OBD scanner
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DCJeeper, Jan 17, 2022.
  1. Jan 17, 2022 at 12:50 PM
    DCJeeper
    DCJeeper [OP] Well-Known Member
    Hi, anyone recommend an OBD scanner that can monitor transmission fluid temperature too?
  2. Jan 17, 2022 at 12:59 PM
    Rememberthecaptain
    Rememberthecaptain Well-Known Member
    Eastern Washington State
    2022 TRD OR 6MT Tacoma. 2021 Venture Edition 4runner
    Look and see.....
    I’m interested as well, good luck to you.
  3. Jan 17, 2022 at 12:59 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  4. Jan 17, 2022 at 1:15 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    veepeak are the cheapest option
    DCJeeper[OP] likes this.
  5. Jan 17, 2022 at 1:40 PM
    JHMartin08
    JHMartin08 Member
    Jay
    2022 Tacoma TRD Off Road Access Cab
    With my 2005 4Runner, I had to write a custom PID for the Torque app to report on transmission temp. I haven't tried it yet with my new truck. Good info here.
    Jay
    Dam325 and DCJeeper[OP] like this.
  6. Jan 17, 2022 at 3:04 PM
    DCJeeper
    This only works for Android, not iOS right?
  7. Jan 17, 2022 at 3:12 PM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    it works with iOS. i use the "Car Scanner ELM OBD2" app
    DCJeeper[QUOTED][OP] likes this.
  8. Jan 17, 2022 at 3:15 PM
    DuffyBank
    DuffyBank Well-Known Member
    Scangauage II
  9. Jan 17, 2022 at 3:42 PM
    MIDTNTACO
    MIDTNTACO Well-Known Member
    Middle Tennessee
    2020 Midnight Black TRD Sport 4x4 DCSB
  10. Jan 17, 2022 at 3:58 PM
    DCJeeper
    Checked the reviews of this one
    https://www.amazon.com/Veepeak-OBDC...ve&sprefix=OBDCheck+BLE.,automotive,64&sr=1-5
    Someone asked about transmission temperature and the answer is it can do with the right app. Maybe that's the one you mentioned: Car Scanner ELM OBD2? Or some special PID needed for each model?
  11. Jan 17, 2022 at 4:45 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    I’ve been looking at the blue driver for like 6 months. I thought I read that it scans live data, including trans temp.
    Can anyone confirm?
    Montana_Actual likes this.
  12. Jan 17, 2022 at 4:50 PM
    Montana_Actual
    Montana_Actual ;)
    I have a bluedriver one. Does it all from their app. I found too many problems with those other apps so I scrapped it. I was using Torqued when I had my FORD and that's when I gave up then swapped to the BD. Their app does everything as far as monitoring and codes.
    DCJeeper[OP] and dfanonymous like this.
  13. Jan 17, 2022 at 6:52 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It definitely is. And, super easy to setup using the info in the Fusion dashboard sharing thread.
    Yes. All OBD adapters get to the same data. You just need a solid app and OBD Fusion is that app.
    Torque Pro is another great app, but it has only the standard PIDs. You need to code the extended set.
    JHMartin08 likes this.
  14. Jan 17, 2022 at 7:44 PM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    yep, that's the one. i think i had to pay a few bucks for the extra PIDs
  15. Jan 18, 2022 at 5:05 AM
    DCJeeper
    @cryptolime Great, thank you!
    Can you let us know how to get the PID for Tacoma and 4Runner? I will order it online and want to know if I can pay for the PIDs when ordering or need to contact somewhere else to get the PIDs.
  16. Jan 18, 2022 at 5:42 AM
    DCJeeper
    Looks very nice!
  17. Jan 18, 2022 at 9:41 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    when you setup the app, it will ask you what vehicle you have, and give you the option to buy the extra PIDs. very easy. i'm not sure that I had to pay for it. it was quite a while ago. if i did, it was only 5 or 10 bucks.
  18. Jan 20, 2022 at 4:38 PM
    DCJeeper
    I saw somewhere in the forum that when checking temp using jump pin method for TRD with tow package, I will need to disconnect a switch somewhere. Do I need to do the same when using the OBD scanner?
  19. Jan 20, 2022 at 6:51 PM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    no, just plug it in
  20. Jan 20, 2022 at 6:58 PM
    DCJeeper
    Thanks. After overfilling the pan with fresh ATF, do you shift gear several times to let the fluid circle around so the fluid from torque converter can be mixed and no 'gap' between them for correct level?
