No coolant
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kacosta91, Jul 21, 2021.
  1. Jul 21, 2021 at 1:04 PM
    Kacosta91
    Kacosta91 [OP] Member
    2021 Tacoma SR5
    Hello, everyone. I purchased a 2021 Tacoma SR5 in May. One day, I was just sitting in the truck with it running when I noticed the temperature gauge was creeping up to the hot side.So I turned the truck off and looked under the hood. Low and behold, it didn't have any coolant. Thinking it was a slip-up on the dealership's part, I added some to the radiator and reservoir. A couple days later, I pop the hood just to see and again there was no coolant! It's currently at the dealership and has been for going on 4 days now. They said they don't see any leaks but are keeping it to run more tests. Just wondering if anyone else has had this kind of problem and how it was resolved?!
    FishnTx likes this.
  2. Jul 21, 2021 at 1:14 PM
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    No obvious leak externally means it's leaking internally. How much coolant did you put in? White smoke? Sweet smell at tailpipe?
  3. Jul 21, 2021 at 1:16 PM
    Kacosta91
    2021 Tacoma SR5
    Maybe a little less than half a gallon. No white smoke and didn't think to smell the exhaust.
  4. Jul 21, 2021 at 1:17 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Sometimes a bubble can form in the system and it blocks coolant from getting in. The dealer should be pressure testing the system, then pulling a vacuum and putting in the new coolant. That shouldnt really take 4 days to complete, but Im guessing they are filling it then letting it sit all day to see if it leaks (which can be done with the pressure test)
  5. Jul 21, 2021 at 1:21 PM
    Kacosta91
    2021 Tacoma SR5
    What exactly does a pressure test do?
  6. Jul 21, 2021 at 1:26 PM
    5nahalf
    Erik
    Minnesota
    So a pressure tester will put the cooling system under pressure (forces air in and seals it off). If there is a leak, the pressure will go down over time and they will see it on the gauge. If there is a external leak, they will see coolant coming out of there. If its a internal leak (head gasket) then they will just see a pressure drop until they check the engine oil.
    It could be that the system was not filled all the way from the factory, or there could be a leak. But if there was a leak, it would be very obvious. There would be coolant on the ground, coolant in the oil, or smoke coming from the tail pipe.
  7. Jul 21, 2021 at 1:31 PM
    Kacosta91
    2021 Tacoma SR5
    That does not sound very promising at all! Thank you for the info!
  8. Jul 21, 2021 at 1:32 PM
    5nahalf
    Erik
    Minnesota
    Its a simple test that takes about a hour to complete. The fact that they have had it for 4 days makes me think there is no leak and they are chasing a ghost right now.
  9. Jul 21, 2021 at 1:36 PM
    Rob MacRuger
    Rob MacRuger Well-Known Member
    2006 4X4 SR5 4.0
    What color is the engine oil?
    Big tall dave likes this.
  10. Jul 21, 2021 at 1:38 PM
    Kacosta91
    2021 Tacoma SR5
    I'm not sure, that is not something I thought to check.
  11. Jul 21, 2021 at 1:39 PM
    tommygs3
    tommygs3 Well-Known Member
    tommy
    18 tacoma limited
    Fox 2.0 - KDmax tune - 5.29 revolution
    if the pressure test detect nothing and the is no dry pink coolant anywhere around the engine compartment... then the dealer will be chasing ghost...
    Kacosta91[OP] likes this.
  12. Jul 21, 2021 at 2:55 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    how much coolant did you add 4 days later? you say "one day i was sitting in the truck" this one day, a week ago, 2 weeks?
    reason i ask is from the day you bought it until the first time you discovered it then only 4 days later again the same issue tells me it was not low from the lot when you bought it.
  13. Jul 21, 2021 at 2:59 PM
    513Mugsy
    513Mugsy Well-Known Member
    Cincy
    2020 VOODOO AC OR MT sold now
    Ok...my son, my dad, and myself encountered this very situation...on a 4 cyl 93 Celica. It was loosing coolant when warm, not burning a drop, but was not in the oil. What we found when we pulled the head were tiny cracks between the water jackets and the exhaust ports....and about 1 gallon of coolant in the two mufflers in the exhaust system. When cold no leak through. When warm it would pour through on the third cyl. So much that it cooled the manifold and cracked it eventually. We chased that for two weeks in the garage before we just pulled the head off.
  14. Jul 21, 2021 at 3:01 PM
    Kacosta91
    2021 Tacoma SR5
    Roughly 2 weeks ago, I discovered it didn't have coolant, added a little less than half a gallon. Maybe three days after that, checked again, empty, added the other half of the gallon (most of it was gone within a 3 hour span), called dealership to make an appointment. The day of the appointment (about a week later), I added another half of a gallon and brought it straight to the dealership.
  15. Jul 21, 2021 at 3:04 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    It a new Truck? Don't mess around with it and give the dealer a window to question something you did, or did not do. Take it back to them for a fix - that is what you have a warranty for. The overflow tank should have fluid in it all times too. Just the apparent simple fix of adding fluid could be a sign of a bad head gasket or worse. In any case you can let them know you had to add Toyota approved fluid as a preventative maintenance step which should not be necessary or a new truck. GL.
  16. Jul 21, 2021 at 3:07 PM
    Kacosta91
    2021 Tacoma SR5
    Yes, it's a new truck. Barely has 2,000 miles on it. I already brought it to the dealer but they are scratching their heads.
  17. Jul 21, 2021 at 3:09 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Quit driving it.
    No coolant will eventually mean a new engine, if you keep driving it.
  18. Jul 21, 2021 at 3:17 PM
    5nahalf
    Erik
    Minnesota
    He's not driving it? he stated in his first post that its at the dealer right now and has been for the past 4 days.
  19. Jul 21, 2021 at 3:19 PM
    Knute
    Sorry......missed that.........:anonymous:
    5nahalf likes this.
  20. Jul 21, 2021 at 3:45 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    He is a She.
    And and a Gallon of coolant in 3 days is a lot.
    Since it a new truck, I’d tell them to drive it if that’s what it takes to diagnose.
    I wouldn’t want it back until it doesn’t lose coolant.
    Hopefully they have her a good loaner.
    Nothing like buying a truck, and getting a Prius as a loaner.
    Not that I have anything against a Prius, it just doesn’t have a bed or the ability to preform the task I need it to ever week.
    jayuu, SR-71A, Junkhead and 1 other person like this.
