OBDII not communicating with Scan tool
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 619Tacoma, Sep 20, 2012.
  1. Sep 20, 2012 at 11:44 AM
    619Tacoma
    619Tacoma [OP] Baja bound
    Call me Rocco
    San Diego, CA
    07 PreRunner SR5, Sport, 4dr
    - Billstein 5100's all around with OME 885 coil springs. - K&N Air Filter - HID Headlights & Fogs - Kenwood Stereo & Infinity Speakers - CB Radio, - Fog On Anytime mod - Anti Tailgate theft mod. More comming...
    I took my truck to the dealership last week to get the Clock Spring recall done. The tech called me a few hours later and told me they were not able to communicate with the ECU. He said they tried a couple different Scanners to rule out a faulty Scan tool but they still weren't able to get it to communicate.
    The guy said his mechanic said he could fix the problem for $200. I said no thank you believing that for the dealership to charge only $200, it must be something fairly simple to do. I did not ask what was wrong thinking he wouldn't tell me. I have gone and checked all the fuses already and everything seems fine.
    Is there a diagram of the OBDII connector for an 07 prerunner showing what wires should have power, etc? I want to try and fix it myself instead of paying them for something that is possibly really simple. Any ideas? I have a multi-meter and hope that could help me figure this out.
    UPDATE:
    I took my truck to a different dealership and dropped it off for the recall work. I get a call later from the service adviser saying they weren't able to perform the recall. They would need 3 hours to diagnose the problem before they could proceed - I declined again. When I picked it up, I spoke to a different adviser as the one I was assigned was not around. This other very helpful adviser looked at the notes from the tech and told me they were able to perform the spiral cable recall, as well as trimming the accelerator.
    They were NOT able to re-flash my ECU though. I asked why that was and he told me: "I'll give you the technical answer." He said it has to do with ohms and amps. He said that the tech noted that there are a bunch of aftermarket wires in the dash. The adviser said that there must be an aftermarket wire getting power from a power wire that runs to or from the ECU. They will not perform a re-flash until the amperage/ohms read from the OBDII are what they should be. They don't want to try to re-flash only to have it crash midway and mess up the ECU because of some aftermarket wire feeding power from the ECU cable. He then told me: "The only reason I know that is because I know what he's (the tech) talking about." He asked me what kind of aftermarket things I have wired and I told him the only things in the dash are:
    - Aftermarket stereo
    - All new Aftermarket speaker wires from back of stereo to 4 channel amp. Then speaker wire to each speaker.
    -Power wire & signal wire to powered subwoofer
    He said that one of those items must be getting power from a wire that corresponds to the ECU. His suggestion was to simply unplug all of those accessories so that they aren't pulling any power from the ECU cable system. That way the amperage & ohm rating should be back to normal and they should be able to perform the recall.
    Does this make sense to anybody? I know there are some Toyota Tech guys on this site. Hopefully they can chime in.
    One other thing of interest; the tech noted that the check engine light is on. It's not on in the dashboard and when I had smog done, it wasn't on either.
    The light works since it lights up on start up, but it doesn't stay on indicating that the engine needs to be checked. Wonder if he confused the "Maint Rqrd" light for the check engine light??
    PFEScan-page-0_zpsa0b486ba_bbb08cd8fc6ebb6cf1a5f91b8d73ffd3b52bb3be.jpgToyotaPage2-page-1_zps883b1b13_fb6c514d6d3fc0ca7b6df816f970c784da3f68e9.jpg
  2. Sep 20, 2012 at 3:28 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    go to autozone and see if they can scan it. it has to be a can capable scanner of course
  3. Sep 20, 2012 at 5:05 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
  4. Oct 5, 2012 at 11:27 AM
    619Tacoma
    Call me Rocco
    San Diego, CA
    Bump.
    Anybody have any other suggestions on how to diagnose & fix this issue myself?
    I checked all the fuses under the hood as well as under the dash and they all seem perfectly fine.
