No Start After Filling Gas
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PhotoDan, Jun 8, 2023.
  1. Jun 8, 2023 at 9:59 AM
    PhotoDan
    PhotoDan [OP] Well-Known Member
    Dan
    SoCal
    2019 TRD Off-Road DCSB 4x4
    ORA Front Bumper ORA Rock Sliders ORA Tire Carrier Bilstein 5100s front and rear OME 888 Deaver AAL SPC UCA 35" Ridge Grapplers
    2019 Tacoma with 40,000 miles would not start for 45min after filling up gas tank 2 days ago. Check engine light turned on and I have a bazillion codes. (see pictures)
    A quick online search points toward evap purge valve as the problem and solution. A local mechanic suggested the same thing. I took my vehicle system report to Toyota to see if the problem(s) might be covered under warranty. They need to diagnose ($$$) the problem before confirming or denying warranty coverage.
    I would like to gather some opinions and see what information overlaps to use as a starting point before moving forward.
    Thanks in advance!
  2. Jun 8, 2023 at 10:03 AM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Did you always top off you fuel tank when filling up? You know, after the nozzle shuts off you add more fuel a few times.
    Kolache007, SH10151, Junkhead and 4 others like this.
  3. Jun 8, 2023 at 10:08 AM
    PhotoDan
    Dan
    SoCal
    I usually do not. Once in a while, I do to round up the dollar amount to a whole number for no logical reason.
    Thanks for your time.
  4. Jun 8, 2023 at 10:12 AM
    Zuba Gooding Jr
    Zuba Gooding Jr Well-Known Member
  5. Jun 8, 2023 at 10:16 AM
    PhotoDan
    Dan
    SoCal
    I should have clarified I did not top it off this time. Not sure if that changes your conclusion. Also, do you think overfilling would cause an ongoing problem? Check engine light with all these codes still on.
    Thanks for time.
  6. Jun 8, 2023 at 10:19 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    don't do that. it damages it.
  7. Jun 8, 2023 at 10:21 AM
    PhotoDan
    Dan
    SoCal
    Lesson learned. Damages what exactly though?
  8. Jun 8, 2023 at 10:22 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    the vapor canister gets soaked in fuel and throws a bunch of codes. the charcoal from the vapor canister gets pushed up into the vent valve and now it won't close properly. i haven't had this issue but tons of others people have.
  9. Jun 8, 2023 at 10:23 AM
    Canadian Caber
    Les
    B.C. Canada, eh
  10. Jun 8, 2023 at 10:29 AM
    PhotoDan
    Dan
    SoCal
    Ok, cool. Thanks again.
  11. Jun 8, 2023 at 10:31 AM
    PhotoDan
    Dan
    SoCal
  12. Jun 8, 2023 at 10:33 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
  13. Jun 8, 2023 at 10:34 AM
    PhotoDan
    Dan
    SoCal
    Searching for parts now!
  14. Jun 8, 2023 at 10:36 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    With that many codes you can't really expect the dealer to know if it's under warranty or not. They (or somebody) needs to do some troubleshooting
    A leaking purge valve is common though, and will cause similar no start symptoms
    And yes, don't overfill the tank
    Junkhead and PhotoDan[OP] like this.
  15. Jun 8, 2023 at 10:38 AM
    PhotoDan
    Dan
    SoCal
    Agreed. I just took the truck to the dealer to see what they would say.
    cryptolime likes this.
  16. Jun 8, 2023 at 1:23 PM
    ricco333
    ricco333 Active Member
    Erik
    2021 White SR5/4x4
    Had a similar issue in my Chevy Impala, it didn't last 45 minutes but always had a hard time starting after a fill-up. It ended up being the Evaporating system solenoid, a $35 part in Amazon and easy DIY procedure after youtubing it. Get ready for the dealer to start blaming fuel injectors, that's what AutoNation did in my case.
    PhotoDan[OP], TacoSR523 and RIX TUX like this.
  17. Jun 8, 2023 at 1:45 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    what parts?
  18. Jun 29, 2023 at 4:06 PM
    PhotoDan
    Dan
    SoCal
    Part #25860-0P090 fixed my problem.
  19. Jun 29, 2023 at 4:17 PM
    oldtoyman
    oldtoyman Small bore freak
    Kevin
    North of Seattle
    1994 Harley heritage, 2017 GSXR 750, 2019 Honda monkey , 2023 klx300 , 2013 prerunner TRD off-road
    Could be a bad gas cap seal
    PhotoDan[OP] likes this.
  20. Jun 29, 2023 at 4:26 PM
    PhotoDan
    Dan
    SoCal
    Yeah, I tried replacing the gas cap first. It made no difference. I replaced the part number in my previous post. Everything is fine now.
