Nut size & thread pitch for the UCA bolt? Also, washer size for the Icon UCAs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JVL1985, Jul 31, 2023.
  1. Jul 31, 2023 at 12:30 PM
    JVL1985
    JVL1985 [OP] Well-Known Member
    2019 Tacoma Double Cab, short bed,4x4, v6, TRD Off-road
    Long story short. I felt some weird play in my steering. Took a look at my Icon UCAs and the nut, washer, and one side of the bushing are missing from the driver side! I just need to limp the truck back home so I'm hoping I can at least pick up the nut and washer at a hardware store. I ordered the bushing replacement from Icon but it doesn't come with the washers or the nut. I'm hoping if you guys can give me the exact size of the nut and bushing I can source them from the local fastenal or someplace similar. Just to get me back home.
    Edit: Thanks for everyone's help on here. You guys are great. Because of all of you I got the exact parts I need to get my truck home. Where I can wait for the bushing kit and finish the job right. Looks like the nut and washer I got will work perfectly fine as a permanent solution. No need to get the factory nut. Thanks again.
  2. Jul 31, 2023 at 12:42 PM
    PacoDevo
    PacoDevo Well-Known Member
    Pops
    Bazetta Twp. Ohio
    2016 SR5 DCLB white "Quinn the Eskimo"
    NOT trying to be a smartass, but if it is a Toyota part - call a dealer and ask them?? If actually an Icon part, call them??
    Chew likes this.
  3. Jul 31, 2023 at 12:44 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Assuming the UCA bolt is installed in the stock direction and thus a PITA to remove, you could remove the nut from the opposite side, take it to the parts store, and ask them for a comparable replacement.
    I also don’t think I would trust a random hardware store for a safety sensitive automotive part like a UCA bolt nut. But in a pinch…
  4. Jul 31, 2023 at 12:49 PM
    JVL1985
    The dealer says it's not in stock and they have to order it. They also claim to not know the size or thread pitch so that I can source it elsewhere. And to order it they charge like $20 for a little bolt. I onow I can get the washer and nut at fasenal for like $3. Just need the to know the size.
  5. Jul 31, 2023 at 12:51 PM
    JVL1985
    A place like fasenal will have bolts nuts at different grades. I'd imagine I could get aircraft and spaceship rated bolts if I wanted too
    SR-71A likes this.
  6. Jul 31, 2023 at 12:51 PM
    gudujarlson
    Minnesota
    Price should not be your concern in the situation I understand you to be in.
  7. Jul 31, 2023 at 12:51 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If the bolts are the same diameter and pitch as factory, I think they are M14x1.5 fine thread.
    But I have no idea if Icon uses the same bolt/nut size.
    gudujarlson likes this.
  8. Jul 31, 2023 at 12:53 PM
    gudujarlson
    Minnesota
    I’m not familiar with fasenal. If they sell quality products, I think you are good to go.
  9. Jul 31, 2023 at 12:54 PM
    JVL1985
    When the fasenal is closer than the dealership and probably a tenth of the cost for the same thing.
  10. Jul 31, 2023 at 12:55 PM
    TnShooter
    Deogee
    STOCK
    Fastenal is good.
    But don’t be surprised if they are more expensive than the dealership.
  11. Jul 31, 2023 at 12:55 PM
    gudujarlson
    Minnesota
    Distance seems important to me too
  12. Jul 31, 2023 at 12:55 PM
    JVL1985
    Icon uses the factory bolt. Thanks. Exactly what I needed
    TnShooter[QUOTED] likes this.
  13. Jul 31, 2023 at 12:59 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Are you talking the big long bolt that is a PIA to get out of the truck>? Runs behind the coilover through both UCA pivots? I can go measurement mine if you're really in a jam though I bet @TnShooter is right
    Chew and TnShooter like this.
  14. Jul 31, 2023 at 12:59 PM
    Toolndie7
    Toolndie7 Well-Known Member
    2019 Sport DCSB Cavalry Blue
    from their website.
    Edit, too slow
    Chew and JVL1985[OP] like this.
  15. Jul 31, 2023 at 1:11 PM
    SR-71A
    Zack
    Southern Maine
    I just measured, M14x1.5 is correct. Hex size is 19mm, not that that really matters in this instance
  16. Jul 31, 2023 at 1:13 PM
    TnShooter
    Deogee
    STOCK
    Nice. I’d suggest a flanged nut like they use from the factory.
    But a nut and washer will do in a pinch:thumbsup:
    JVL1985[OP] and SR-71A[QUOTED] like this.
  17. Jul 31, 2023 at 1:15 PM
    gudujarlson
    Minnesota
    Yay, Tacomaworld! Sometimes we help the peoples.
    TnShooter, JVL1985[OP] and SR-71A like this.
  18. Jul 31, 2023 at 1:43 PM
    JVL1985
    Thanks! But I got the size form another person on here.
    Actually that other person was you! Thanks a ton. exactly what I needed!
    SR-71A[QUOTED] and gudujarlson like this.
  19. Jul 31, 2023 at 1:44 PM
    JVL1985
    Yes! Thanks you !
  20. Jul 31, 2023 at 1:45 PM
    JVL1985
    Perfect! I don't know why I couldn't find that. Probably because I'm on my phone and everything seems to be moving slower for me. But thank you. exactly what I needed
    SR-71A and gudujarlson like this.
