No air blowing from my AC/Heat
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mejij037, Sep 26, 2014.
  1. Sep 26, 2014 at 9:22 AM
    mejij037
    mejij037 [OP] Member
    Jake
    California
    05 PreRunner
    I have an '05 Tacoma and it has stopped blowing air (hot and cold).
    The main problem is that it stopped blowing air for about a month or so and then all of a sudden everything worked fine again for another month. Same thing has happened for about a year until recently. Now the air never blows, except for extremely rare occasions where it will blow for about 5 minutes and once I shutoff the car the air won’t come back on the next time I start.. Any ideas?
    I initially thought it was a fuse or something but intermittent issues make it seem like it is something else. Any ideas? :confused:
  2. Sep 26, 2014 at 9:32 AM
    A_Ninja_Racer
    A_Ninja_Racer Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    With out testing I would say that it sounds like your blower motor has failed. I would want to do a little more testing to confirm but this is the same thing that happened on my celica. the motor worked fine one night and then the next morning nothing. a week or to later it turned on again and worked for a while and then then it would quit on me the next time I would get in and turn it on. this happened in cycles for a while until it stopped working long enough to really piss me off (Florida Heat). so I went to a Barley Used auto parts and got a used one from them. Haven't had a problem since.
  3. Sep 26, 2014 at 9:34 AM
    mejij037
    Jake
    California
    05 PreRunner
    Ah ok, thank you for the quick response. How did you determine that it was the blower motor? Just guessed and then replaced?
  4. Sep 26, 2014 at 9:57 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Welcome to TW!
    These trucks are known to have blower motor issues. If you search "blower motor issues" you will find hundreds of threads on many different ways they have failed.
  5. Sep 26, 2014 at 10:09 AM
    mejij037
    Jake
    California
    05 PreRunner
    Thanks for the help! I'll try it out this weekend and let you know how it goes.
  6. Sep 26, 2014 at 10:16 AM
    mejij037
    Jake
    California
    05 PreRunner
    Now that you guys pointed me in the right direction, it sounds like it may be an issue of the blower motor resistor, actual blower motor or the wiring. I'm going to take a deeper look and see. Either way I definitely think I found a fix!
  7. Sep 26, 2014 at 10:21 AM
    hitmans.army
    hitmans.army Just a guy.
    Myrtle Creek, OR
    '07 PreRunner & '40 Chrysler Coupe
    Bilstein 5100s up front with OME 885s, rear Add-A-Leaf, LED lights (tails, dome, map, plate lights), Kicker 8" in custom fiberglass enclosure under back seat, Kicker speakers throughout and Kicker amp for sub, Pioneer DVD Player, Satoshi Grille with Devil Horns, Leer 100XQ.
    Give the blower a solid smack. NOT with a sledge hammer, that'll break it. I use a tire knocker. Or go the "correct" route and test things.
  8. Sep 26, 2014 at 10:23 AM
    A_Ninja_Racer
    Tampa, FL
    I know when a resister goes bad it still works on high. I had a feeling it wasnt the switch so I chose to replace the motor. I could have tested the switch with a test light but I didn't and my hunch was good.
  9. Sep 26, 2014 at 10:34 AM
    mejij037
    Jake
    California
    05 PreRunner
    Oh ok, mine isn't working on high either so it sounds like it is the actual resistor.
  10. Sep 26, 2014 at 11:45 AM
    A_Ninja_Racer
    Tampa, FL
    No that's wrong a bad resister will always work on high. It would only not work on 1 2 or 3. Where the resistor has to provide resistance to slow down the speed of the motor.
    MTopp likes this.
  11. Sep 26, 2014 at 11:59 AM
    hitmans.army
    Myrtle Creek, OR
    Seriously. Go out, turn the fan switch on high (with ign on), and smack the bottom of the blower motor. See if it starts working.
  12. Oct 27, 2014 at 3:08 PM
    07terry
    07terry Active Member
    north carolina
    07 4x4 trd
    where is the resistor
  13. Oct 27, 2014 at 3:13 PM
    Burnsy444
    Burnsy444 Active Member
    Virginia
    07 Taco doublecab 4x4 sport
    grill guard winch Baja Roof Rack 4 Hella Black Magics 2 Hella Floods 3" leveling lift BFG AT'S Ultra Wheel Gauntlett Wheels Weather Tech mats Debaged Rebadged on the tailgate
    Check the resistor first. I'm willing to bet that it is the problem rather than the motor! I can tell you where it is and how to fix it if you want. There's a thread somewhere around here.... Anyhow I am an electronics tech, and fix circuit boards everyday. Take my advise for what it's worth!
    whiteshoes07 likes this.
  14. Oct 27, 2014 at 3:16 PM
    Burnsy444
    Virginia
    If the resistor is totally blown it causes an "open" in the path of current and the blower will not work at all. The reason it only work on high when the resistor is "bad" is because the resistive value has been comprised causing a "short" to wich only high will work
  15. Oct 27, 2014 at 3:23 PM
    Burnsy444
    Virginia
    A "bad" resistor will NOT ALWAYS work on high, that is really poor electronic circuit advise. The bang test is a legit test on your blower motor. Likely there are relays in the motor assembly which stick in an "open" position causing it not to work
  16. Oct 27, 2014 at 3:26 PM
    Burnsy444
    Virginia
  17. Oct 27, 2014 at 3:27 PM
    joshua721
    joshua721 Well-Known Member
    16 f150 xlt v6
    Correct.
    When they work on high only its not the resistor its the plug assembly.
    Check connections first then the blower motor.
  18. Oct 28, 2014 at 8:49 AM
    fritzthecat
    fritzthecat Well-Known Member
    Virginia Beach
    07 PreRunner Auto AccCab Indigo
    Sigh.
    The Fan resistor is actually 3 resistors in one module.
    The 3 resistors have different values to vary the fan speed.
    On HIGH the resistor module is bypassed and the full voltage goes to the fan. That is why the fan will run on HIGH if the resistor module is burnt out.
    There are no relays in the fan motor. It's simply a cheap, brushed motor that sometimes gets stuck. Some kinetic energy transfer maintenance will jolt it enough to get it moving again.
    Fan only runs on HIGH - resistor
    Fan doesn't run at all - fan/wiring/fuse/control. Or a dead rat jammed in the blower.
    Fritz
    MTopp likes this.
  19. Oct 28, 2014 at 8:58 AM
    A_Ninja_Racer
    Tampa, FL
    That's what I've been trying to say. Just didn't want to spell it out from my smart phone.
  20. Oct 28, 2014 at 9:07 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Sadly the "new design" resistors suck just as bad if not worse than the original design. My original lasted 3 years before burning out and the new design lasted less than 1 year. I need to buy a crate of the junk.
