Not buying new catalytic converters
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 96fido96, Dec 6, 2014.
  1. Dec 6, 2014 at 12:22 PM
    96fido96
    96fido96 [OP] Well-Known Member
    ESQ
    ONTARIO CA
    6cyl 4x4 first gen
    I live in California and my catalytic converter went out and I'm not going to replace them they are just to rediciusly expensive. So would it be ok if I just do straight pipe with a muffler would it mess with any sensors. What options do I have.
  2. Dec 6, 2014 at 12:38 PM
    racer1x
    racer1x Well-Known Member
    campbell ca
    05 Taco
    Too many
    Are you throwing codes or is the cat toast? Magnaflow makes reasonably price replacements.
    If you put a straight pipe you will throw codes unless you get 02 simulators. And you defiantly will not pass smog with no cats.
  3. Dec 6, 2014 at 12:39 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  4. Dec 6, 2014 at 12:58 PM
    el tardo
    el tardo Well-Known Member
    replace them or replace them,those are your options
    no way around it,or you just leave in your bad cats and blow out your piston rings from to much back pressure. which one do you think cost more.
    not to be a dick but this is the price we pay to live in this beautiful state!
  5. Dec 6, 2014 at 1:10 PM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
  6. Dec 6, 2014 at 1:15 PM
    96fido96
    ESQ
    ONTARIO CA
    6cyl 4x4 first gen
    Yea I have 420 code mechanics told me the cars are shot
  7. Dec 6, 2014 at 1:19 PM
    96fido96
    ESQ
    ONTARIO CA
    6cyl 4x4 first gen
    What's the damage if I l take them off
  8. Dec 6, 2014 at 1:23 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    :rolleyes:
  9. Dec 6, 2014 at 1:27 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Ok, that isn't what happens with bad cats. Cats go bad when they loose enough precious metals to not filter enough emissions gasses.
  10. Dec 6, 2014 at 1:30 PM
    smmarine
    Melbourne FL
    Before you do something, try a bottle of Cataclean on a low tank of gas. That's what I did when I got a P0420 code. O2 sensors weren't reading good readings, and now they are. Haven't had the code in over 5k miles, and my computer has passed its emissions self test.
  11. Dec 6, 2014 at 1:35 PM
    racer1x
    campbell ca
    05 Taco
    Too many
    I was throwing codes for bad cats and the dealer wanted to replace both cats, I replaced both downstream 02 sensors and have not had a problem or code since.
  12. Dec 6, 2014 at 1:37 PM
    96fido96
    ESQ
    ONTARIO CA
    6cyl 4x4 first gen
    I'll try the Cataclean
  13. Dec 6, 2014 at 2:53 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    if the cats are truly bad, you MUST go with OEM ones, as any aftermarket ones are not CA legal,
  14. Dec 6, 2014 at 2:57 PM
    96fido96
    ESQ
    ONTARIO CA
    6cyl 4x4 first gen
    Looks like I have very little options Cataclean, 02 senders, or new ones.
  15. Dec 6, 2014 at 3:03 PM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
    Move to another state?
  16. Dec 6, 2014 at 3:14 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    There are aftermarket ones that are CA legal, it does have CARB # on them. The OP didn't say which year his truck is. Newest year I see available for the Tacoma are 2004. Any newer then it has to be OEM.
  17. Dec 6, 2014 at 3:25 PM
    96fido96
    ESQ
    ONTARIO CA
    6cyl 4x4 first gen
    Truck is an 06
  18. Dec 6, 2014 at 3:32 PM
    Clearwater Bill
    Billy
    Largo Florida
    You won't pass inspection cat-less.
    You have pre and post cat o2 sensors. The rear would set a full time CEL with no cat.
    Any aftermarket cat would need to have a Cali CARB certification. There are some out there for other marquees that I'm aware of, so there may be some for Tacos.
    I'd also replace both sensors and see what happens. Cat may be fine. Unless you have a long history with a quality mechanic I'm not sure you can be fully trusting of them and your wallet.
    At the worst you're out a couple bucks for the cleaner, you'll have a new cat and sensors, making you good for a long time to come.
  19. Dec 6, 2014 at 3:32 PM
    BamaToy1997
    Bill
    Navarre, FL
    Your biggest issue with taking them of and going straight pipe is never passing smog and having to deal with that. It can get pretty pricy trying that.
    Incorrect. If a cat gets too hot then the internal components can melt. This blocks the exhaust flow through the cat and causes excessive backpressure. Usually they do not go bad because they loose precious metal. Most of the time too much carbon builds up on the precious metal, reducing the ability of the cat to properly do it's job. The precious metal is not "lost", but it can be melted by excessive temps and thus not able to do it's job that way either.
  20. Dec 6, 2014 at 3:41 PM
    Clearwater Bill
    Billy
    Largo Florida
    Of course there are legal ones.
    http://www.arb.ca.gov/msprog/aftermktcat/aftermktcat.htm
    There may not be any for his application. But there certainly Cali CARB legal aftermarket cats.
    Magnaflow, Flowmaster and EasternCatalytic all have compliant Executive Orders. There may be others.
