Nitto ridge grappler weight size 285/70/17??
Discussion in 'Wheels & Tires' started by aidenhardcore, Aug 27, 2019.
  1. Aug 27, 2019 at 2:51 PM
    aidenhardcore
    aidenhardcore [OP] Well-Known Member
    mike
    boston,ma
    2017 trd off road
    None yet but soon all black.
    I need some help. Was looking at the Nitto ridge grappler in the 285/70/17 load c. And I’m wanting to know how much they weigh? If you go onto their website, both the load c and e are the same weight at 57.5lbs but I was told by a couple people the load c Nitto in that size is weighing lower at 54lbs. Can anyone give straight facts haha. Thanks guys.
  2. Aug 27, 2019 at 2:52 PM
    aidenhardcore
    mike
    boston,ma
    2017 trd off road
    I found a couple of post on here saying they actually weigh between 52 and 54 pounds. Can anyone comment? Lol
  3. Aug 27, 2019 at 6:53 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Doesn’t it really matter, if you want them just put them on.
  4. Aug 27, 2019 at 7:00 PM
    aidenhardcore
    mike
    boston,ma
    2017 trd off road
    I don’t care. I’m putting them on anyways I was just wondering
  5. Aug 29, 2019 at 6:30 PM
    907TrailRunner
    907TrailRunner New Member
    2019 Tacoma TRD Off-Road LB
    3" Rough Country Lift
    The Nitto Ridge Grappler 285/70R17 116Q (B rated - 4 ply, 44psi max) weighs 48.74 lbs.
    The Nitto Ridge Grappler LT285/70R17 C 116/113Q (C rated - 6 ply, 50 psi max) weighs 57.89 lbs.
    The Nitto Ridge Grappler LT285/75R17 E 121/118Q (E rated - 10 ply, 80 psi max) weighs 64.4 lbs.
    That is quite a difference from bottom to top! For my mall crawler, a C rating should be more than enough. E is overkill.
    Also considering the BFG All-Terrain T/A KO2 LT285/70R17 116C. Quite a bit lighter than the Nitto at 50.3 lbs.
