O2 sensor spacer for p0420 codes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by spazjensen, Mar 15, 2023.
  1. Mar 15, 2023 at 9:58 AM
    spazjensen
    spazjensen [OP] Well-Known Member
    Here
    06 Tacoma Prerunner SR5 4cyl 5spd Manual
    3" lift with Biltein 5100's w/Eibach Coils, SPC UCAs
    I've heard and read up on using non-foulers with the o2 sensors..... my question is if there is a standard thread size/length used, or if there are different non-foulers' that I need to be looking for? Don't hate on me for asking this in a new post. If there is a thread that i missed that answers my question please post it.
    Truck is an 06' 2.7 with 200k+ miles. I'm not wanting to put a lot of money into fixing emissions in a state that doesn't require testing. I've already confirmed I need new o2 sensors, but I'm not replacing the cat with another cat....just a resonator pipe, and will be installing both o2 sensors with this anti-fouler method.
    I found these on Amazon, but I'm not sure if it's what I'm needing to use:
    https://www.amazon.com/Dorman-42004...5c06a1a74d&pd_rd_i=B000BYGJQY#customerReviews
  2. Mar 15, 2023 at 10:34 AM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    ok for legal purposes, I'm not saying you should use a nonfouler to work around cat codes, but if you were working around that way. you may need to open up the nonfouler with a drill bit to fit the O2 sensor into the base a bit. they also make ones that put the sensor at a 90deg and are made for this specific purpose.
  3. Mar 15, 2023 at 10:34 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    M18x1.5
    spazjensen[OP] and TnShooter like this.
  4. Mar 15, 2023 at 3:24 PM
    spazjensen
    Here
    thanks guys for responding. it was mainly the thread and diameter i was concerned about.
  5. Mar 18, 2023 at 9:48 AM
    spazjensen
    Here
  6. May 21, 2023 at 7:58 PM
    Cleahy
    Cleahy Member
    Canon
    09 TRD Sport
    Does anyone have any recommendations for ones that worked?
