Odd Transmission Whine or humming sound
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Choano, Aug 10, 2020.
  1. Aug 10, 2020 at 5:15 AM
    Choano
    Choano [OP] Member
    Looking for help on a maintenance issue, maybe some else has experienced this.
    2020 TRD Sport, Double Cab, 4x4, Regular Bed, OEM Firestone 17" wheel, 1. month old.
    I get a loud whining or humming sound at speeds between 45-60 MPH when the throttle is applied. This sound only occurs when the driver or cruise control applies throttle. Manually shifting gears between 4th, 5th and 6th has no effect on the sound. Also "sideloading" the suspension has zero effect on the sound. It seems to originate from the back passenger side, maybe the right rear wheel but I'm not 100% sure about that. Again the sound is in direct relation to the gas pedal, you press the gas pedal you get the sound, let the pedal go and it stops, tap the pedal rapidly and the sounds comes and goes rapidly. It's impossible to ignore, the stereo needs to be above 38 to drown it out. You can actually hear it with the windows down. I'm taking it to the dealer this week and was looking for anyone with a similar experience that might be helpful. Thanks
  2. Aug 10, 2020 at 5:26 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Driveshaft u joints, maybe
  3. Aug 10, 2020 at 5:29 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Is it maybe the rear differential? I think this is common, mine has a slight whine, I just leave it, rather than having the dealer tear it all to hell and rebuild.
    bulalo, Skydvrr, zoo truck and 2 others like this.
  4. Aug 10, 2020 at 6:05 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    This. There's a slim chance that the dealer will do anything about it, and if they do, there's a better than slim chance that the noise will return.
    You'll get used to it and tune it out eventually.
    I would check the level of fluid in the rear diff., just to make sure it was full from the factory.
  5. Aug 10, 2020 at 6:35 AM
    Taylor21554
    Taylor21554 Active Member
    My 2020 has a slight whine in the rear... I’ve learned to live with it. Only happens when feathering throttle at 65. Can only hear with radio off and windows up. Hasn’t gotten worse since i I purchased. Not worried about it.
  6. Aug 10, 2020 at 6:38 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Mine does the same . I have taken it to the dealer they diagnosed it as a driveshaft noise .Said its normal no fix or solution for it . I have about 5k miles on the truck now so if it breaks down because of it its recorded at the dealer as normal. I just turn my stereo up louder now lol :rofl:.I would at least take it in and have them document it on your truck even if they call it normal your covered in the long run . Best of luck hope it helps .
    AKGSD likes this.
  7. Aug 10, 2020 at 7:57 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Head directly to the dealer and make them fix it. It's a brand new truck!!
    G.
  8. Aug 10, 2020 at 7:59 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Pretty sure my buddies 2019 trd does the same, among some weird tranny quirks. Dealer claim its normal for that vehicle. Its lifted now with more aggressive tires so you really can't hear anything but the tire noise after the truck gets up to speed.
  9. Aug 10, 2020 at 8:19 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Get duratrac tires. Looks good and you won’t hear that whine .
    Junkhead, MOC221_ and Chew like this.
  10. Aug 10, 2020 at 11:10 AM
    Rodchester
    Rodchester Well-Known Member
    Baton Rouge
    2017 Quicksand SR5 DCSB V6
    Weather tech mats, LED interior lights and reverse lights, tube steps, bed extender, bed mat, folding bed cover, TRD Pro grill, blacked out badges and wheel center caps. Kicker speakers(all 6). Front bed rail header. Under hood LEDs. Tufskinz door and interior foam inserts. Chrome interior door handles. Fumoto drain valve. Aluminum oil filter canister. Rear view mirror with Homelink. Quick charge USB charging ports. TRD badge on grill. MESO fuse box cover. Redline Tuning hood struts. Ceramic coating. Pop & Lock auto tailgate lock. LED bed lights. Lower bumper LED light that bar. MESO coin holder. TRD cat back exhaust. Hikari Ultra LEDs high and low beams. 2020 TRD Sport wheels and TRD center caps. RSC Nano dashcam. DSM from the Taco Garage. Blue Sea dual USB outlet on back of center console. KDMax7.0
    Rear differential. Just think of it as Toyota going old school on the new Tacomas.
  11. Aug 10, 2020 at 11:48 AM
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    all vehicles make whining noises at some point. not sure what the issue is. just gear harmonics.
  12. Aug 11, 2020 at 7:37 AM
    Garyji
    Gary
    Absolutely! Make them tell him that. Not us here on TW.
    G.
    AKGSD likes this.
  13. Aug 11, 2020 at 7:56 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Hahaha!
    Truth.
    The more they wear the louder they get.
    bulalo[QUOTED] and Garyji like this.
  14. Aug 11, 2020 at 10:51 AM
    2020cement
    2020cement Active Member
    Toyota will say it’s normal.
    AKGSD likes this.
  15. Aug 11, 2020 at 11:24 AM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    It’s obnoxious, but “normal”
    I tried and failed to get mine fixed
  16. Aug 11, 2020 at 11:34 AM
    zoo truck
    None
    Well, i'm still waiting to hear from mine. I had a 2001 tundra with nearly 300k miles and no whine. I've had toyota pickups since the 70's and never heard them whine. Can't say some of those small pickups were perfect though.
    AKGSD likes this.
  17. Aug 11, 2020 at 2:08 PM
    TriniPhantom
    TriniPhantom Well-Known Member
    Bay Area, California
    2018 Tacoma TRD Off Road DCSB
    Prinsu roof rack, Budbuilt Sliders, Avid Bumper Guard, MESO Ultimate Turn Signals, Door sill decals, Raptor Lights, Tailgate inserts, Mudflaps, Tri-fold Tonneau, DC Motorsports Muffler Tip, TVD Vinyl Decals, Many Interior Mods.
    Truck makes noises. Welcome to the club. Just crank up the volume on your radio and enjoy the truck. I have the rear diff whine around 55-60mph. Honestly can't say it affects anything. I know a lot of people around here talk about their older trucks having no noises, but I think it's all relative. I mean the cabin in the Tacoma is pretty quiet so you tend to pick up on a lot of 'other' noises. But if you have a 'noisy' older truck, the whine would just be drowned out. By the time you throw on a roof rack plus some knobby tires you won't hear nuttin'
  18. Aug 13, 2020 at 4:17 PM
    Choano
    Choano [OP] Member
    Tacoma update
    First off thanks to the folks who were able to read and understand my comments, I really appreciate your insights and you taking the time to share your personal experiences.
    I talk to the service manager and we went over the issue, I told him that this was not going to be ok unless the truck was fixed period. To his credit he accepted my offer to go for a ride and he admitted that the issue was not a "Tacoma thing" and needed to be fixed. They went at it pretty quickly and decided to replace the rear differential (Chew you nailed it) and that completely resolved the issue. It's like I'm driving a different truck.
    Chew and AKGSD like this.
  19. Aug 13, 2020 at 4:19 PM
    AKGSD
    Joe
    Alaska
    Well.... guess you’re lucky. I and many others were told quite firmly that this is “normal” and to suck it up.
    Makes me more frustrated that yours got fixed :p
    Could you post your Repair Order description?
  20. Aug 13, 2020 at 4:19 PM
    Choano
    Choano [OP] Member
    Go to a different dealer or really lay it out for them. I was nice but very much to the point.
