No tire rub till a UCA was install?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lava-road, Sep 15, 2022.
  1. Sep 15, 2022 at 11:46 PM
    Lava-road
    Lava-road [OP] Well-Known Member
    2019 trd-off road
    Hard top camper...many more to add+
    My Son’s 2016 Tacoma TRD was lifted four years ago, 275/70R/ 17. Never had any tire rubbing.
    I purchase a JBA UCA for his Birthday, We got it install a few days ago. Today I pick up his truck after a wheel alignment.
    Once we hit a bit of dirt roads , we got tire rubbing the fenders!
    What happen?
    Why NO tires rubbing for four years! After the UCA was install , tires rubbing inside fenders.
    I am guessing it has more wheel travel?
    Be aware the stock UCA may be better?
  2. Sep 15, 2022 at 11:51 PM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    You're 3 hours early for a Hawaiian Friday.
  3. Sep 16, 2022 at 12:15 AM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Jba arms add castor at the Uca, which actually pushes the tire closer to the firewall compaired to stock so thats what is causing the rubbing.
  4. Sep 16, 2022 at 1:07 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Did they use factory specs to align the truck?
    drizzoh and jeffmansion like this.
  5. Sep 16, 2022 at 1:33 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Just a thought, maybe your alignment specs are off since the new uca. Just a thought but maybe, just maybe an adjustment might fix it, but its just a guess.
  6. Sep 16, 2022 at 4:48 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    You changed the geometry of the suspension. There is no more travel than before but the travel is in a different location in the wheel well. Post up your alignment numbers. Why did you put UCA's on it to begin with?
    Edited after coffee...
    Ricardo13x likes this.
  7. Sep 16, 2022 at 4:59 AM
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    To clarify, the first poster is correct. When you put on the new UCAs, caster was increased by moving the upper ball joint BACK towards the cabin mount, thus increasing the caster angle. The 2nd poster would be correct if you were using the OEM LCA eccentrics to increase caster by pushing the lower ball joint forward, thus increasing the caster angle.
    whatstcp likes this.
  8. Sep 16, 2022 at 5:09 AM
    airforceb2cc
    Don
    KCMO
    Obviously haven't had enough coffee this morning. You are correct, sir.
    TacoSupremo19[QUOTED] likes this.
  9. Sep 16, 2022 at 6:30 AM
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    Yup, on top of the Jba's, the shop probably tried to bring the castor way down to factory spec, thus moving the wheel even further back.
    super_white[QUOTED] likes this.
  10. Sep 16, 2022 at 7:41 AM
    AusRunner
    AusRunner Well-Known Member
    Las Vegas, NV
    2021 TRD Off Road 4X4 DCSB - Cement
    Same thing happened to mine. Installed Bilstein 6112/5160 with 285/70 17 and had zero rub. Add Icon Delta Joint UCAs and rubs on tight turns or big bumps. A bit disappointed, planning for trimming and CMC to resolve.
  11. Sep 16, 2022 at 7:43 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    You have to get the alignment shop to push the wheels forward with the LCA eccentrics. It will no longer be a "factory" alignment. You need to get the caster set to about 4deg (factory is 2-2.5, and it will rub at 2-2.5)
  12. Sep 16, 2022 at 10:17 AM
    jeffmansion
    jeffmansion Well-Known Member
    16UTILITY4x4MT2.7
    K&N 63 series CAI, AVS Vent Visors, 16x8 Level 8 MK6 Rims, 285/75/16 MT, Eibach Pro lift, JBA UCAs, Wheelers 3leaf AAL, DV8 skidplate, Westin bedmat, Backrack, swaybar delete, Magnaflow cat-back, 9Drive throttle controller, 2LO Mod, Cali Raised Rock Sliders, Tyger rear bumper, Chinese Body Armor front bumper clone, 10K pound Winch, Smoked headlights, LED Bulbs.
    You need to follow JBAS alinement specs. They have their own spec guide. Have it printed out on paper in my truck.
    drizzoh likes this.
  13. Sep 16, 2022 at 10:27 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    As the others have said, they need to be realigned to have the caster increased (if you chose the high caster version). If they aligned back to factory specs you will rub 100%. With my JBA's I'm at 4.2° caster. With that tire size, any caster above ~3.5° should pretty much eliminate the rear rubbing issue, but may vary based on lift and wheel offset.
    These trucks are very finicky with alignment, after the shop aligns it, have them back it off the alignment rack to destress the suspension, then pull it back on and check again.
  14. Sep 16, 2022 at 10:35 AM
    Lava-road
    2019 trd-off road
    Wow! Great feedbacks. Thank you!
    I have the alignment papers all “green”
    I did not realize aftermarket UCA , like the JBA push the tires closer to the fender wells.
    OK next step inside fender trimmings.
    The bright red JBA’s looks “Cool”, stands out!
    Hopefully… Your answers & solutions will help future Tacoma owners when installing aftermarket UCAs. “Mahalos”
    In Hawaii every Friday is call “Aloha Friday’s”. There is even a Song written about “Aloha Fridays”
    davidstacoma, jeffmansion and drizzoh like this.
  15. Sep 16, 2022 at 11:57 AM
    CanadaToy
    Greg
    Toronto
    Nono, read the last few posts. you need a custom alignment. it will be red in portions.
  16. Sep 16, 2022 at 12:30 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
  17. Sep 16, 2022 at 1:42 PM
    Lava-road
    2019 trd-off road
    Thank you. We are just going to trim the inside fenders. Sure the video above is very convincing.
    I am wondering if it is true the video above . Why are there over a dozen aftermarket parts claiming improvements?
    Many of those well known companies have experts designing there UCAs . If the stock ones perform just as good as the AFTERMARKETS, why would there be so many UCAs on the markets?
  18. Sep 16, 2022 at 1:45 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    The big reason to change the UCA is to gain tire clearance/drivability via increased caster, increased strength, and increased articulation. JBA high caster accomplishes all 3, I'm a little bias though.
  19. Sep 16, 2022 at 2:40 PM
    Lava-road
    2019 trd-off road
    Thank-you drizzoh , for your support on the JBA UCA …. That is a picture too!
  20. Sep 16, 2022 at 3:16 PM
    gudujarlson
    Minnesota
    I think the videos I posted answer your question. Most (all?) of the aftermarket UCAs have added caster to help keep your caster in spec after a lift. Some also provide extra adjustability to allow you to more easily fit larger tires or other custom modifications. Some come with different types of joints (eg uniball) that have advantages (and disadvantages).
    Some have added clearance to fit larger coil springs and/or longer travel shocks, but the videos call that into question. It’s good to point out that the videos are not specific to a Tacoma. I think he has an FJ cruiser. It’s unclear how much applies to the Tacoma.
