Occasional whine in rear end
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tocoma2021, Mar 19, 2024.
  1. Mar 19, 2024 at 6:33 AM
    Tocoma2021
    Tocoma2021 [OP] New Member
    2021 Gray Tacoma 4x4 TRD Off Road
    This is hard to explain. Basically coasting when no gas is applied, there is no whining noise. When just a little throttle is applied there is a whining noise that is annoying to hear. Add a little more throttle and the noise goes away. I know that is a lousy description, but I can’t explain it any differently. Has anyone have any ideas?
  2. Mar 19, 2024 at 6:44 AM
    Clearwater Bill
    Billy
    Largo Florida
    Some searching here will find lots of threads on the topic.
    If you sprang for the extended warranty, time to let it help you.
    In my location I'd go to a specialty differential shop for diagnosis and possible repair.
    tcBob likes this.
  3. Mar 19, 2024 at 7:14 AM
    YotaHead858
    YotaHead858 Well-Known Member
    San Diego, CA
    2023 TRD OR
    King Shocks Camburg UCA's
    Have you had any differential fluid service performed?
    Same thing happened to my 04 4Runner back in 08, I noticed the same whine. I blew the differential brought it to Toyota and the technician found it was low on gear oil. Luckily, my extended warranty took care of this.
    Like the member ^^^ said, if you have the extended warranty, let Toyota take care of it.
    tcBob likes this.
  4. Mar 19, 2024 at 7:15 AM
    YotaHead858
    San Diego, CA
    2023 TRD OR
    Also, if you have the tools and depending on the miles it wouldn't hurt to service the diff fluid, cheers!
  5. Mar 19, 2024 at 7:28 AM
    BlackCat81
    BlackCat81 Well-Known Member
    2023 Ice Cap TRD OR
    theres a bulletin for it.
    tcBob likes this.
  6. Mar 19, 2024 at 7:49 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    From my perspective, this is a normal phenomena.
    Both my '06 TRD OR and my current '21 TRD OR exhibited this behavior occasionally.
    Has yet to develop any mechanical issues.
    warjelly likes this.
  7. Mar 19, 2024 at 7:59 AM
    Big Cole
    Big Cole Well-Known Member
    My 21 TRDOR makes the same whine sound. Diff fluid change made no difference. Rear axle rebuild isn't an excessively expensive repair so I'm not concerned.
  8. Mar 19, 2024 at 8:27 AM
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    So what is your plan? Run it until your rear axle completely blows, than fix?
  9. Mar 19, 2024 at 8:35 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Are you the initial owner? Has the truck been re-geared?
  10. Mar 19, 2024 at 8:57 AM
    Big Cole
    I'll monitor the situation and once the sound becomes louder I'll have the rear end rebuilt. I have a few jeeps that have all been regeared so I'm used to $1,300 per axle for the rebuild.
  11. Mar 19, 2024 at 9:53 AM
    PTPinETN
    PTPinETN Well-Known Member
    Alan
    ETN
    My ‘21 OR did this too, repeatable every time- 57mph, let off throttle and it’s whining, on the gas and much above or below 57, no whine.
    My rear locker wouldn’t engage at around 18k, I believe it was, and the dealership (warranty) replaced the rear carrier (going from memory) and the whine is gone.
  12. Mar 19, 2024 at 11:46 PM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
  13. Mar 20, 2024 at 3:07 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I don’t have this with my 23
    I did change the diff fluid at 500
    Funny how the manufacturers don’t recommend an oil change but all aftermarket gear builders do.
    Not sure if my early fluid change prevented a whine or I just got a properly set up diff.
  14. Mar 20, 2024 at 3:50 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Mine has done this from new it’s been the same noise level since new . I brought it up with my service advisor . They diagnosed it heard the whine . Was advised by Toyota to add a sound barrier to it . I did have the fluids changed at 30k no metal shavings . I’m at 50k and still going . My guess is Toyota won’t replace the differential unless the noise is excessive. So just keep driving it if it becomes really bad push for a differential swap . I have read that others have done this and noise comes back . I don’t know …
  15. Mar 20, 2024 at 1:09 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    I think it’s resonance coming from the area .Almost like the side view mirror thing . It’s not like everyone is blowing up rear diffs . Pick up trucks in general are noisy in those areas . It’s all exposed if you think about it .
    If your fluid is good ,pick a good Zeppelin tune or some Pink Floyd and you will forget about it . Just put it really loud lol
  16. Mar 20, 2024 at 1:13 PM
    goofydug
    goofydug Well-Known Member
    Doug
    SoCal
    '17 TRD Sport
    My doctor recommended against wine in the rear end.
    faawrenchbndr likes this.
  17. Mar 20, 2024 at 1:25 PM
    TruckGuy63
    Gilbert
    New York
    Really if you think about it , if the oil in the diff is good , nothing Is coming apart. If you don’t hear banging and stuff like that , it could be anything stupid that has nothing to do with mechanical performance. I had a 01 Gen 1 that from brand new had Vibes in the back . I could see the passenger seat would vibrate or shake on the highway . Fast forward 200 k miles later , it did the same thing not more or less . It never broke and never gave me an issue, and believe me I loaded the hell out of that truck , with tiles and other masonry stuff.
    All I ever did was struts ,belt , timing belt ( water Pump also ) twice , shocks ,and brakes. Of course I was all over it maintenance wise . Was it fast no, was it quiet inside no, did it get good gas mileage no , was it a great little truck 100 percent absolutely. I can honestly say that about all my Toyota stuff I owned . As of now , I never got burnt once . At least so far . That’s why I keep coming back .
  18. Mar 20, 2024 at 3:39 PM
    B6P6P6
    B6P6P6 Well-Hung Member
    Brian
    Firestone,Colorado
    2023 Tacoma Sport