  5. Oct 5, 2012 at 11:41 AM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
    does the yellow wire in the DLC connector have power
  6. Oct 5, 2012 at 12:20 PM
    619Tacoma
    Call me Rocco
    San Diego, CA
    I don't know but I will check this afternoon.
  7. Jan 3, 2013 at 12:41 PM
    619Tacoma
    Call me Rocco
    San Diego, CA
    UPDATE:
    I finally took my truck to a couple of electricians to figure out what was up with my OBDII port.
    1st: neighborhood mechanic (who also has a Tacoma) said his scanner could not communicate with the computer.
    2nd: 2 weeks later, General mechanic with a shop said his scanner was unable to communicate with the computer.
    3rd: Same day as general mechanic, Auto Electrician with shop WAS able to get his scanner to communicate with my trucks computer. It showed no errors and that everything was fine. Tried it several times and it worked fine.
    4th: Since the last guy told me it was working fine, about 5 days later I went to get my smog check done. Their scanner was successfully able to communicate and confirm no codes in my trucks computer & passed the smog check.
    1 week after smog check, I drop my truck off at the Toyota dealership to get the two recalls done... and guess what? I get a call about 3 hours later saying their computers/scanners (3 of them) were not able to communicate with the truck's computer and so they cannot do any of the work until that's fixed. I told them an electrician was able to get his scanner to read it and so did the smog place and they just said they didn't know why but they couldn't do anything because their system wouldn't read it.
    I'm completely fed up! I have no idea what to do. The dealership wants to charge me $500 now to "fix" the problem. I'm going to take it to the electrician again and see if his scanner will read my truck's computer still. I'm going to try a different dealership if his scanner works fine.
    Any ideas what the hell could be going on? The only thing I can think of is that possibly one of the prongs/wires in the adapter has bad contact and thus with vibration and/or movement of the adapter the contact is lost.
  8. Jan 3, 2013 at 1:01 PM
    619Tacoma
    Call me Rocco
    San Diego, CA
    Thanks, I'll print that out and test it out this weekend. Otherwise, I'm going to take it to the electrician again.
  9. Jan 25, 2013 at 6:47 AM
    folmonty
    folmonty Active Member
    Monty
    NorCal
    05 PreRunner Sport (sold) 13 AC 4X4 (inbound)
    How'd this work out Rocco? Good thing you got other opinions. When you got smog cert they actually connect to the OBD and looked for fault codes? Just went through that and don't recall seeing that? Barely want those yahoo's opening the hood on my vehicles let alone anything else. Biggest rip-off ever but that's a whole nuther story!
  10. Mar 6, 2013 at 1:20 PM
    619Tacoma
    Call me Rocco
    San Diego, CA
    Yes, the smog place brought out their scanner, hooked it up to the OBDII port and scanned for I'm assuming fault codes and/or maybe specifically for a check engine fault code that would automatically fail my truck's smog test.
  11. Mar 7, 2013 at 6:43 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    No experience here, but from what you've posted I would suspect that the "helpful" tech had your answer. The Toyota scanners check for proper volatage/resistance prior to flashing the ECU. The other scanners, from the emissions station and your mech friend, are not checking for voltage/resistance but rather just pulling the codes which does not require the checks that an ECU flash should.
  12. Jan 6, 2024 at 7:13 PM
    ChocoTaco88
    ChocoTaco88 Just a little midnight snack
    Mac
    1998 Black 2wd 5spd
    Restoring
    Did you ever figure this out? Its been 10 years lol
    Mine is doing this now.
  13. Mar 2, 2024 at 1:42 PM
    nasher75
    nasher75 Member
    Erik
    2006 Tacoma 4X4 4.0
    I'm in the same boat. 2006 Tacoma took in for smog test and after 30 mins the tech told he could not establish communication with my OBD system. Checked OBD fuse and good. Plugged in my own scanners and home and they are powering up but not able to establish comms.
    checked back shell of OBD connector and no loose or pulled wires.
