No click, no crank, no start...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taranw25, Oct 6, 2020.
  1. Oct 6, 2020 at 5:02 PM
    Taranw25
    Taranw25 [OP] Member
    99’ 2.4l 2wd
    So this Tacoma is actually my fathers and he asked if I’d help him since his not so tech savvy. So let me say he’s no novice when it comes to turning wrenches. But he started by trying to start it to move and changed the oil and got a “click”. Battery terminals looked rough so he cleaned and replaced and battery is good. So he then changed the starter, still nothing. He then changed the ignition switch, nothing. He then changed the starter relay and power outlet relay and still nothing. He went as far and changing the battery cables. We’re stumped and everything checks out. We have door chime, lights, dash lights. This thing seriously will not turnover we tried starting in park and neutral. Any ideas?
  2. Oct 6, 2020 at 5:09 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    fuses?
    bigmw likes this.
  3. Oct 6, 2020 at 5:16 PM
    Taranw25
    99’ 2.4l 2wd
    Fuses check out.
  4. Oct 6, 2020 at 5:18 PM
    jbrandt
    Justin
    Visual inspection or did you check continuity? I've had a fuse or 2 that look good but don't connect.
  5. Oct 6, 2020 at 5:19 PM
    Tacoma1997White4x4
    Tacoma1997White4x4 America First
    West Covina, California
    1997 white 4x4 auto 4cylinder Singlecab, 2001 auto rwd 2.4l single cab flatbed
    Km3’s 31’s,Lift,Sliders,rear ARB air locker,on board air, armor, hi shell
    Have you checked if the battery is any good? The terminals need to be clean and tight put some gel on those posts so they dont rust , jump start it , is it a manual? If so jump the clutch
  6. Oct 6, 2020 at 5:22 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Ground wire somewhere
  7. Oct 6, 2020 at 5:27 PM
    Taranw25
    99’ 2.4l 2wd
    Op says battery is good.
  8. Oct 6, 2020 at 5:31 PM
    jbrandt
    Justin
    you said in the op you said
    do you mean cleaned and replaced the terminals, or did you replace the battery, too?
    How old is the battery? How you do know it's good?
  9. Oct 6, 2020 at 5:38 PM
    Taranw25
    99’ 2.4l 2wd
    Because I checked the battery and it was good. And the terminals were replaced and posts were cleaned. We have power to the starter but no turn.
    wilcam47 likes this.
  10. Oct 6, 2020 at 5:51 PM
    jbrandt
    Justin
    Did you load test it or just stick a voltmeter on it?
    How old is that battery?
    With your symptoms, I would have replaced, or at least had the battery load tested before replacing the starter, and all those other parts.
    Gunshot-6A likes this.
  11. Oct 6, 2020 at 5:58 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Power to the Starter (big wire)
    Power to the solenoid
    The cables are good
    The battery is good
    That pretty much leaves the starter.
    A lot of the time, it isthe contacts.
    See this video for what “usually” goes wrong.
    https://youtu.be/cWm8j1SkUD8
  12. Oct 6, 2020 at 6:41 PM
    Taranw25
    99’ 2.4l 2wd
    Well the starter is new and was tested
  13. Oct 6, 2020 at 7:28 PM
    TnShooter
    Deogee
    STOCK
    Are you getting power to Black/White wire on the starter?
    If not, check the starter relay?
    Are you Auto or Manual?
  14. Oct 6, 2020 at 7:34 PM
    TnShooter
    Deogee
    STOCK
    Ok, I reread your first post.
    If the stater relay is good (new) you still need power to the relay.
    You have 2 different powers to the relay.
    1 from the battery, 1 from the ignition switch.
    You have 3 different fuse that power goes through.
    Check them
    120A Alt fuse
    40A AM1
    7.5A STA
    Power also goes through the Park/Neutral Safety Switch for an Automatic.
    Or the Clutch Start Switch for a Manual.
    You should check these.
    1997tacomav6 and wilcam47 like this.
  15. Oct 6, 2020 at 7:45 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    how long has it been sitting? Can you turn the crank shaft manually to see if the engine is free and not locked up? Also with the lights on and try to start does the lights dim? Like theres an electrical load on?
    1997tacomav6 and TnShooter like this.
  16. Oct 6, 2020 at 7:47 PM
    TnShooter
    Deogee
    STOCK
    I thought of that, but then didn’t want to think of that.
    That would be Bad, really BAD. I figured we would start with the “not so bad stuff”
    2020 sucks enough. Lol
    wilcam47[QUOTED] likes this.
  17. Oct 6, 2020 at 7:52 PM
    wilcam47
    Will
    Bourbon state
    Yeah...sounds like for all intents its trying to turn starter over....
    TnShooter[QUOTED] likes this.
  18. Oct 6, 2020 at 8:07 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    It would have to sit for hundreds of years not to start from internal corrosion if it ran when parked. I start my similar project truck once every six months with no problems. Hot rodders get cars running that have been sitting in fields for 70 years.
    If you’re getting power to the starter, have you tried this what others have suggested and turn your headlights on and see if they dim when engaging the starter? If they are then you could check these measurements here from a thorough set of test procedures.
    https://www.google.com/amp/s/www.howacarworks.com/ignition-system/checking-the-starter-circuit.amp
  19. Oct 6, 2020 at 8:18 PM
    wilcam47
    Will
    Bourbon state
    In prime conditions yes, but without knowing all the variables its not impossible...
    TnShooter likes this.
  20. Oct 6, 2020 at 10:43 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    If you had the hood off and plenum removed sure but cars out in fields get going on shows all the time. OP maybe you want to elaborate - did your dad leave this out in the snow for 20 years or sitting in the garage for 4 months
