No power from starter relay
Discussion in '2nd Gen. Tacomas (2005-2015)' started by garage_monkey, May 18, 2018.
  1. May 18, 2018 at 7:59 PM
    garage_monkey
    garage_monkey [OP] You're dumber than stupid.
    Carlsbad, NM
    Silver '08 and Lunar '22 DCs
    Murdered Out the Rims, ARB Bumper, OME upgrade
    I have exhausted all efforts on getting my truck started. Checked battery, voltage is at 13v. Getting power to starter relay, starter relay is engaging when key is turned to start position (bought a new one just to confirm it’s a nonissue). Pulled starter and jumped the power to solenoid and starter engaged. Placed the starter back, and jumped power straight from the battery to the starter wire on the low side and starter engaged.
    The only area that I can see an issue is from the starter relay to the wire harness that runs the wire to the low side of the starter (it’s a yellow wire with a small green stripe). Anyone have any suggestions?
  2. May 18, 2018 at 8:06 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Use a DMM to check continuity between the relay and the starter (small wire) terminal.
    Take the fuse box apart a little and look for any cooked wires inside of it.
    Check closely to see if any wires are rubbing on the frame and offering another path to ground
  3. May 18, 2018 at 8:12 PM
    garage_monkey
    Carlsbad, NM
    I just tried to start it with key in the on position by jumping the power straight to the starter. Motor turns over, but it will not start.
  4. May 18, 2018 at 8:35 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Anti-theft issue?
    Just to be clear though, you think there is an issue between the starter relay in the fuse box and the starter motor itself? On the little control wire?
  5. May 18, 2018 at 8:40 PM
    garage_monkey
    Carlsbad, NM
    That is where I thought my problem was until I just tried to start it by using a jumper wire. Had the key in On position to use jumper wire and everything turns over, motor will just not fire. So I am completely lost on what the issue is now.
    Could it be the neutral safety switch?
  6. May 18, 2018 at 8:47 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    How do you know the relay is working? A bad neutral safety switch would prevent it from closing. Just because it clicks doesn't mean the power is getting through it and on down the line where it needs to go
  7. May 20, 2018 at 7:06 PM
    garage_monkey
    Carlsbad, NM
    Ok. So I went back an double checked my work. I am NOT getting power from the relay to the low side on my starter.
    I also tested the relay and determined it is working correctly as well. So it is something between the relay and low side of starter.
    Not sure how to proceed from here?
  8. May 20, 2018 at 9:30 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    There is only wire between the starter relay and the starter motor.
  9. May 21, 2018 at 6:25 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    While wiggling the yellow/green wire
  10. May 21, 2018 at 11:54 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    That is what she said!
    b_r_o likes this.
  11. May 22, 2018 at 5:35 PM
    garage_monkey
    Carlsbad, NM
    Alright let’s start this from the very beginning. Last Thursday I get in my truck for work and my blower for the A/C is not working correctly but still works. Fan on third speed is blowing slower than that second position. So that evening do a little searching on here and find out that it’s probably the connector that plugs into the resistor. So the next morning I jump in the middle of that and find that sure enough I have a burnt wire that connects to the resistor. So I remove the resistor to make sure I have the correct part. Hop in the driver’s seat to run to parts store and bam no cranky cranky!
    I am beginning to wonder if I smoked a wire that has something to do with the factory alarm. It is my understanding that the alarm, when engaged, disables the vehicle from starting. Any ideas?
  12. May 22, 2018 at 6:19 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    IF the starter relay is closing then you don't have an alarm issue.
    You need to pin out all 4 terminals of the relay and see what you have and what you don't have at each terminal. A multi-meter or test light is required. I also like to use a relay test kit like this one. It allows you to test all 4 pins with the relay plugged in. The wiring diagram provided by jimmyh in post #8 will help.. LIL-56810.jpg
    If pins 5 and 1 have power during cranking and there is a good ground on pin 2 then you don't have an alarm issue and you can focus on the green/yellow wire (pin 3).
  13. May 22, 2018 at 7:48 PM
    garage_monkey
    Carlsbad, NM
    Thanks for your help. Hopefully I have some time to walk through it tomorrow
  14. Oct 18, 2018 at 2:18 PM
    garage_monkey
    Carlsbad, NM
    Update: I finally slowed down enough to update my issue. As painful as this is I am going to tell on myself!!! After exhausting all efforts I loaded my truck up and took it to the dealership to have them figure out the problem. It took the tech approximately 30 minutes to find that the fuse I replaced was in the WRONG slot, fuck I'm an idiot!!!!!!!!!!!!!!!!!!!! So future reference, don't just check to see if your fuses are good, make sure you put them in the right place!
    GirlMud01Taco4x4 and b_r_o like this.
  15. Oct 18, 2018 at 2:28 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    :yay:glad you got it figured out!
    GirlMud01Taco4x4 likes this.
  16. Oct 18, 2018 at 7:23 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    :bananadead:
    Well I commend you for your integrity and honesty.
    Glad you got it fixed.