    I suppose after 18 years it could be the ECU, but hoping to hear back from someone
  14. Mar 2, 2024 at 6:31 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Are you experiencing any other problems with the truck?
    If so, what are they?
    We need to know all we can to help steer you in the right direction.
  15. Mar 3, 2024 at 9:00 AM
    nasher75
    nasher75 Member
    Erik
    2006 Tacoma 4X4 4.0
    No other issues with truck. Just took it in for smog check and was told they could not connect to OBD. Checked OBD fuse and wiring under dash. It powered up my scan gauge tool, but also would not communicate. And even though my scan tool was powering up, I verified good voltage and grounds on OBD connector.
    I read that aftermarket equipment wired up might cause issues, but I only have an amplifier wired to the battery. Haven't used the amp in years because head unit died. Either way, I inspected connection at battery and was surprised to see the positive connection of that cable was completely gone. Lug was on the battery terminal and cable end near by, but all strands of stripped end were gone???
    Considering that I had no idea when that connection may have failed and any related voltage variance, I decided to disconnect battery to clean terminals and posts. While the battery was disconnected, I pulled all the ECM connectors to inspect. Found no corrosion or issues.
    Put everything back together and now my scan tool is connecting it OBD system. Need to put some miles on the truck before I take it back down for smog test.
    TnShooter likes this.
  16. Mar 4, 2024 at 7:00 PM
    Psng
    Psng New Member
    97 Tacoma 2.4L
    Hi Nasher75,
    I am also have a no communication with the ECU on my 97 Tacoma. Most of the issue is caused by failing capacitors in the ECU. I found one leaking capacitor in mine and I have all the capacitors professionally replaced but still have the no communication error. My board could be damage by the leak from the capacitor.
    Yours seem intermittent and you might want to google for capacitors issues on Toyota ECM since this seems to be common problem.
  17. Mar 4, 2024 at 7:12 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I wonder if you maybe have a spread pin in the OBD connector.
    2nd gens don't tend to have that issue or really many PCM problems at all for that matter.
  18. Mar 4, 2024 at 9:00 PM
    nasher75
    nasher75 Member
    Erik
    2006 Tacoma 4X4 4.0
    I'm in agreement with you. Took it back for smog test and once again they could not communicate with OBD. I plugged in my scan tool in the parking lot before the test and all was good.
    Got it back out when they said they could not connect and all the sudden, it wouldn't even power up. If I held pressure against the wires or connector it would power up, but would not connect intermittently.
    Came back home and more of the same, so I've ordered a pre-wired OBD 2 connector and will try splicing it in and try again. Starting to get annoying.
    The truck is old and beat to shit, but it still runs like a tank so I refuse to give up on it. I also have 2021 Tundra TRD Pro, but I just cannot seem to let this truck go. I've had it for 18 years and it has been an absolute workhorse.
    Dm93[QUOTED] likes this.
  19. May 9, 2024 at 12:46 PM
    Devin 99taco
    Devin 99taco Member
    Devin
    1999 Toyota Tacoma Prerunner 3.4l auto
    Suspension, wheels, roll bars, bumpers, all lights, additional lighting.
    My 99 just shut off on me while pulling into a parking lot, tried to restart it, it'll crank, no start. Obd2 scanned I keep plugged into it at all times for live data is now not connecting with the ecu, powers on just fine but steadily keeps scanning. Checked my fuses and relays, everything seems fine. Suspecting either fuel pump because I've read from 2 other people that it caused their obd2 not to connect. I'm hoping it's not it because it's hot as hell outside right now lol. Thinking possibly crank sensor too, haven't checked for spark yet.
    Had a misfire going for a few weeks lately and I doubt that helped anything
  20. May 9, 2024 at 1:23 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    A failed fuel pump or crank sensor won't cause no communication with the PCM.
    I'll have to look at wiring diagrams later, meanwhile you can unplug the TPS and see if you have 5v on one of the terminals with the key on. That will tell us at least if the PCM is online or not.
    BTW this thread was about a 2nd gen, yours is a 1st gen. 2 completely different trucks.
