o2 sensor gas mileage
Discussion in 'Performance and Tuning' started by Rhino, May 30, 2011.
  1. May 30, 2011 at 12:10 PM
    Rhino
    Rhino [OP] Well-Known Member
    Laurel, Mississippi
    03 TRD SR5 4x4
    gray wire mod, blacked out, debadged, toolbox foglights, cb in dash, system, bilstein 5100's in front wrapped in eibach coils, 5125's in the rear with 2 inch aal and 1 inch shackle, diff drop kit, extended rear brake line, 8000 lb smittybuilt winch on a custom winch bumper, 2 4 inch 100 watt kc's and 2 6 inch 100 watt kc's on the bumper, sometimes a ladder rack,much more to come
    my o2 sensor went bad in my truck would this have any effect on my gas mileage?
    :confused:
  2. May 30, 2011 at 8:59 PM
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    As far as I know the O2 sensor is just there to make sure the more emissions are going into the air that are needed. So I believe it helps relay information for the fuel injectors of the vehicle regarding rich/lean. So yes.
  3. May 31, 2011 at 9:22 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    It will run like crap. The ECU goes to a preset fuel mix. It will run, but will kill the cats.
  4. May 31, 2011 at 9:24 AM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    When mine went out I got 14 mpg! Just replace it
  5. May 31, 2011 at 9:42 AM
    Rhino
    Laurel, Mississippi
    03 TRD SR5 4x4
    thats exactly what im gettin!! ive heard that if i pull it out and wipe the end off it will start working fine again does anybody know if its true? also its my rear sensor thats bad would it still hurt my cats?
  6. May 31, 2011 at 9:49 AM
    98tacoma27
    Ben
    Not Beech Creek
    No, that will not help. The rear just monitors the CAT performance. The front O2 (AFR sensor) is what monitors the air to fuel ratio. No, a bad rear O2 won't hurt the CAT. I ran with a bad one on my 98 2.7 for over a year with out a CAT problem.
  7. May 31, 2011 at 10:00 AM
    Rhino
    Laurel, Mississippi
    03 TRD SR5 4x4
    then i'll need to replace both cause the front also went bad and we wiped it off and the check engine light went off so we thought it was fine.. thats what i planned to do to the back but i thought it a little fishy that toyota would let something like that happen
  8. May 31, 2011 at 10:07 AM
    98tacoma27
    Ben
    Not Beech Creek
    Look at Rockauto.com. Get the Denso OEM replacements and use rockauto's member discount to save a few extra pennies. Theier discount code can be found in their vendor section on the site.
  9. May 31, 2011 at 5:06 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Running with a bad o2 means you will be running rich. It will make the cat work harder to burn the extra fuel. It will shorten its life. It can also set your truck on fire, since it will be running hotter than normal.
    Don't wait, or try to fix the bad one, replace it.
  10. May 31, 2011 at 6:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Ive never heard of that setting a vehicle on fire....link to reports?
  11. May 31, 2011 at 6:45 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Parking in grass, fuel leak, undercoating will burn,etc. I don't have any links, just stories from reputable sources, and the knowledge that excess fuel to the cat will burn. It will glow red, and will set flammable things on fire. The degree of danger is directly related to how much extra fuel it's getting.
    80's GMC trucks had this problem with the truck running properly. It was a problem with the catalyst type(pellets).
  12. May 31, 2011 at 6:52 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
  13. May 31, 2011 at 7:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im well aware of how they work. Yes, If you drip fuel on them, that CAN cause the truck to burn up, but that wouldnt be something caused from running rich. And they DO get hot. Temps around 1400* during normal driving are normal (on the first set), but there is shielding to prevent anything under the truck catching fire.
  14. Jun 1, 2011 at 4:19 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    You failed to go to the bottom of the article. Thermal failure from excessive fuel will cause the substrate to melt... This goes well above the normal operating temp. Shielding will only help so much. The heat has to go somewhere. No air circulating after driving, or stuck in traffic, what are the odds of a fire now?
  15. Jun 1, 2011 at 4:27 AM
    98tacoma27
    Ben
    Not Beech Creek
    Still very slim............
  16. Mar 6, 2024 at 9:14 AM
    mark06yoda
    mark06yoda Well-Known Member
    marcus
    2006 Black Tacoma TRD Sport DCSB MT
    hey man i seen your post in 2011 about getting 14mpg with bad 02, which o2 did you replace to fix this the upper A/F ones or lower (downstream) ones
  17. Mar 6, 2024 at 9:18 AM
    VoodooBlueATL
    VoodooBlueATL Well-Known Member
    2007 FJ Cruiser
    I'm not the OP, but the rear downstream sensors will not affect fuel mileage. The front upstream sensors will, though. Stick with OEM denso sensors from a reputable source (not ebay or Amazon). Most go through Rock Auto.
    tacomakid96 likes this.
  18. Mar 6, 2024 at 11:46 AM
    mark06yoda
    marcus
    okay thanks man i also have lots of exhaust leaks. do you think getting new a/f ratio sensors would somewhat increase my gas mileage even though my exhaust has leaks?
  19. Mar 6, 2024 at 12:20 PM
    VoodooBlueATL
    2007 FJ Cruiser
    If your exhaust is leaking at the manifolds or before the cats, you'll likely still have issues even with new sensors. If you leaks are towards the back, that shouldn't affect mileage.
  20. Mar 6, 2024 at 1:19 PM
    mark06yoda
    marcus
    right after the first upstream cat on both sides flanges are leaking on the bottom flange i don’t think the actual manifold is leaking, so what would you think about that, i think the cats are still good though i hit them and didn’t hear anything rattling inside
