No Throttle Response & Engine Light Comes On
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kiyote49, Jan 15, 2011.
  1. Jan 15, 2011 at 9:05 AM
    kiyote49
    kiyote49 [OP] New Member
    texas
    2006 Toyota Tacoma
    Hello,
    I have a 2006 Toyota Tacoma with 70,000 miles on it.
    Yesterday I started the engine and when I press on the gas pedal, nothing happens and the engine light comes on. Turn it off and on a couple of times and this problem goes away.
    Any fixes? This is NOT related to the recall problem at all. This is some kind of intermittent connection problem (electrical) I THINK.
    Thanks,
  2. Jan 15, 2011 at 9:09 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Do you have a code reader or know someone who does?
    Post the code up here, that will help a lot.
  3. Jan 15, 2011 at 9:21 AM
    Papa Tac
    Papa Tac Adjunct Anarchist
    Papa Tac
    Codroy Valley, Newfoundland
    '10 Ned Ludd Edition
    Pupped my ride - Dog bench, Black stock rims, Tail Gate antitheft mod, Bed storage and sleeping platform, Action Cap w/Yakima rack and Rola basket, Seatbelt chime off, Tentasaurus
    I had something similar in my '05 Impreza - turned out to be a loose connection on the induction coil. This after 1 garage hauled the back seat to check the fuel pump, had her for 3 days and finally towed 200km (120m) to another garage, who found and fixed it in minutes.
    Obviously I know only a little more than sfa about my rigs - I was afraid he'd try to tell me to replace the Johnson rod...gotta have that...
  4. Jan 15, 2011 at 10:17 AM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    Throttle body was probably stuck. Happened to my friends fj after sitting for awhile
  5. Jan 15, 2011 at 10:21 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What code is the CEL throwing?
  6. Jan 15, 2011 at 10:29 AM
    kiyote49
    texas
    2006 Toyota Tacoma
    Thanks! Where is the induction coil?
  7. Jan 15, 2011 at 10:38 AM
    RichardTRD
    RichardTRD Well-Known Member
    Richard
    Oregon City Oregon
    2017 Tacoma TRD OFF ROAD 4X4
    Ironman4x4 pro stage2 lift, 285/75/16 Nexen Roadian MXT tires, leer shell, Pro hood, Raceline 16x8 0mm offset wheels, prinsu cab and topper racks, FSR High country 55" RTT and Bedslide.
    Might be the tire pressure! No but really you need that code to properly track down the issue. Around here you can rent those handheld readers, at autozone I believe.
  8. Jan 15, 2011 at 10:43 AM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Yea rent it 150 bucks, cuz i work there. OP you're better off just GOING to autozone and have them read the CEL with their code reader, its free :D
  9. Jan 15, 2011 at 11:46 AM
    Marazzito
    Marazzito Well-Known Member
    Dublin, CA
    07 DC TRD Off-Road 4x4
    TRD Exhaust, AFE Cold Air Intake, URD Short Shifter, OME 886 HD Lift OME Rear Springs With XL... TRD Supercharger Coming Soon.
    I had the same thing happen to my 07 Tacoma. What happened in my case was when they did the gas pedal recall on my truck they did not reconect the throttle wire correctly. It progressively got worse until all throttle was lost and I had to get towed 100 miles to the nearest dealership.
  10. Jan 15, 2011 at 2:05 PM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    We see that in Hyundais sometimes- try the Throttle Position Sensor. If you've got a code, I have access to ALLDATA and can look it up.
  11. Jan 17, 2011 at 3:17 AM
    Papa Tac
    Papa Tac
    induction coil?
    Thanks! Where is the induction coil? - Kiyote49
    I wish I could tell you. I'm almost useless with engines, but I think on my Subie it was at least visible/near top of engine. I guess that doesn't really help at all, does it?
    Sorry, and good luck
  12. Jan 17, 2011 at 5:03 AM
    98tacoma27
    Ben
    Not Beech Creek
    Tacomas don't have an induction coil. Each cylinder has it's it own dedicated ignition coil. OP, you need to get the code read before we are able to fully help you.
  13. Jan 18, 2011 at 3:28 AM
    hogeyphenogey
    Dave
    Agawam, MA
    Go to the local parts store (autozone, pep boys, etc...) and GET THE CODE!!!
    I work in a service department and get calls like this all the time:
    "hello, is this service? "
    yes it is- how can I help you?
    "hi, yes, well my check engine lamp is on- what's wrong with my car? is it safe to drive?"
    well, there are over 150 sensors in the car- is the light flashing or just on solid?
    "listen, I just want to know if the car's ok!"
    sir/maam- just put the phone on the hood of the car and I'll diagnose it for you....
