Novice...33s with a 3" lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chenzo1990, Feb 23, 2018.
  1. Feb 23, 2018 at 1:10 PM
    Chenzo1990
    Chenzo1990 [OP] New Member
    Vincent
    2010 White Tacoma Pre-runner
    Don't know to much about truck, never the less my own. I have a 2010 Toyota Tacoma V6. P245/75/r16.
    I look at some of these Tacoma and like the look of a lifted truck with all terrain tires. I'm looking to go for a 3" lift with 33 size tires. Only I really don't want to have to cut anything or trim. So if it is possible to run 33s on a 3 inch lift without having to cut or trim I would like to know. Also, if not I would like maybe a recommendation on what I could go with as far as a lifted truck with all terrain tires. I'm just looking for Asteics here. Don't ever take my truck out off roading. Thanks in advance for any replys.
  2. Feb 23, 2018 at 1:14 PM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
  3. Feb 23, 2018 at 1:17 PM
    CaliforniaTacoTuesday
    CaliforniaTacoTuesday Well-Known Member
    Sounds like something like this may be what you're looking for.
    austin2009, Mully, 4drtaco03 and 10 others like this.
  4. Feb 23, 2018 at 4:10 PM
    Chenzo1990
    Vincent
    nailed it!!!
    Mully and Pigpen like this.
  5. Feb 23, 2018 at 4:15 PM
    R242
    R242 I have a tortoise
    Rick
    Indianapolis, IN
    2024 SR 4x4 6 spd
    That...is...noice...:muscleflexing:
  6. Feb 23, 2018 at 4:15 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    Welcome to TW! You might consider moving up to 265/75 (just under a 32 inch tire). You shouldn't rub at all with a 3 inch lift in that size. You'll likely have to trim, if only a little bit, if you run 33s. Many people run 265s here, so you can search for pics.
  7. Feb 23, 2018 at 4:17 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    I have a 2016, and I run 32.6” Tires on stock height. The 2nd Gen trucks, yours included, are 1” lower stock, so you would need about an inch or slightly over. I don’t know the specifics for your generation truck or what wheels you want to run or even what tire you’re looking at, and all are slightly different, but read up on the thread posted above. It’ll get you started in the right direction. And welcome to TW
  8. Feb 23, 2018 at 4:21 PM
    tcjacado
    tcjacado Well-Known Member
    Welcome to TW and look up a spindle lift maxtrac
    Fluffymonkey likes this.
  9. Feb 23, 2018 at 4:25 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
  10. Feb 23, 2018 at 4:27 PM
    ToyoKühl
    ToyoKühl Well-Known Member
    Aaron
    UP Michigan
    2015 DCSB OR
    OME 887 with Nitrocharger Sports and full Dakar Pack SCS Coopers 255 85 rigid industries
    The answer is 255/85/16. I run wen in a cooper st maxx with no rub evah.
    330d, Pigpen and Tocamo like this.
  11. Feb 23, 2018 at 4:30 PM
    ToyoKühl
    Aaron
    UP Michigan
    2015 DCSB OR
    Also, I'm going to a 265/75 when these run their course due to mpg loss at a 33. Love these 255s but I will be just fine with the 32
  12. Feb 23, 2018 at 4:35 PM
    Chase8059
    Chase
    ESVA
    How much of an MPG decrease would you say? I'm thinking of going from 265/70r17 to 255/80r17 in the near future.
  13. Feb 23, 2018 at 4:51 PM
    Adgrimmer
    Adgrimmer Well-Known Member
    Aaron
    Stephenville,Texas
    2015 Silver Tacoma TRD
    3 in lift, 17x9 -12 offset Fuel Krank wheels,New decals, Bull Bar,
    I have a 3in lift with 17x9. -12 offset wheels and running 265/70/17 and was rubbing the front mud flaps at full cock so I took them off. I’m sure if I goto 285s then I will have to trim some of the inner fender.
  14. Feb 23, 2018 at 4:59 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    https://www.tacomaworld.com/threads/maxtrac-spindle-lift-for-2nd-gen-prerunners.203889/ read this thread. Lots of good info and pics to learn about
  15. Feb 23, 2018 at 4:59 PM
    ToyoKühl
    Aaron
    UP Michigan
    2015 DCSB OR
    Ummm significant amount. Never did the actual calculations but I added some weight to mine as well. Winter driving, strictly "city" I get about 10.5. In the summer about 15 on a good tank. Do some research on how much weight you will be adding over stock tires at a 33, you might end up shocked. Try the 265/75 and I would put money on it you will be happy. Also check the difference between loads. Mine are E. There is a huge difference between the E, C and P load. A P loaded falken would be good for you if you are never off road
  16. Feb 23, 2018 at 5:11 PM
    tcjacado
    You might want a doctor to look at that:anonymous:
    rimmer, post: 17224830, member: 242803"]rubbing the front mud flaps at full cock[/QUOTE]
  17. Feb 23, 2018 at 5:12 PM
    jmauvais
    NorCal
    ...stuff
    A C rated tire is more than sufficient for a Tacoma. The rating for a C tire is still higher than the max tow capacity
  18. Feb 23, 2018 at 7:08 PM
    Pigpen
    Northwest Montana
    I also run this tire size. OP, this is the only "no trim" 33" tire.
  19. Feb 23, 2018 at 7:15 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Here is my latest, full steel plates and bumper, Apex side bars, 3" lift, 265x70x17, no rub, goes where I want it too.
  20. Feb 23, 2018 at 7:25 PM
    Pigpen
    Northwest Montana
    My 33s don't rub. No trimming. They go most of the places I try to go.
