OBD permanent fault code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Larzzzz, Aug 23, 2019.
  1. Aug 23, 2019 at 11:56 AM
    Larzzzz
    Larzzzz [OP] Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I have never heard of these and I have one because I just got my vehicle inspected in the lovely state of Taxachusetts.
    My permanent fault code is 7F 0A 11. Can this be translated to a standard trouble code format? Can I get rid of it?
    Thanks
  2. Aug 23, 2019 at 12:00 PM
    RicanTacoma
    RicanTacoma Well-Known Member
    Andres
    Fountain, Colorado
    2014 DCSB OR
    interesting………..
  3. Aug 23, 2019 at 12:05 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Most of the permanent codes are all tied to emissions faults within the system. They are intended to be permanent in order to prevent short term fixes of the CEL just to pass inspection. A full drive cycle (defined differently by manufacturer) must be completed within satisfactory parameters to clear the code. Use a code reader on the OBD II to give you a better readout.
    Start here:
    https://www.outilsobdfacile.com/obd-presentation.php
  4. Aug 23, 2019 at 12:09 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    http://app.mavehiclecheck.com/newsletters/newsletters/InspectionUpdate_Volume17-Issue03_Fall2016.pdf
    See page six for information on permanent codes directly from the Comm of MA..
    Seems like you have to make a repair of the condition causing the code. You can’t just use a scan tool to clear it. So in essence, they’re not really permanent...
    Here’s some general info on all DTCs:
    https://www.autoserviceworld.com/carsmagazine/taking-a-first-look-at-permanent-dtcs/
    As for the 7F 0A 11, doesn’t your read out say what needs to be fixed?
    Jimmyh likes this.
  5. Aug 23, 2019 at 4:22 PM
    Larzzzz
    Larry
    MA
    Thankfully I passed. It was listed on the report i got and have never seen it before
  6. Aug 23, 2019 at 4:34 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    In NC, for example, vehicles prior to 01 can have up to 2, Not Ready codes. These systems are the ones associated with EPA emissions. Newer than 01, you can only have one, Not Ready code.
  7. Aug 23, 2019 at 4:47 PM
    Larzzzz
    Larry
    MA
    @PzTank no it doesn't tell me... Those are actually 3 numbers in hexadecimal format. Base 16 vs our base 10 decimal system. 7F hex= 127 decimal, 0A= 10 and 11= 17. Confusing to say the least...
  8. Aug 23, 2019 at 4:52 PM
    PzTank
    Above the Notches
    Huh, didn’t know of the hex equivalents... Thanks.:D
  9. Aug 23, 2019 at 4:55 PM
    Larzzzz
    Larry
    MA
    Thanks for posting the stuff you did in response to my questions.
    Like that?
    Jimmyh and PzTank like this.
  10. Aug 23, 2019 at 5:37 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Shot in the dark but maybe disconnect the battery and let the computer lose power.
    Do you have a scanner?
  11. Aug 23, 2019 at 5:58 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Nope. That is why they are called “permanent” codes. They can only be cleared by a complete drive cycle or the manufacturer tech stream.
  12. Aug 23, 2019 at 8:45 PM
    Larzzzz
    Larry
    MA
    From what I've read, they can only be cleared by and when the ecu is satisfied that the issue no longer exists
    PzTank likes this.
