OBD2 Splitter
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Irishblessing, Apr 12, 2024.
  1. Apr 12, 2024 at 4:21 PM
    Irishblessing
    Irishblessing [OP] So Cal Is Where My Mind States
    2023 Tacoma OR
    I have seen a couple videos on this with conflicting results; I could have revived an old thread or posted a new one.
    My Plan and Question: I have a Scanguage I am currently running in OBD2-and would like to continue to use-I am getting a Shift Sense Pro and would like to use them simultaneously; has anyone had success using a OBD2 splitter with these two items or similar items?
  2. Apr 12, 2024 at 5:31 PM
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
    I have a splitter on mine with a PedalMonster on one connector and a Bluedriver code scanner on the other. The Bluedriver app allows for monitoring real-time data. When using both, the Bluedriver app would show occasional drop outs of the parameters I was monitoring (coolant temp, etc.). The PedalMonster worked fine.
    When I put the PedalMonster in 'non-OBD' mode such that it was no longer reading vehicle speed and only using the OBD port for power, the data dropouts on the Bluedriver app went away.
    Since the OBD port was never designed to have two devices polling for data, don't be surprised if the two devices step on each other.
    I didn't have any drivability issues, check engine lights, etc.
    Irishblessing[OP] likes this.
  3. Apr 13, 2024 at 9:45 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Scangauage says it is not possible.
    Banks uses their own system that “splits” OBDII with their Pedal Monster and their iDash gauges and it works flawlessly.
  4. Apr 19, 2024 at 3:04 PM
    Irishblessing
    2023 Tacoma OR
    For Those who are wondering the same thing:
    I purchase the BBFly Pro OBDII Splitter and I am running the Shift Sense Pro in conjunction with a Scan Gauge II.
    I only just installed and did a short trip to shift through all the gears, functionally both units appear to be working correctly.
    My best guess as to why both these units work correctly together is that they are both READ only-No Write.
    I will update once I put more miles on it.
    inwood customs likes this.
  5. Apr 19, 2024 at 3:09 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
