No.2 knock sensor, my question why does it cost over 2 grand to replace a 60 dollar part
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Francal51, Feb 9, 2017.
  1. Feb 9, 2017 at 9:45 AM
    Francal51
    Francal51 [OP] New Member
    2009 tacoma
    None
    Why does it cost over 2 grand to replace a no. Bank 2 knock sensor on a 2009 taco part cost 60 bucks
  2. Feb 9, 2017 at 9:45 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Labor?
  3. Feb 9, 2017 at 10:19 AM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    It's not the cost of the part that is usually the most expensive for a repair, it's how much work you need to do to swap it.
    How Manu hours are needed to tear into the engine to swap that part?
  4. Feb 9, 2017 at 10:52 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    because it is buried under a ton of engine parts and fuel rails
    that are more than just loosening a bolt and
    moving something aside
    it's all labor, and gaskets....at how much per hour ?
    since the engine doesn't need to be dropped...you can do it yourself easily
    you just need the tools and time
  5. Feb 9, 2017 at 10:58 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Because vehicles are designed by people who sit at a desk, wear a suit, and do not think about what happens after the vehicle is sold.
    Lester Lugnut and mwc273 like this.
  6. Feb 9, 2017 at 12:31 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
  7. Feb 9, 2017 at 12:39 PM
    jv_74
    jv_74 Well-Known Member
    Jesse
    Filthadelphia
    2015 DCSB Silver Sky Metallic
    Because they know how to do it, and you don't :crapstorm:
    Mach375 and ManBeast like this.
  8. Feb 9, 2017 at 1:34 PM
    ABA180
    East Bridgewater MA
    And have the time, tools, and shop to do it.
    jv_74[QUOTED] and outlawtacoma like this.
  9. Feb 9, 2017 at 4:05 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Easiest way to reach the, it to remove the heads. Resourceful method, is to remove the lower plenum, and have flex head ratchet wrenches. Still isn't easy.
  10. Feb 9, 2017 at 5:32 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Just to f with you. It's a conspiracy I tell ya.
  11. Feb 9, 2017 at 7:26 PM
    elliott3
    elliott3 Unknown
    in the ozarks
    99 xtracab 4x4 03 dcsb 4x4
    I didn't have to pull no heads on mine. You just have to be very flexable.
    Torspd likes this.
  12. Feb 9, 2017 at 8:28 PM
    Aztex
    Aztex Well-Known Member
    2013 Tacoma TRD 4x4
    Yep...knock sensors!
    Remember this next time someone here tells you how dumb you are and how smart engineers are!
    W
    desertrunner24 likes this.
  13. Feb 10, 2017 at 11:53 AM
    tgear.shead
    tgear.shead Well-Known Member
    Glad I don't have a V6!
