
    none
    I forgot to mention, for those contemplating doing this too: remember to note the orientation of the EEPROM. This is critical so that the correct pins are on the correct pads when you re-solder the IC onto the board.
    Jimmyh likes this.
  19. May 6, 2020 at 12:43 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Good fukin job dude!
    :thumbsup:
  20. May 6, 2020 at 6:16 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Good to know! Thanks for doing the work.
