O2 sensor nuts
Discussion in '1st Gen. Tacomas (1995-2004)' started by Old metals, Aug 29, 2023.
  1. Aug 29, 2023 at 4:00 AM
    Old metals
    Old metals [OP] Well-Known Member
    02 x-cab 4x4 2.7 2018 TRD Sport 4x4 3.5
    Original
    Just curious, has anyone found a way to keep these from rusting? Along with the studs also. Also never knew to stick with the Denso brand. Now I do. Thanks to others.
  2. Aug 29, 2023 at 4:04 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Because of the thermal cycling not much you can do.
    Anything you would spray or coat the hardware with would just burn off.
    You could try going to stainless steel studs and nuts.
  3. Aug 29, 2023 at 8:42 AM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
  4. Aug 29, 2023 at 9:23 AM
    Old metals
    Original
    @noodles93 Thank you. That is what I was looking for. Didn't even know copper was an option. Thanks again
  5. Aug 29, 2023 at 4:09 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    coat em in ,,,anti seize......or that white high temp thread lock...
    not as much the nut as its the stud that turns to dust eventually....
  6. Aug 29, 2023 at 9:50 PM
    Caslon
    Caslon Well-Known Member
    2003 Base Cab. 2 whl drive. 5 speed
  7. Aug 30, 2023 at 4:08 AM
    Bivouac
    M8x1.25
    I have found by the time the O2 sensor fails the studs are going to need replaced .
    Most likely the whole exhaust system as well.
    Caslon[QUOTED] likes this.
  8. Aug 30, 2023 at 8:36 AM
    Caslon
    Not Mine! Damnit! (No whammy no whammy). Dry climate, non rust belt, USA. Much PB Blaster to be applied beforehand.
  9. Aug 30, 2023 at 9:40 AM
    Bivouac
    My first O2 sensors needed replaced around 230,000 miles .
    I just replaced the whole exhaust because I had all the parts
    I am glad your in a dry Climate and don`t need to fight the constant battle with rust.
  10. Aug 30, 2023 at 10:21 AM
    Caslon
    Your cone heater element lasted a freakish amount of time. My PO131 CEL code indicates it’s the O2’s heater fail (at 123k). 230,000 miles? Unreal. Some report factory installed fail at 45K! They lament…”why is that?” You got lucky. Me? Lasted 123k.
  11. Aug 30, 2023 at 10:27 AM
    Bivouac
    About time I have good luck for once.
    Maybe sensors and Cats were better in 2000.
    I have had PO420 codes from leaking gaskets the only issues.
    Other then pulling the front sensor harness out with the transmission.
  12. Aug 30, 2023 at 10:59 AM
    Caslon
    Connectors…heh. 15 minutes to get the sensor nuts off, 35 minutes to unbuckle the harness connector.
  13. Aug 30, 2023 at 11:18 AM
    Bivouac
    There was no need to disconnect the harness connector that pulled apart just fine .
    Found a 4 pin male and female connector soldered and heat shrink the top truck side connector on with lots more length.
    Drop it down put the new connector on the O2 sensor side plug things in secure away from the exhaust no need to remove any rusted nuts or studs.
  14. Aug 30, 2023 at 11:49 AM
    Caslon
  15. Aug 30, 2023 at 11:59 AM
    Bivouac
  16. Aug 30, 2023 at 12:24 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
  17. Aug 30, 2023 at 12:53 PM
    Bivouac
    Been there buy Never seize by the case .In 3 different flavors .
    Around Here on exhaust it might help break your nut loose it does not keep the studs from deteriorating or the nuts from thermal cycling and winter chemicals.
    It goes on everything but engine internal hardware.
    It never hurts.
