Nitto Terra Grappler G2 VS Toyo Open Country AT3
Discussion in 'Wheels & Tires' started by Crimson Flam3s, Oct 20, 2020.
  1. Oct 20, 2020 at 9:37 AM
    Crimson Flam3s
    Crimson Flam3s [OP] Well-Known Member
    Been looking for new tires, currently have the Falken which have performed amazing but a bit on the heavy side so looking into a bit lighter options.
    Toyo has been my main choice but there are no good deals on them, about $930 with install and the discount tire certificate incase I mess them up.
    Due to Toyota's buy 3 get one free I can get the Nitto's for $670 with 2 year accident certificate, and installation.
    I wonder if @Discount Tire is able to match the dealership deal or local dealerships
    Decisions..
    Edit: Went with the Nitto's, pics below
    Hooper89 likes this.
  2. Oct 21, 2020 at 2:46 AM
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    I'm also considering these two models. Aggressive tread with SL rating for weight, and both with 65k miles.
  3. Oct 21, 2020 at 6:35 AM
    Crimson Flam3s
    I ended up installing the G2 due to the $250 savings at the Toyota dealership, it seems to perform well according to the reviews and does seem to have a slightly more aggressive look to them.
  4. Oct 21, 2020 at 7:41 AM
    tacotoospicy
    tacotoospicy Well-Known Member
    Luke
    P'cola, FL
    2019 TRD OR
    sirius xm
    What size? and did you notice a significant difference between them and the wildpeak with ride quality?
  5. Oct 21, 2020 at 9:49 AM
    Crimson Flam3s
    265/70/17, same as I had with the Wildpeaks.
    So far they ride well and I can notice power has improved a little bit since they are 6 pounds lighter after all.Just installed them yesterday and doing a 150 mile roundtrip today and a 600 mile trip at the end of the week so we will see.
    MPG doesn't seem to have changed much but that's more dependent on thread pattern and compound than just weight. Need to use them a bit longer to see what improvements there would be, I was expecting an extra 1mpg.
    Mostly interested in the rain or rare snow performance lol
    tacotoospicy[QUOTED] likes this.
  6. Oct 21, 2020 at 10:19 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I’ll assume you’ll rotate them yourself, since had you gone with discount rotations and balance are for life of the tire. Plus the certificates from discount are for a longer period of time too. If you have to pay for rotations and balances then probably a wash over the life of the tire if you went with discount.
  7. Oct 21, 2020 at 12:20 PM
    Tacospike
    Two Trucks
    Lets see them. I've been eyeing Terra Grapplers for a while. My stock tires are getting to the point of replacement but are still a few thousand miles out.
    Crimson Flam3s[OP] likes this.
  8. Oct 21, 2020 at 12:38 PM
    tacotoospicy
    Luke
    P'cola, FL
    2019 TRD OR
    sirius xm
  9. Oct 21, 2020 at 1:41 PM
    [TACOMA]
    [TACOMA] Well-Known Member
    SoCal
    '17 DCLB Sport in QS
    With weight & appearance in mind, I went with the Terra Grapplers. Truck was stock prior, so no other AT/Tire for reference.
    Tacospike and Crimson Flam3s[OP] like this.
  10. Oct 21, 2020 at 1:42 PM
    Crimson Flam3s
    @gotoman1969
    Does Toyota not include that? Tried checking but couldn't find anything. If so you have a good point on the final value though depending on how often it's done.
    As for myself, my Local DT rotates and balances without asking where they were bought lol but I normally get it done at my friends shop while doing oil changes, don't really get charged for labor just the oil and the filter parts. I also drive around 30k a year so 2 year warranty is enough in my case.
    DT is much better than dealer though when it comes to rotation or balancing, all dealer will do is try to sell you extra shit and say that wheel needs aligment every single time lmao
  11. Oct 21, 2020 at 1:45 PM
    Crimson Flam3s
    Got exactly 22mpg for my 250 mile roundtrip so not too bad, driving around 75-80moh most of the trip. Wasn't my main concern but nice to have :D
    Tacospike likes this.
  12. Oct 21, 2020 at 1:47 PM
    tacotoospicy
    Luke
    P'cola, FL
    2019 TRD OR
    sirius xm
    Looks good man, are there two different sidewall choices?
  13. Oct 21, 2020 at 1:49 PM
    skanetic
    skanetic Well-Known Member
    Andrew
    Houston
    2019 Tacoma SR V6 4x4 AT TSS off road
    Softopper, badge overlays, H9 low beams, fog lights with factory stalk switch, intermittent wiper stalk, 265/70/17 AT3W
    Hated the G2s on my truck, wet traction was garbage
    PuyallupJon likes this.
  14. Oct 21, 2020 at 1:59 PM
    Crimson Flam3s
    Yes
  15. Oct 21, 2020 at 2:02 PM
    Crimson Flam3s
    Let's hope that's not the case here, they don't have have to be perfect but as long as they ain't dangerous like the Rugged Trails lol
  16. Oct 22, 2020 at 8:24 AM
    Tacospike
    Two Trucks
    Yeah, I really like the tread side you have out. I've seen several where it's the other way and not bad but I like the way you have it.
  17. Oct 22, 2020 at 1:14 PM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    Thank you for all the good comments. We appreciate your support.
  18. Oct 24, 2020 at 7:52 PM
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    ^^^^^this
  19. Oct 25, 2020 at 11:22 AM
    emund
    emund Well-Known Member
    Arroyo Grande, CA
    2017 Inferno TRD OR 4x4
    Go RG's
  20. Oct 25, 2020 at 12:20 PM
    Tacoma13_NC
    I went with KO2s. I like the looks of them and they have a good overall rating and following. Maybe next time I'll try RGs.
    emund[QUOTED] likes this.
