O2 Sensor Lean
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gunmaker96, May 28, 2020.
  1. May 28, 2020 at 6:41 PM
    Gunmaker96
    Gunmaker96 [OP] Member
    Been having issues with my 2012 2.7L 4cyl manual Tacoma. It’s been surging/ jolting for a bit without a code and it was driving me nuts. Replaced the plugs and didn’t help. It finally threw a P2195 code for the O2 sensor stuck in the lean condition. From the way the truck is running it does seem to be an air/fuel issue. Has anyone else had this? I’m thinking 1)bad o2 sensor, 2)bad MAF sensor, or 3) leak in air intake somewhere. Any help would be appreciated.
  2. May 28, 2020 at 6:43 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    How many miles on engine and plugs?
  3. May 28, 2020 at 6:45 PM
    Gunmaker96
    Engine at 107xxx plugs are brand new
  4. May 28, 2020 at 6:47 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    What brand plugs?
    whatstcp likes this.
  5. May 28, 2020 at 6:48 PM
    Gunmaker96
    Bosch
  6. May 28, 2020 at 6:49 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    You changed the plugs yourself? Allotta questions, I know
  7. May 28, 2020 at 6:51 PM
    Gunmaker96
    Yup. My mechanic hooked up his computer to it afterwards and they were all firing fine. The problem was the same before and after I changed the plugs.
    Steves104x4[QUOTED] likes this.
  8. May 28, 2020 at 7:02 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  9. May 28, 2020 at 7:02 PM
    Gunmaker96
    hoverlover and gasgasman like this.
  10. May 28, 2020 at 7:02 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    There is part of your problem.
    Bosch I garbage.
    Aside from that, while it is unlikely your plugs are the main contributor to your issue they can and will be an issue nonetheless. Toyota likes Denso/ NGK plugs.
    You may want to get smoke checked for vacuum leaks because that indicates a stuck rich or lean scenario (I can't remember which) either way, you have to rule out vacuum leaks and incorrect MAF reading issues. Your next step would be to check fuel pressure to make sure that is okay as you have a 2012 and the pumps on 12-15 Tacomas were bonafide garbage as well.. you have to rule out fuel delivery issues entirely because it is likely that air fuel sensor is fine and it is just reporting an air fuel issue it is seeing further upstream.
  11. May 28, 2020 at 7:05 PM
    Gunmaker96
    I’m not sure there is a way to check fuel pressure on my engine without cutting any lines. If there is a way to do it that’d be great.
  12. May 28, 2020 at 7:19 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    There is a quick disconnect fitting Right in the engine bay. o_O You can literally pull it off with your hand.
    Disconnect the fuel pump relay, give it a crank and wait until the engine dies and then disconnect the line to check your fuel pressure at that fitting. It should be on drivers side close by to the brake booster (most likely) V6 runs the lines there, I4 may be a different story.
  13. May 28, 2020 at 7:21 PM
    Gunmaker96
    I’m not sure that there’s the qd on the 2.7..
  14. May 28, 2020 at 8:51 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Do not dead head the fuel pressure into a gauge it will give you readings that are too high and incorrect.
    Instead of the intelligent tester you can run the fuel pump by starting the engine.
    Pressure should be between 40.8 to 41.7 psig
    Maybe this will help:
  15. May 28, 2020 at 9:10 PM
    Gunmaker96
    I’ll give it a try. Thanks
  16. May 28, 2020 at 9:41 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I'd just put a sensor in it.. of you had a fuel pressure problem or an air leak it would be setting a 171
  17. May 28, 2020 at 9:49 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    No it would not.
    That's the problem with diagnosing without facts and just throwing the parts bin at it, you wind up spending a lot of money that may not even be necessary. Codes on a Toyota are usually just a symptom code, it is not the actual cause of the issue most of the time..
    I have had a downstream oxygen sensor code which wound up being the head gasket.
    It's not black and white with these vehicles sometimes. Most of the time on Toyota actually. He needs to rule out the basics and ensure proper fuel supply because an air fuel ratio sensor stuck rich could be a lot of things.
  18. May 28, 2020 at 10:04 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Theres more than 1 oxygen sensor in the exhaust stream though. An upstream issue would cause both sensors to get stuck lean. Thats an advantage to having multiple sensors, they can cross check each other.
    When both sensors see a persistent lean issue it usually sets a p0171
    The computer will do self-check strategies where it will drive the system lean in a hurry and then see if both sensors reacted at the same time and in the same direction. If one reacts and the other doesn't the computer notices. It will also do it in the rich direction. those are the p2195 / p2197 (stuck rich/ stuck lean)
    The code is not trying to tell you the whole system is stuck lean, its trying to tell you that a specific sensor is stuck lean, even for just a few seconds. This is in the same family of codes as "sensor slow response" and it means the same thing, replace the sensor.
    A 5 minute test drive with short/long term fuel trims pulled up on a scan tool would tell if you had a fuel pump problem or an intake leak.
    If anything, I'd look for an exhaust leak near that sensor, but thats about it.
  19. May 28, 2020 at 10:59 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's what you think... I understand how the computers strategy works.. and honestly.. the code means nothing. It's a reference starting point more often than not, nothing more. This has been most often the case on Toyota more than any other brand I have ever dealt with. GM coming in close second.
    You really gotta check the basics before you start replacing crap. I don't mean you I just mean in general. It just leads to a lot less heartache, more cash in your wallet and it makes for a more thorough, better educated, well informed mechanic who knows without a doubt in their mind that one section or another is known good and has been tested to confirm that. It separates the YouTube mechanics from the real mechanics.
    Might it be the sensor? Yeah.. anything is possible, but when it comes to lean and rich issues involving codes like that, what I have learned over the years is that it's all out on the table, especially when the indicated drivability symptom is surging.
    If the air fuel ratio sensor is stuck lean, don't you think that there may be a whole lot of other crap above it potentially mudding up fuel control? I have had that exact code before on my own piece of junk and you know what was causing it? A cloggage of EVAP flow in the canister every time I would fuel up. I darn sure was not surging though, and it sure wasn't the air fuel ratio sensor either, but you see where I'm getting at I hope.
    Do me a favor @Gunmaker96 pull the mode 3 freeze data for me from the scanner if you can. What is your indicated short term and long term fuel trim data?
  20. May 28, 2020 at 11:07 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    You're saying you fixed a p2195 by replacing/unclogging the evap canister?
    12TRDTacoma[QUOTED] likes this.
