OBDII Bluetooth Device for iOS? 1st gen
Discussion in '1st Gen. Tacomas (1995-2004)' started by chrispchicken9, Apr 22, 2019.
  1. Apr 22, 2019 at 2:00 PM
    chrispchicken9
    chrispchicken9 [OP] Well-Known Member
    '04 3.4 tacoma, '16 4.0 4runner
    Anyone know of a high quality OBDII Bluetooth capable Car Scanner that'll give real time data, like coolant temp, transmission temp, maybe mpg, and whatever else
    Something similar to Scan Gauge II, but bluetooth to toggle into phone - specifically iphone in my case.
    I realize there may be threads on this from 8 years ago but I'm interested in today's technology and today's newer model scanners - there are so many to choose from!
    Looking for thoughts, tips, and product recommendations
    Thank you in advance
  2. Apr 22, 2019 at 2:02 PM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    chrispchicken9[OP] likes this.
  3. Apr 22, 2019 at 2:07 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
  4. Apr 22, 2019 at 2:15 PM
    chrispchicken9
    This got pretty decent reviews, thanks for the recommendation.
    When connected via wifi, does this interefere with streaming music? (in the event the phone tries to stream music through wifi connection with no internet)
  5. Apr 22, 2019 at 2:16 PM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    i personally have not tried while reading it. I would assume no issues since its not bluetooth.
  6. Apr 22, 2019 at 2:18 PM
    Bannerman
    Johnson
    Charlotte, NC
    Yes, you can get around this by downloading music to your phone. but its never been an issue for me as I pretty much just use to to read and clear codes.
  7. Apr 22, 2019 at 2:24 PM
    chrispchicken9
    Makes sense. so because it's connected to wifi it pretty much makes any internet usage not applicable is what I'm understanding.
    In essence it's best for reading and clearing codes on the fly - you wouldn't keep it connected for an extended road trip to watch temps if you're towing, and still wanted internet on your phone.
  8. Apr 22, 2019 at 2:34 PM
    chrispchicken9
  9. Apr 22, 2019 at 3:51 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    LOL@certified and licensed
    Bluetooth is Bluetooth.
    If you have a smart TV close enough to your car, you can even see your codes/etc. on your big screen. In cases like these, it's the app that's more important.
  10. Apr 22, 2019 at 4:32 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    You can use bluetooth. Wifi sucks because it blocks your internet usage.
    I have used the gopoint one which used to be the only one able to use bluetooth. Now I use carista which is cheaper and does the same thing.
    https://www.amazon.com/Carista-Blue...5876&s=gateway&sprefix=barista,aps,123&sr=8-2
    It works with pretty much any app that you'd want (dash command, obdfusion, enginelink)
  11. Apr 22, 2019 at 4:59 PM
    Zerofear66
    Zerofear66 Well-Known Member
    2022 TRD Off Road Lunar Rock, 2014 Tundra Crew Max TRD 5.7L
    Torque app is pretty solid.
  12. Apr 22, 2019 at 6:39 PM
    Glamisman
    Glamisman Well-Known Member
    BlueDriver is tough to beat.
    as for reading some live data, it isnt 100% the tool used, some manufacturers dont have those PID's avalible for viewing and some Scanners cant scan certain manufacturers... there is a piss you off factor in buying a scanner as there is no one tool to do it all. You didnt mention a budget... Launch makes an excellant scanner and will probably do more than what you want but for the sub $100, Bluedriver.
  13. Apr 22, 2019 at 9:54 PM
    chrispchicken9
    No, that’s wrong. You must be a 3rd gen owner. Not any Bluetooth is Apple compatible. Among other countless tech accessories that aren’t Apple compatible. Thanks Apple
    Interesting, I’ll have to check out Launch. Bluedriver was a top pick on other websites I read as well. Thanks for the tip.
  14. Apr 22, 2019 at 9:55 PM
    chrispchicken9
    Reading through the reviews it sounded like people with Apple had to use WiFi as the Bluetooth wouldn’t work
  15. Apr 22, 2019 at 10:02 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    LOL
    1st Gen, thank you very much.
    Must be an apple thing then; android user here. I'm not about "proprietary gear and software".
  16. Apr 22, 2019 at 10:09 PM
    chrispchicken9
    This thread is regarding obd2 scanner for first gens compatible with Apple software.
    Thanks for sharing linda
  17. Apr 22, 2019 at 11:36 PM
    Glamisman
    In my haste I forgot one thing... what ever tool you buy you will always wished it did more. Your buddies ABS light comes on on his Silverado and maybe your scanner can read ABS, maybe it cant. It is what they DONT tell you that it cant do is the annoying part.
