No Apple Car Play? Help!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Stevenas, Apr 21, 2025.
  1. Apr 21, 2025 at 11:11 PM
    Stevenas
    Stevenas [OP] Member
    I just purchased a used '23 SR5 and for the life of me can't get Apple Car Play.
    I have tried multiple different USB cables, iPhones and nothing!!
    The iPhone charges from USB, I connect and play music via bluetooth but NO Apple Car Play.
    What to try next?
    Help!
    Thanks in advance.
  2. Apr 21, 2025 at 11:23 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    There’s a setting in the radio options to enable CarPlay. It also has to be enabled on your phone and the phone plugged into the correct USB port in the truck.
    t0p_d0g likes this.
  3. Apr 21, 2025 at 11:30 PM
    Stevenas
    Yeah, I found that and turned that on in the radio options. I plugged into the USB in the dash and the one in the center console compartment also.
    Is there another USB port somewhere?
    The same iPhone worked with CarPlay in my trade in so I know it's not the phone (iPhone 16 pro)
  4. Apr 22, 2025 at 12:00 AM
    Stevenas
    Would a hard reset of radio unit be worth a try? By removing the fuses to the radio for a few minutes?
  5. Apr 22, 2025 at 12:31 AM
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    CarPlay is run through the USB port located under the climate controls. Have you tried another iPhone to truly rule out your phone? Have you tried an Android phone to see if Android auto works in the truck?
    Stevenas[OP] and Chew like this.
  6. Apr 22, 2025 at 3:50 AM
    Hogleg918
    Hogleg918 Well-Known Member
    Oklahoma
    Ranger Raptor, sorry TW
    Is it still under the 3/36 warranty? Could also require an update to radio. I know my Tacoma needed that because CarPlay stopped working.
    Stevenas[OP] likes this.
  7. Apr 22, 2025 at 4:34 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    Use only factory cables is the first advice. We have a little box that allows the wired apple carplay to go over WiFi for seamless connections. It was about $70 on Amazon.
    https://a.co/d/5RxvAhA
  8. Apr 22, 2025 at 5:47 AM
    ugawino
    ugawino Well-Known Member
    Bill
    Paola, KS
    2021 TRD Off-Road, Silver Sky Metallic
    Mods? We don't need no stinking mods.
    These head units are very picky when it comes to which cables are compatible with Apple/Android.
    I've got a few cables from UGREEN and SUNGUY that work with AndroidAuto. And a drawer full of other cables that don't.
    My wife's cable that came with her iPhone works as well.
    But you can't plug in just any $5 Walmart cable or that cable that came with your rechargeable speaker.
    Snobdds and Chew like this.
  9. Apr 22, 2025 at 4:40 PM
    Stevenas
    I brought it by the dealer who told me that since the Tacoma was formally a lease/fleet vehicle it is linked with another account in the Toyota Connect APP.
    Could this be the issue? This company disabled the Apple CarPlay feature? Has anyone heard of such a thing?
    Dealer told me that I would have to call Toyota Connect support desk to verify my ownership of the vehicle.
    Problem is, their hours at 9am to 6pm UAE standard time!
  10. Apr 23, 2025 at 3:38 AM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Problem solved yet you’re complaining about the hours? FML
  11. Apr 23, 2025 at 3:47 AM
    Stevenas
    Wrong pal. Problem is not solved.
  12. Apr 23, 2025 at 4:06 AM
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    2023 TRD OR
    What’d they say when you called
  13. Apr 23, 2025 at 4:18 AM
    Stevenas
    Non working number.
  14. Apr 23, 2025 at 4:34 AM
    fiftysix
    Midwest
    2023 TRD OR
    Try 1-800-331-4331
  15. Apr 23, 2025 at 6:46 AM
    SnuggleTruck
    SnuggleTruck Well-Known Member
    Alex
    Fort Myers
    2020 DCLB TRD OR
    TRD 2" lift shocks Icon AAL (gave me 1" lift with OL leaf out) 17x8.5" -12mm Trail Edition OEM replica wheels by FSW BF Goodrich KO2s (285 70 17) ECGS bushing OME carrier bearing drop kit TRD Pro skid plate Truxedo roll up Tonneau cover MESO - led interior light kit, blackout kit and gashole Toyota door sill protectors and bed mat
    how has this unit performed for you? I really want wireless CarPlay but I’m afraid of spotty connectivity. Thanks!
  16. Apr 23, 2025 at 7:38 AM
    Snobdds
    Snobdds Member
    2021 Tacoma ORD
    The cable has to be a data cable, not just a charging cable.
    It took me going to Verizon and getting an expensive data cable for it to work.
    Chew likes this.
  17. Apr 23, 2025 at 7:42 AM
    Stevenas
    Really? Not factory Apple issued cord?
  18. Apr 23, 2025 at 7:54 AM
    Snobdds
    Snobdds Member
    2021 Tacoma ORD
    I don't know about Apple, don't use their ecosystem.
    I know my Samsung S24 needed a data cable and not just a standard charging cable.
    ugawino and Stevenas[QUOTED][OP] like this.
  19. Apr 23, 2025 at 8:19 AM
    Toyko Joe
    99.98% works without issues or dropping. Sometimes Siri is a bit jarbled when reading text messages but otherwise fine.
    SnuggleTruck[QUOTED] likes this.
  20. Apr 23, 2025 at 11:03 AM
    Kolohe07
    Kolohe07 Well-Known Member
    David
    Haiku , Maui, Hi
    2022 Access cab Sport 4x4 Celestial Silver
    Make sure you have a clean contact in your charging port.
    pocket lint will get in there and interfere with the connection.
    I periodically clean it out with a tiny piece of paper towel, with rubbing alchohol swabbed with the head of a needle.
