Obd code,P0302,P0302 PD
Discussion in '1st Gen. Tacomas (1995-2004)' started by Moose984x4, Jun 29, 2016.
  1. Jun 29, 2016 at 8:47 PM
    Moose984x4
    Moose984x4 [OP] New Member
    98 Tacoma
    I just changed out the plugs and wires,ran great for about 7miles,then it started running rough and vibrations! I checked the codes again and came up with cylinder #2 misfire! What's next? 98 Tacoma 4x4 4 cylinder
  2. Jun 30, 2016 at 11:35 AM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    Hey Moose......I had the spark plugs changed on my '03 PreRunner (3.4) at the Dealership and a couple of days later had the same symptoms. I thought the transmission was going out from the vibrations and bucking like a mule.
    Took it back to the Dealership and turned out that the individual who changed the plugs torqued one down to much and the spark plug had cracked.
  3. Jun 30, 2016 at 7:11 PM
    Moose984x4
    98 Tacoma
    Thanks for the input,I will check out the spark plugs!
