O2 sensor rusted bolts
Discussion in '1st Gen. Tacomas (1995-2004)' started by kiingme413, Oct 24, 2023.
  1. Oct 24, 2023 at 1:55 PM
    kiingme413
    kiingme413 [OP] Member
    So went to change my o2 sensor because I got the code for it and my truck is starting to give the signs . A little hesitation when driving . Air flow doesn’t feel right . Anyway . I went thru the steps on un plugging the sensor under the passenger seat . With my luck it’s attached to 2 studs with bolts at the end . But as you’ll see it’s completely rusted . I have no idea what to do . I seen previous forums on o2 sensor and using a craftsman lock out kit and getting it out but I don’t have nothing really to grab on to . This old rusty son of a b has caused me so many issues lol.
  2. Oct 24, 2023 at 1:56 PM
    kiingme413
  3. Oct 24, 2023 at 1:57 PM
    kiingme413
    Hear some better angles of it . Tried to put a video but that didn’t work . Thinking maybe a torch ?
  4. Oct 24, 2023 at 1:58 PM
    kiingme413
    This is the downstream o2 sensor on a 01 Toyota Tacoma non 4x4
  5. Oct 24, 2023 at 2:33 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Perhaps this:
    https://www.amazon.com/gp/product/B01GKEBG9I/
    I used it to remove a sensor bolt that had snapped in half.
    Could also try heat. Torch it... with care of course.
    Can also find extractors at the local hardware or auto parts stores.
    Granted I had more threads showing on the snapped stud I was dealing with, this is what it looked like. The extractor made short work of it. Came out clean. Of course I was dealing with quite a bit less rust than you have.
    unstpible likes this.
  6. Oct 24, 2023 at 2:43 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Rusty Taco 11 likes this.
  7. Oct 24, 2023 at 5:07 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  8. Oct 24, 2023 at 6:28 PM
    O'Silver_Taco
    MD
    It looks to me like those studs are welded/brazed in there....
    It might be easier to try just to screw the sensor out.....
    does the new one screw out of that plate??
    .....messing with any of that could crumble away......
    Or are you faced with replacing that back half of exhaust anyway in next few years.
  9. Oct 24, 2023 at 6:34 PM
    grizzlypath
    grizzlypath Member
    Zac
    1996 Tacoma
    OP those studs normally have nuts holding the O2 flange on, yours are totally gone and the stud is disintegrating.
    Tricky call and may require more fab abilities than you have available to you, but I would probably try to just pry the O2 sensor/flange off. Then I'd probably try to use vice grips or something to rotate the studs out of the exhaust and install new studs if possible. If they don't want to come out then you may have to get creative with heat and/or weld to bust them loose. Possibly re-tap the hole or something.
    Rust!
  10. Oct 24, 2023 at 7:44 PM
    foresterfields40
    foresterfields40 Active Member
    ‘99 Tacoma 3.4 4x4
    50/50 mix of ATF and acetone. Let it soak
  11. Oct 24, 2023 at 8:02 PM
    Currygoat
    Currygoat Well-Known Member
    Bay Area, California
    2002 Tacoma 2.4 5 Speed
    Rims, 4600 Bilsteins, K&N filter
    Heres everything you need to know:
    https://www.tacomaworld.com/threads/old-oxygen-sensor-removal.736791/#post-26228869
    I went through the same thing and tried lots of things (soaking in pb blaster, heating them up, cursing at them) but the nuts were completely rusted round and merged with the studs. In the end I bought a small file and filed two sides of the nut flat so I could get a wrench around them (see attached image). They came right off.
    Most of your nuts are gone so all you have to do file down one side till you hit the stud and then pry/knock them off with a flathead screw driver. Note that you can buy new studs if you break them... but they are gonna be hard to get out.
    Kolter45 likes this.
  12. Oct 25, 2023 at 4:35 AM
    kiingme413
    So are u saying knock the studs off. And replace em?
  13. Oct 25, 2023 at 4:54 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    I'd replace the midpipe. I suspect that's what's going to happen anyway. I doubt you'd ever get new nuts to torque down on those studs.
  14. Oct 25, 2023 at 8:20 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    You know the studs are threaded into the bung, and can be replaced right? Cutting the pipe out and replacing it is a bit excessive, especially since this scenario was specifically taken into consideration in the design of these parts.
    Area51Runner likes this.
  15. Oct 25, 2023 at 8:44 AM
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    Did you try to unscrew the O2 sensor from the flange ? Did it not come out and that's why you are trying to remove the flange?
  16. Oct 25, 2023 at 9:24 AM
    ridefreak
    NM
    2006 DCSB TRD
    minor tweaks
    Didn't know that, I'll still be surprised if they come out w/o snapping off but anything is possible.
  17. Oct 25, 2023 at 9:40 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    I wouldn't "knock the studs off" unless you have to, but I wouldn't be shy of filing (or grinding if you have a dremmel or die grinder) the threads closest to the o2 sensor flange.
    I would start by heating cycling the studs a bit while taping on them. Not so heavily as to bend them, so maybe straight down them if possible. Heat + impact should free them up. Then get a screw driver or pry bar between the o2 sensor flange and bung. It really shouldn't take much.
    Once you have the sensor out, the two studs are threaded into the bung. PB Blaster (or 1 part acetone + 1 part ATF), let it sit, tap the studs again, heat the bung (not the stud) and try to remove the studs. File flat spots onto the studs so you can get vise grip on them.
    Currygoat likes this.
  18. Oct 25, 2023 at 7:14 PM
    babylon5
    David
    Of you can try wire brushing what remains of the studs and weld on a new nut. That combines with heating of the studs closest to the actual exhaust pipe might do it.
  19. Oct 26, 2023 at 7:39 PM
    Currygoat
    Dont knock the studs off :). File down the nut so one side is open and free. Then you can pry/knock the nut off. Here is a bad example but illustrates the concept. This guy went too far using a grinder but you get the idea.
    Andy01DblCabTacoma likes this.
  20. Oct 27, 2023 at 2:56 AM
    phoforbreakfast
    phoforbreakfast Well-Known Member
    A muffler shop usually uses oxygen and acetylene to heat it up before removing it. I've tried using MAP gas before and it's still not hot enough.
