No power no lights on dash
Discussion in '1st Gen. Tacomas (1995-2004)' started by ekahi1, Apr 17, 2020.
  1. Apr 17, 2020 at 9:52 PM
    ekahi1
    ekahi1 [OP] CUZ I CAN
    Hilo Hawaii
    97 xcab sas baja front
    Dana 44 SAS,locker,4:88s,6" lift,16x10 weld mountain crushers, fox shocks.
    Leaving my friends house started my truck np. As I'm driving home I notice I have no tach or temp gauge, but its driving fine I get home pull in to the garage and shut it off look for lose connections nothing obvious. I go to start the truck and nothing NO dash lights not even a click from the starter nothing. The door chime and dome light stay on. Chime does not go away even when key is in on position. Checked ignition switch seams ok. Also checked ignition fuses under dash... battery is good, head lights ect. Work fine
    Kind of lost what else to check...
  2. Apr 18, 2020 at 1:47 AM
    ekahi1
    Hilo Hawaii
    Any one have any idea's
  3. Apr 18, 2020 at 2:18 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    My first thought Does the truck have a alarm or parts of one??
    Time to break out the multi Meter check voltages and the main grounds .
    When you say the tach and temp gauge did not work the needles did not move??
  4. Apr 18, 2020 at 2:20 AM
    JohnT43
    JohnT43 Well-Known Member
    2007 Tacoma
    Radio
    Alternator.
  5. Apr 18, 2020 at 2:23 AM
    ekahi1
    Hilo Hawaii
    No alarms. Batt voltage is good dome light, headlight ect all work. Started and drove home fine besides no tach and temp gauge. After I shut it off went to re start and nothing no lights on the dash no start just nothing. I'm thinking ignition switch...of course my DMM is acting up..
  6. Apr 18, 2020 at 11:05 AM
    ekahi1
    Hilo Hawaii
    But if it is a bad ignition switch why would the temp gauge and tach not work.
  7. Apr 18, 2020 at 8:29 PM
    ekahi1
    Hilo Hawaii
    Any one have any idea what else it could be
  8. Apr 18, 2020 at 8:50 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Are your tail lights out as well?
    Dash lights and tail lights are the same fuse.
  9. Apr 18, 2020 at 9:22 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Battery voltage might be good with no load, but drop with any load. Did you try to jump start it? It certainly sounds like a bad battery or bad connection to the battery. Any corrosion on the terminals? Like someone else said, it could be the alternator and you were able to run off the battery just long enough to get home, but it discharged.
  10. Apr 19, 2020 at 12:57 AM
    ekahi1
    Hilo Hawaii
    But why is there no lights on the dash when I turn the key to the on position theres nothing and with the door open the door chime dosent stop. It's as if the ignition switch is not working. There is power to the switch but I haven't had a chance to test any thing else.
  11. Apr 19, 2020 at 1:32 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Sounds like a ground issue.. anything aftermarket up under the dash?
  12. Apr 19, 2020 at 1:46 AM
    ekahi1
    Hilo Hawaii
    Nothing under the dash head unit still works fine. Headlight, blinkers, hazards, wipers, dome light, a/c blower ect all work fine. Nothing on the gauges works and no crank no start. Nothing happens when I turn the key. That's why I'm leading towards ignition switch. But the no tach and temp gauge is throwing me off.
  13. Apr 19, 2020 at 4:51 AM
    otis24
    Mark
    California
    Do your tail lights still work?
    This thread might have some helpful info.
    https://www.tacomaworld.com/threads/instrument-cluster-dash-lights-all-out-help-please.268763/
  14. Apr 20, 2020 at 1:45 PM
    ekahi1
    Hilo Hawaii
    Figured it out. It was the blown 10amp gauge fuse under the drivers side dash. It must also tie into the ignition system not sure exactly how but Changed fuse truck starts and all gauges work fine.
    Hamer95USA likes this.
  15. Apr 20, 2020 at 2:50 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Glad you found it.
    Always check the easy things first.
    What caused the fuse to open??
  16. Apr 20, 2020 at 3:05 PM
    ekahi1
    Hilo Hawaii
    @Wyoming09 not sure...I cleaned up the main ground off the batt. And terminals.
