Nitto Terra Grappler P265/70r17 113S
Discussion in 'Wheels & Tires' started by jwall1988, Feb 22, 2022.
  1. Feb 22, 2022 at 7:16 PM
    jwall1988
    jwall1988 [OP] New Member
    2022 Army Green Tacoma
    Hey all,
    Wondering what the best tire pressure is for these on the road. I can't find anything through the manufacturer because they are discontinued. The max pressure the tire says is 35 PSI. My truck is a 2022 OR. Thanks in advance!
  2. Feb 22, 2022 at 7:17 PM
    Bishop84
    Bishop84 Well-Known Member
    The max has to be 44 or higher, no way its 35.
    30psi is ideal for comfort. 35psi for slight fuel savings.
  3. Feb 22, 2022 at 7:24 PM
    jwall1988
  4. Feb 22, 2022 at 7:27 PM
    Bishop84
    I am corrected, that seems low!
    30psi is spec for 17" I believe, its on your door placard on your drivers inner b pillar.
  5. Feb 22, 2022 at 7:30 PM
    OmahTako
    OmahTako Well-Known Member
    SoCal
    Tacoma-1ea. Tundra-1ea.
    They are SL not E rated. I have Toyo AT3 and run 28 as per my convo with Toyo. I would call Nitto for good info.
  6. Feb 22, 2022 at 7:31 PM
    jwall1988
    So I had these tires installed after. it originally came with 16" tires and the placard says 30 psi.
    Appreciate your help!
  7. Feb 22, 2022 at 7:34 PM
    Bishop84
