OBD2 port help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco_Sam_96, Mar 21, 2022.
  1. Mar 21, 2022 at 2:40 PM
    Taco_Sam_96
    Taco_Sam_96 [OP] Well-Known Member
    1996 White Tacoma 4x4 DLX Extended Cab 5VZ-FE 3.4
    Recently my obd2 reader stopped working in my truck. No other problems with the truck. Checked the fuse under the hood and it was blown. I put a new fuse in and still didn't work. So I figured the female pins in the port had opened up and were not making good connection. After further investigation I found a broken wire. Fixed it with a new end but the port is still not working. I only have a test light but I can't seem to find any power going to any of the wires. I'm not sure which one is supposed to have power. I could really use a chart or something showing the location of all the pins (so I'm sure I put the wire back where it came from) and to also know which wires carry signal/power/ground. I'm a complete novice at wiring. I've always avoided it as much as possible...lol....can anyone point me in the right direction? I have googled everything I know to and I'm having no luck. TIA
    brandon78lusch likes this.
  2. Mar 21, 2022 at 2:59 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    I don't know a lot about first gens but is there also a fuse under the dashboard for this too?
    Taco_Sam_96[OP] likes this.
  3. Mar 21, 2022 at 3:25 PM
    Taco_Sam_96
    Thanks....I did just out of curiosity check the fuses in the cab and they are all good. I'm not sure why there's no power to any of the wires. Probably going to have to get a pro to look at it.
  4. Mar 21, 2022 at 7:49 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Pin 16 should have power at all times (from OBD Fuse in engine compartment), pins 4 and 5 should be grounded at all times.
  5. Mar 22, 2022 at 5:50 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    The first step is to verify your code reader still works.
    Test on another vehicle. I have had them power up give the can not connect signal yet fail to work when another reader is tried all was well on the truck side.
  6. Mar 22, 2022 at 9:53 AM
    Taco_Sam_96
    Thanks...this is exactly what I've been looking for. Now to figure out why I don't have power. Fuse is good and has power but no power at the obd port. Again thank you!
  7. Mar 22, 2022 at 9:56 AM
    Taco_Sam_96
    Thanks...yes that was actually the first thing I did and the reader works great on every vehicle I've plugged it into. I'm pretty sure something else is wrong. Don't have any power to the obd port though my fuse is good and fuse has power. Again thanks
  8. Mar 22, 2022 at 11:15 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    The fact that the fuse was blown to begin with likely indicates a short in that power wire between the fuse and the OBDII port. If it were me, I'd run a wire directly from a known 12v source (battery) to that #16 pin on the port.
  9. Mar 22, 2022 at 6:04 PM
    Taco_Sam_96
    Okay...solved the problem. It appears the scanner I've been using is blowing the fuses. That's what it appears to be anyway. Everything is back together and working with no codes showing. Trucks running great. Thanks EVERYONE for your help!!
    TnShooter likes this.
