O2 Bank 1 replaced
Discussion in '1st Gen. Tacomas (1995-2004)' started by Snowman422, Oct 3, 2018.
  1. Oct 3, 2018 at 4:55 PM
    Snowman422
    Snowman422 [OP] Member
    Todd
    2003 4wd Tacoma
    Had check engine lite activate. Got checked at Autozone was told I had code P0402. They have me a print out saying the O2 sensor Bank 1 need to be replaced. I replaced it. Do I need to clear the check engine lite some way to get it to turn off or could there be another problem?
  2. Oct 3, 2018 at 5:03 PM
    E30325
    E30325 Well-Known Member
    Nick
    2000 Tacoma TRD 5spd
    5100's and OME 881's, AAL and KM3's
    If you unplug the battery for a few minutes it will clear the code. If it comes back after that then you have another problem. I think it should self clear after a few drive cycles or a certain amount of miles too, but I'm not sure how long
  3. Oct 3, 2018 at 5:15 PM
    Snowman422
    Todd
    2003 4wd Tacoma
    Excellent. I'll give that a try. Appreciate the advice.
    E30325 likes this.
  4. Oct 4, 2018 at 5:21 AM
    FloridaAKM
    FloridaAKM Active Member
    Alan
    2004 Green 4WD Tacoma V6 TRD
    LED headlights
    I had the same situation with the code P0031 which translates to HO2S Heater Control Circuit, Low Bank 1 Sensor 1. After ordering a sensor from Toyota & installing it, I disconnected the battery for 5 minutes. That cleared the CEK warning light & it stayed off. Disconnecting the battery before changing the sensor & reconnecting it, would turn the CEL off, but it would come back on after a few minutes of operation. The electrical plug connection is a bear on a 2004 gearbox taco as it is on top of the transmission, bolted down. Good luck with your problem.
  5. Oct 6, 2018 at 3:06 PM
    Snowman422
    Todd
    2003 4wd Tacoma
    Well cleared the check engine light and all seemed good. After driving for couple of miles the light came back on. Guess I'm back to checking codes.
  6. Oct 6, 2018 at 4:30 PM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    I'm sorry to hear, but your first mistake in my book is listening to Vato Zone,,, the code just points to the direction of the problem not the exact source. Plus, even it is the O2 sensor, I don't think the aftermarket one will work good enough to satisfy the computer, if it does, not for long. I would diagnose the issue, look at a flow chart in the FSM for the code, that'll help you out.
    Brie likes this.
  7. Oct 7, 2018 at 7:03 AM
    FED Driver
    FED Driver New Member
    Dave
    2004 Red Tacoma TRD
    Stock 3.4L
    Hi - I'm Dave and live in Saugus, CA, driving a 2004 Tacoma extended cab 2-wd with 3.4L engine. Purchased this truck new in So. California, it now has 114,750 miles on the odometer.
    Three weeks ago, the CEL threw a P-0031 code, indicating a bad up-stream A/F Sensor. The bad sensor Toyota p/n 89467-35060 was removed. The OEM replacement starts at $196 on Amazon, $280 at the dealer, but many vendors on Amazon, Ebay, auto parts stores and posts state that the Denso p/n 234-9001 is a valid replacement for the OEM Toyota part. NOT so.....
    I purchased the Denso part and installed it. The truck CEL extinguished, but the engine surged and pulsated at all speeds. Not good. A replacement Denso unit was sent, installed, and with the same results. Not really driveable, but the CEL lite was OUT.
    Last week I bit the bullet and ordered the OEM Toyota part number 89467-35060 for almost $200. In ten minutes it was installed and the truck runs like new.
    Hope this helps someone in a similar predicament.
    T4RFTMFW likes this.
  8. Oct 7, 2018 at 7:35 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Welcome to TW.
    I think you should show us that dragster. :burnrubber:
  9. Oct 7, 2018 at 9:52 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Denso A/F sensor 234-9001 is for the regular, no CARB required Tacomas, and is routinely used as correct replacement sensor. The Cali CARB compliant Denso part number, I believe, is 234-9002 or 234-9003. Sorry you missed out on the money savings with this. It's definitely not easy to find this info.
    But you are correct, 234-9001 is not a replacement for 89467-35060.
    Brie likes this.
  10. Oct 8, 2018 at 8:15 PM
    FED Driver
    Dave
    2004 Red Tacoma TRD
    Stock 3.4L
    Thanks cruiserguy
    I thot I had researched this, but what you say is exactly what my Toyota dealer friend surmised, and that is that California trucks are different. Would appreciate info as to which Denso part is the one to use in this case, either 234-9002 or 3....for the future and others here in California. Not only do we in California get to purchase the expensive sensor, we also pay a buck or more per gallon for gas and $100 more per year for registration! The plus in all this is a high-speed rail system that we desperately need!!
    Hey T4RFTMFW
    For info on my second dragster, take a peek at http://www.frontenginedragsters.org/photos3.htm and don't believe everything about the hacksaw! My article was edited by someone else. Sure was fun building and driving these beasts. Then I put twin turbos on the 327" in my Model A tudor, seen at
    https://www.theturboforums.com/threads/1931-ford-tudor-327-sbc-twin-turbo.375157/ ....the fastest street car I ever owned or driven.
    Have spent a lot of time trying to figure out how to put a turbo on my 2004 Tacoma 3.4L. Everything is easy from scratch to weld, mount, and the downpipe/exhaust is simple, but to retard the ignition when it goes into boost is not easy to do, controlling the fuel delivery is complicated, and it would never pass CA smog. I'm spoiled because of the Model A project shown in the above link.
    cruiserguy, Brie and T4RFTMFW like this.
  11. Oct 8, 2018 at 8:18 PM
    T4RFTMFW
  12. Oct 8, 2018 at 8:42 PM
    Bentrodder
    Bentrodder PeeRunner Fanboy
    Peter
    Cotati, CA.
    2015 DCLBFTMFW TRD Sport
    Kings and a TW DECAL!!!
  13. Oct 31, 2018 at 4:09 PM
    Snowman422
    Todd
    2003 4wd Tacoma
    Well lesson learned I think. Replaced the bank 1 sensor with a Denso. Was able to drive briefly and check engine lite came on. Had it checked again was told catalytic converter was bad. Had new on installed. Drove briefly and lite came back. Checked it again and said senator in bank 2 was bad. So replaced that sensor with a Denso. You guessed it check engine came back on after about 10 miles of driving. Not had it checked yet so not sure what might wrong but after the fact research makes me think the Denso sensor or sensors may have failed. Seems Densos are known for failure. If it is the sensors guess I'll go with OEM unless I find that something may have caused it to fail.
  14. Oct 31, 2018 at 4:34 PM
    cruiserguy
    Elijah
    SEKS
    Denso makes the OEM sensor for Toyota.
    So when the malfunction indicator lamp turns on, it never says something like 'sparkplug #3 is bad, replace it' or something like that. The ECM can't know a part is bad or good. It only monitors the values of that certain system through sensors. So for example, your MIL turns on and you get the code read, it will say a specific code and that specific code number is important. Let's say you get P0402, this means 'Exhaust Gas Recirculation Flow Excessive Flow Detected'. It doesn't mean the EGR valve is bad, per se, it specifically means the ECM, for some reason, got a value of EGR flow that was higher than it's programmed range. There can be many signals from many sensors that go into that decision to trigger the MIL.
    I guess simply saying, if the MIL is triggered by a reading from a sensor, (02 sensor, temp sensor, etc) it doesn't necessarily mean that sensor is bad. It can be, but correlation doesn't always equal causation. Sorry for the novel.
    Brie likes this.
  15. Oct 31, 2018 at 6:40 PM
    Snowman422
    Todd
    2003 4wd Tacoma
    Thanks cruiserguy for the explanation of how it works. I'm capable of doing the physical part of the repairs but not so much up on the theory behind. I'm going to get it checked again and see what comes up now. I'm hoping it comes up with a different code than before, I would rather spend the money to replace a different part than replace something already replaced once already.
    cruiserguy likes this.
  16. Oct 31, 2018 at 6:45 PM
    cruiserguy
    Elijah
    SEKS
    Sounds like a solid plan, let us know what the code is when you find out:thumbsup:
  17. Nov 1, 2018 at 3:12 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    According to the Denso website:
    234-9001 is for Automatic transmission
    234-9003 is for Manual transmission
    Their site does not show 234-9002 as a part available for my 2003 / Toyota / Tacoma / 3.4L, but if I search for that part number it comes up. It does not show details about the application.
  18. Nov 1, 2018 at 3:28 PM
    cruiserguy
    Elijah
    SEKS
    Cool. So the 234-9002 might be the sensor for Cali emissions spec tacos?
  19. Nov 1, 2018 at 4:04 PM
    JasonLee
    15 TRD OffRoad
    Not sure about that. It's looking more like the 234-9002 is for the 4-cylinders...
  20. Nov 4, 2018 at 9:34 AM
    Snowman422
    Todd
    2003 4wd Tacoma
    Well had codes reset after replacing both banks O2 and the catalytic converter. Light was off. Drove approx 5 miles and it came bac on. Had it scanned again and code says bank 1 O2 sensor circuit malfunction. Any suggestions as to what might case the O2 to malfunction?
